Old 12-20-2011, 04:56 PM   #8506
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
We are quite lucky, now the weather is excellent for racing outside.
Our local track is pretty much all SP now....
Originally Posted by Solara View Post
Thanks for the support...and keep letting us know about anything you guys working on....
In Chicago, we have something called SNOW so on road outdoor is over...we are moving in for little carpet match box car racing or Off Road. So if you guys have some good setup on ESC/motor, please let me know and I can post it on our web....
As well as other friends that used or ESC and Motor around the world...I will try to post them as well.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-20-2011, 05:27 PM   #8507
Radio Active's Avatar
Originally Posted by Radio Active View Post
Make that "have just purchased" [a MMM 17.5]. I'd still like to know the bearing dimensions. I gather they are ID 1/8", OD 3/8" but what about the 3rd dimension?
Someone must know the bearing dimensions. I'd like not to have to wait for the motor to turn up before I order the ceramics. Can anyone fill me in?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 12-21-2011, 02:30 AM   #8508
Originally Posted by nnick View Post
Our rules have no motor limit, but we have decided to run up to 4.5. With stock motor 5.5 is fast (can keep up with nitro cars on straight - loose on sweepers and turns as they run foam) so I thought no need for higher motor and run the esc safer.
If you are running the GT2.0 Pro, it is still plenty safe to run a 4.5T with timing. I have used that combo all summer, and the ESC barely gets warm at all. It is so nice and cool - even after a 7min heat.
So the ESC is not the problem. In my opinion, running a 5.5T on a huge track is probably pushing it a little. Your motor would be safer, if it was a 4.5T
Well - more safe for the motor itself. Less safe for all people around the track
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-21-2011, 03:17 AM   #8509
TeamWTF's Avatar
I'll measure for you tomorrow... Or friday if no one knows on here
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-21-2011, 08:19 AM   #8510
M-Technic's Avatar
Trader Rating: 15 (100%+)
Howard... sent you an email this morning. Thanks,
-T.J.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-21-2011, 08:22 AM   #8511
TimPotter's Avatar
Must say.. Reventon looking pretty sharp on RedRc
Old 12-21-2011, 08:41 AM   #8512
ahpeq_ong's Avatar
http://www.redrc.net/2011/12/speed-p...sc/#more-50147
ahpeq_ong is offline   Reply With Quote
Old 12-21-2011, 08:57 AM   #8513
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default order
When and where can I order one?
jgraham37128 is offline   Reply With Quote
Old 12-21-2011, 09:24 AM   #8514
M-Technic's Avatar
No kidding, especially the gold to match my Xray and Savox servo!
Old 12-21-2011, 10:28 AM   #8515
Moderator
Clegg's Avatar
So... no one here knows why a new Green timing ring in a SP 17.5 V3 would cause it to cog and seemingly be broken? (as posted yesterday?)
no one sees this? Just trying to figure out if I should deal wiht the painful RMA process.
Joe
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-21-2011, 12:00 PM   #8516
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Clegg View Post
Hey there,
I have a 17.5R V3 1 Cell motor (sealed motor from IIC). I am racing in blinky 17.5 1/12 class and wanted more than the stock 10Deg of timing. I picked up (possibly by accident) the 20+ green sensor ring. even at the lowest timing of 20, the motor barely works. It drives like an old sensorless motor, chugging, and even at full speed it sounds very very harsh like a misfire in an old car.
The Tekin ESC I am using (in ROAR mode) shows all 3 Hall sensors reporting back.
is 20 Deg just a step too far for this motor? Should I return the sensor ring? If I put the stock 0-10 black ring back in, the motor runs fine.
That sensor might be a problem....where did you get that sensor? Request warranty service and a new one should be send back to you...if under warranty period.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-21-2011, 12:23 PM   #8517
Moderator
Clegg's Avatar
Thanks,
I ordered it direct from SP, so I will ping them to get an RMA setup. I didnt know if this was expected behanviour.
Could it have anything to do with the fact this was a handout motor from Snowbirds (the 1S version)? They didnt set these up any different did they?
Old 12-21-2011, 01:25 PM   #8518
Well it looks nice
sidecarphil1 is offline   Reply With Quote
Old 12-21-2011, 01:42 PM   #8519
Solara's Avatar
-T.J.
TJ...got that email, and I will have that filed and will let you know once I am working on that.
Old 12-21-2011, 01:44 PM   #8520
Solara's Avatar
Most of our shop will carry that...or check here for the date. Right now, the S and R version will be mid JAN, Stock Club Race version will be FEB/March...PRO version will be APRIL or so.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
