The Speed Passion Thread
#8433
Guest
V3 1 cell 13.5
Anyone using this motor in their 12th scale? If so, I was wondering if you gear'm the same as a standard 13.5 or gear'm lower (bigger spur or smaller pinion)?
#8434
Depends on if your running boosted or blinky. For boosted id gear it the same as any other motor but in blinky id recommend getting the opptional 20 or 30 deg timming sensors. Then gear like normal but if running stock timming sensor you have to gear up a lot cause theirs only ten or so deg. Hope this helps.
#8441
JUst learned of Speed Passion, and was wondering if anyone could reccomend a brushless combo set that would work well in an SCT, being ran in a mild mod class on a small indoor carpet track.
Thank you,
Tom
Thank you,
Tom
#8442
But I will do a lot of testing the next couple of weeks, and get back to all of you, if I find a good setup!
#8445
