Like Tree8Likes
Old 12-28-2011, 09:08 AM   #8596
Tech Legend
Cain's Avatar
Trader Rating: 223 (100%+)
so what is considered a "safe" stock software to use on the GT2.0 ESC series that you don't have blow up concerns but still get some boosting benefits, etc?
< RC10B6D | Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-28-2011, 11:49 AM   #8597
morgoth's Avatar
Originally Posted by morgoth View Post
Hey guys,
I just bought a 10.5T Speed Passion V3 for my Xray T3.
I'm looking for a good starting FDR for indoor. The track is about 14m*30m. The other tracks I drive on are about the same. (Currently, I drive with a FDR of 6.4 on our track with a 17.5T boosted motor and it's pretty close I think.)
Anyone with a similar setup?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-28-2011, 12:34 PM   #8598
M-Technic's Avatar
Trader Rating: 15 (100%+)
If you want something REALLY safe, you can run the 119_Mod software as it really limits the amount of boost.
But you should be fine running 323_Stock, just go conservative with the settings and work your way up.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-28-2011, 01:52 PM   #8599
Hello Everyone,
Just had a quick question, is it possible to run the Speed Passion GT 2.0 LPF without a fan on the heatsink if running 13.5 pro stock with no boost what so ever (I havn't even upgraded my ESC since I got it)
I race in England, indoor carpet.
The temps can go between 2 to 20 celcius, I'm asking this because if it's possible to not run the fan, it will save me some space for electronics
Thank you
MatJ is offline   Reply With Quote
Old 12-28-2011, 02:33 PM   #8600
M-Technic's Avatar
Originally Posted by MatJ View Post
Hello Everyone,
Thank you
It should be OK. We've run a boosted 7.5t with no fan, the ESC got quite hot but was still OK even with that setup.
Old 12-28-2011, 09:56 PM   #8601
hello
i look for a 21.5 motor for f104. i look at speedpassion v3 but then i see 1 cell v3 21.5 motor. do these go with 2 cell battrey?
thank
freakyfreakyflo is offline   Reply With Quote
Old 12-28-2011, 10:29 PM   #8602
jake95's Avatar
Trader Rating: 27 (100%+)
Originally Posted by freakyfreakyflo View Post
hello
thank
yes it does
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 12-28-2011, 11:42 PM   #8603
Originally Posted by jake95 View Post
yes it does
many thanks. is there noticable performance difference from 1 cell motor on 2 cell to a normal motor on 2 sell? and the sportman motor, is this slow?
thanks
Old 12-29-2011, 01:10 AM   #8604
jake95's Avatar
thanks
i have tried in a touring car compared to normally v3 it is very smoth.it didnt seem any slower just smother
XRAY✯NOSRAM✯SANWA
Old 12-29-2011, 03:22 AM   #8605
mattwoodcraft's Avatar
thanks
i use these in my F104 pro its a great motor and yep smooth for the F1 to
mattwoodcraft is offline   Reply With Quote
Old 12-29-2011, 05:11 AM   #8606
Hello all, new to the forum and also new to the brushless system
I am currently running a 13.5 MMM SP motor on a tekin RS pro for 1/10 TC. Was wondering what would be a good starting gear ratio for 13.5 boosted.
Also is it true that I should not run anymore than 64 degrees total of timing advance? and is the ballend timing on the MMM calibrated to the software timing? ie. if I am running 11 degrees on the motor - then I shouldn't run more than 53 degrees on software
thanks for the help
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 12-29-2011, 06:10 AM   #8607
M-Technic's Avatar
thanks for the help
The speed control will only apply 64* of timing even if you have more than that programmed into your setup. You can also run motor timing on top of the 64* with caution, it will work, you are just riding a fine line of over timing the motor and causing too much heat.
EDIT: Sorry, I thought you were talking about the SP speedo, not Tekin. Tekin will allow you to run full boost and full turbo (75* total) but I am not sure that their settings are actual full degrees of timing. 64* is just a guideline that Tekin states, most people I know run more than that plus some motor timing.
Old 12-29-2011, 09:08 AM   #8608
Solara's Avatar
Trader Rating: 16 (100%+)
None....
If boost is actually that good and safe, ROAR will keep them running for stock. And there will be no blinky mode....
I would say, use our setup on the SP site, they were all tested, but they are no garantee the fastest because you might use different motor then our driver does and also different track, different layout and different condition.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-29-2011, 09:12 AM   #8609
Solara's Avatar
Hello Everyone,
Thank you
Definitely yes...I have yet to mount the fan when I am running NO TIMING software and the ESC are very cool...just check esc temp when the race is done, just for the safe side...
Old 12-30-2011, 02:36 AM   #8610
As promised, here is my setup for 17.5T boosted using the LRP X12 motor and Speed Passion GT2.0 Pro with 323Stock software.
That LRP X12 is really a pain. It gets hot no matter what you do. You can gear it anywhere between FDR 6.0-10.5 and it still gets hot (100+ deg C is "normal"). You really need to find the sweet spot for your way of driving, which is why I actually post 2 setups here.
The first is my own setup. I drive quite "smooth" and not to much on the throttle. The other setup is my teammate's setup. He is a lot more on the throttle than I am, so he can't use my setup.
The motor(s) gets around 75-80 deg Celcius after a 5 min heat.
A note for those who wish to use the LRP X12 for boosted: Use the 4-dot insert unless you want to buy a new motor very soon!
File Type: pdf GT 2.0 Pro + X12 17.5T - Johnnie Lyng.pdf (212.2 KB, 119 views)
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
