Like Tree12Likes
Old 09-26-2009, 05:57 AM   #841
sudhar93's Avatar
Send a message via MSN to sudhar93
Originally Posted by t4m1y4niac View Post
is it possible to advance the SP 11.5 V2's timing????
Yup you can adjust the timing on 11.5 V2 motor.Most of the time we didnt adjust it at my place as at neutral position its quite fast already...
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 09-26-2009, 06:46 AM   #842
Originally Posted by irgo View Post
Would that be normal for GT2.0Pro running 4.5T on 45C-50C
i dont think you are wearing sp fan, do you ?
I am using the stock fan of the speed control.
Tommorow that i would go to the track i check it again and tell you.
Team Magic G4JS - Orion wasp .12 - Traxxas 4tec - O.S 18 tz
Team Magic E4FS - speed passion GT 2 pro - 4T ver 2 - 4.5T Ver 3
Kyosho spada 09 - Kyosho mini-z monster - Kyosho mini-z mr-02
memix is offline   Reply With Quote
Old 09-26-2009, 08:02 PM   #843
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Adam, 1) did you get a head count at vegas concerning 'booster vs rec pack' ?
2) Has anyone had issues with mechanical timing adjustment on the new V3 motors?
I picked up a 17.5 that came from Vegas.....just touchin', playing with the new jewel and noticed that the sensor plug would not turn past center to the advanced side. I did some investigating and found that the sensor was indeed hitting/rubbing against the stator windings!
The motor was not used at all...not soldered in or even bolted in yet, as new, in the package as it gets!
This could help explain some of my sensor failures.....impact causing the winding to slap the sensor board!
Just what I found....looking forward to runnin the 13.5 version when it gets here
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 09-27-2009, 11:25 AM   #844
dsyed1's Avatar
hi i would like to adjust the v2 17.5 motor timing maybe 10 degrees or so... how do we do this? I did not see anything in the manual..
thanks!
dsyed1 is offline   Reply With Quote
Old 09-27-2009, 12:54 PM   #845
Is it the general finding , now, with adjustable timining on the can, that for 17.5 it is better to crank can and esc timing up and gear down a bit to keep temps in check? Or is it still gear to the moon and play with timing on the esc to gain top end and keep temps in check?
Tim
got2bqik is offline   Reply With Quote
Old 09-27-2009, 12:55 PM   #846
Today in the track ( outdoors tarmac ) with near 30C outside temp , the speed control was at 45C , motor 60C , lipo 45C .
FDR 8.2 ( 116 spur , 29 pinion )
Old 09-27-2009, 01:32 PM   #847
The 2.0 lpf will run on 1S lipo, right? Has anyone been running it in their 1/12? What ver, software for 10.5 1S lipo 1/12, on a medium technical track??
Tim
Old 09-27-2009, 01:55 PM   #848
Hi,
Is it ok for me to use 12AWG wire going from my GT2.0 LPF to my v3.0 13.5t motor ? i notice its 14AWG that come with my speed control
Thanks in advance
madwestmo is offline   Reply With Quote
Old 09-27-2009, 03:07 PM   #849
Mike Haynes's Avatar
Tim
312 software,full timing and 9 drrs, i have been using an rx pack and speedo switch off
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-27-2009, 08:58 PM   #850
irgo's Avatar
Tim.
Mike Haynes
Tim
if you want too
with 1S
don't forget to disabled your cut-off
set your cut-off to none (1)
Quark Force
irgo is offline   Reply With Quote
Old 09-27-2009, 11:45 PM   #851
Originally Posted by madwestmo View Post
Hi,
Thanks in advance
anyone ? dont wanna fit it until im sure ??
Old 09-28-2009, 12:54 AM   #852
irgo's Avatar
Quark Force
Old 09-28-2009, 12:58 AM   #853
irgo's Avatar
Quark Force
Old 09-28-2009, 12:59 AM   #854
irgo's Avatar
madwestmo
Hi,
Thanks in advance
Today 10:58 AManyone ? dont wanna fit it until im sure ??
that's better than 14AWG
12 AWG is lower resistance than 14 AWG.
but you would also get more heavier with that wire, due to more weight,
when comparing to the same wire length.
Quark Force
Old 09-28-2009, 01:47 AM   #855
cyanyde's Avatar
For stock motors, I run 14 AWG. But to the battery its still 12AWG.
cyanyde is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
