Old 12-27-2011, 01:15 PM   #8581
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by jgraham37128 View Post
How does this motor compare to the DUO 3 or RevTech 17.5? Has anyone used one with the optional ring for the 30-50 timing?
The MMM with the 30+ board feels better then a RevTech or D3 with advanced timing in it. Lap time wise Its not a bunch faster they are both close but it does seem to run stronger over 6 minutes from what I have been able to do. The MMM or any SP motor for that matter just seem smoother to drive then others and the MMM with more timing advance has really bridged the gap to the other Spec motors on the market in the speed dept.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-27-2011, 01:53 PM   #8582
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Manson View Post
What is the difference between 119 and 323 ?
i actually run the 323 with an x12 4.5 octawind, and it s realy smooth.
If i switch on the 119, what can i expect ? Is it wotk with boost/turbo like the 323 ?
or is it like old software with supercharger 1-2-3-4-5-6 etc... value
323 is design for STOCK motor but we used that for MOD motor as well...it is very aggressive and if not handle correctly, you will pop the motor left and right...very easily.
119 has boost but like 50% less then 323...it is more forgiving then 323. But it is definitely less powerful compare to 323.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-27-2011, 01:55 PM   #8583
Solara's Avatar
I can't say it better then this...thanks KK.
Old 12-27-2011, 03:02 PM   #8584
RacinJ's Avatar
Default 1S motor question
Is there a repair / replacement parts list for the 1s motors? (Rotors, bearings, stator, etc...)
The Speed Passion website doesn't have this information.
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 12-27-2011, 04:41 PM   #8585
hanulec's Avatar
Trader Rating: 23 (100%+)
Would SP ever bring out a MMM motor with the 20-30 green boards by default? The motors are great.. but it sucks to have to buy another sensor board to make them really good
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-27-2011, 06:33 PM   #8586
Csaari77's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Csaari77 View Post
The program card that I just got didn't come with any directions or the setting sticker for the Cirtix Stock Spec. Will it come with the speedo? What port on the box do I plug the speedo into?
Anyone?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 12-27-2011, 07:38 PM   #8587
wandiez1019's Avatar
Default Need set up
I'm running sp gt2 pro with tekin 10.5r....any good set up to start?...our track is about 50x30 meter....long straight is bout 40 meter.....low traction parking lot.....thanks in advance guys....
wandiez1019 is offline   Reply With Quote
Old 12-28-2011, 02:20 AM   #8588
This is my setup for the luxembourg track
lrp 4.5 octawind
soft 323
Ratio 8
ddrs 1
boost 0
Turbo 40
turbo delay 0.1
Turbo slope 3/0.1s
I don't use boost with the 4.5 because i ve got a lot of torque already.
40 degres of turbo with a low turboslop give me an impressive top speed with a really smooth motor feeling
maybe the ddrs 1 of the 119 is lower than the 323 ?
Manson is offline   Reply With Quote
Old 12-28-2011, 07:22 AM   #8589
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Anyone?
Go to the Gallery tab in the link. Club Spec is the first one in the list: http://www.speedpassion.net/en/produ...PESCPB01&c=OPT
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 12-28-2011, 07:31 AM   #8590
+1
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 12-28-2011, 09:50 AM   #8591
Solara's Avatar
Everything are on the web site and all V3 motor are sharing the same parts EXCEPT the stator....we don't sell 1S V3 stator.
Old 12-28-2011, 09:51 AM   #8592
Solara's Avatar
Sorry, no...the motor released right at the peak of the BOOST TIMING SOFTWARE racing period...running 30* timing with boost is like asking customer to send in for repair immediately.
Old 12-28-2011, 09:53 AM   #8593
Solara's Avatar
Anyone?
Please contact our USA office for the above request...thanks.
Old 12-28-2011, 09:54 AM   #8594
Solara's Avatar
We don't have any TEKIN 10.5 motor setup, but you can use our 10.5 motor setup and adjust the gearing accordingly. They should be very similar...
Old 12-28-2011, 10:01 AM   #8595
Solara's Avatar
lrp 4.5 octawind
soft 323
Ratio 8
ddrs 1
boost 0
Turbo 40
turbo delay 0.1
Turbo slope 3/0.1s
I don't use boost with the 4.5 because I've got a lot of torque already.
40 degrees of turbo with a low turbo slope give me an impressive top speed with a really smooth motor feeling
maybe the DDRS 1 of the 119 is lower than the 323 ?
You have to load 119 and give it a try....119 has couple area that is not active compare to 323...for example, 119 boost is only up to 16*, turbo is up to 20*...and I think (not 100% remember now) it has item 13 active, that means you cannot adjust rpm/ramp because we are concern about using BOOST on MOD motor if not handle correctly, it will blow up motor immediately. It is a design concern that will protect our products.
From your setup...I really think you should use BOOST more then TURBO. Try to delay the turbo engagement time a little longer (try 0.2s) and your ramp need to reverse to 12/0.1s or even higher if you are running more boost then turbo...
DDRS can be higher too...try 2 or even 3...
However, how does your setup work for you..? If that is FAST..then that works for you and that track.
Remember FAST is FAST...you just need to WIN, you don't need to win by a lap or mile...1 second or 1 cm ahead of the 2nd place is all you need to accomplish.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
