Like Tree3Likes
Old 12-02-2011, 01:20 PM   #8356
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Solara View Post
Yes..All SP ESC can use sensored or sensorless motor.....but they are all designed to run on sensored mode.
No...it cannot be run on 1S by itself. However, Club Spec can be run on 1S if you use the TQ CELL booster unit, only the TQ unit will work, I have tried others like NOVAK and somehow it won't work. And I have not try Short Course Master....but I will guess the same thing. And I would not recommend that....the ESC is designed to run on 2S.
Thanks.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-02-2011, 08:19 PM   #8357
Magnet Top's Avatar
Anyone have a good setup for the mmm 17.5 ?? ( non timing - "blinky" on a somewhat large carpet track , flowing and fast but still technical layout )
Timing and FDR settings ! I ran it once at 4.0 FDR and full ( 20 degree ) timing. It was very fast early but faded too much. Unfortunately I don't get enough test and tune time between races...
Magnet Top is offline   Reply With Quote
Old 12-02-2011, 11:26 PM   #8358
mattwoodcraft's Avatar
i have not rum much with with out using timing but i would suggest starting at a FDR of 5.5 and see what happens just keep dropping a few teeth at a time and check the temps.
with my old V3 i was running a FDR of 4 and now have a FDR of 7.3
mattwoodcraft is offline   Reply With Quote
Old 12-03-2011, 08:17 AM   #8359
unknownmember's Avatar
Hi there,
I was wondering if I can obtain a GT 2.0 housing replacement any where or from SP themselves? Mine's held together with tape ATM coz I was too harsh on the clips.
unknownmember is offline   Reply With Quote
Old 12-03-2011, 12:32 PM   #8360
Trader Rating: 17 (100%+)
I have been experimenting with different firmware On the GT 2.0, and loaded some of the latest hobbywing settings on to try, problem is now I can't seem to load SP firmware back on, keeps coming back with message saying unable to upgrade. Any suggestions?
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 12-03-2011, 10:53 PM   #8361
I have been running the citrix short course esc and v2 17.5 in my blitz and took it out tonight for an oval race. I was running max timing on the esc and added some more timing via the motor (estimated 10-15Degrees). Now I knew I was pushing the limits and it failed on me as i was leading the amain lol...greed sux.
I was considering going with the same setup since they are on sale, but then I was looking at the 17.5 mmm. How good is this motor? can it be paired with the short course esc?
Im trying to find a good 17.5 setup without breaking the bank. Anyinput would be great
Smoedog is offline   Reply With Quote
Old 12-03-2011, 11:03 PM   #8362
defcone's Avatar
Go to the 205_mod and then upgrade it on the sp software.
defcone is offline   Reply With Quote
Old 12-03-2011, 11:52 PM   #8363
Solara. i have a question regarding the much more racing thermoelectric motor cooler. here the temps are getting hot weather can these be used on brushless motors at all to cool them rite down before your race ?
or does anyone use these at all on the brushless motors
Old 12-04-2011, 12:05 AM   #8364
Pattojnr's Avatar
Trader Rating: 19 (100%+)
you want to coolem before a race ? try spray freeze , lol. then come in at 4 mins and spray again. i am joking.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-04-2011, 12:08 AM   #8365
thanks mate, so they can be used on brushless
Old 12-04-2011, 12:39 AM   #8366
TeamWTF's Avatar
Ive seen guys use them... They seemed to work very well to cool the motor. I cant remember exactly, but I think it dropped the temp around 10deg or so.
Its getting hot here also... Track temps should be hitting 60c soon enough
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-04-2011, 04:00 AM   #8367
great thanks i used a long time ago with brushed but i thought i would ask befor buying another fan. thanks 10 degrees is always a good thing when its hot for sure
Old 12-04-2011, 08:36 PM   #8368
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
I just purchased a used gt 2.1 prostock. I believe it was used for non boosted 17.5 off road. Do I need a laptop to tell what software it has and change it for boosted touring? I have the pro lcd box and software..
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 12-04-2011, 11:41 PM   #8369
to dee what software it has connect the box it will tell you what firmware the speedy has.
if you want to change the firmware you will need to use a lap top and down load the pc interface.
all the info is on the speed passion web site with vidio support aswell
Old 12-05-2011, 07:25 AM   #8370
Solara's Avatar
Trader Rating: 16 (100%+)
Try 4.75 final with 30* green board (all the way to 30*).
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
