Like Tree8Likes
Old 10-14-2011, 02:49 AM   #8101
mattwoodcraft's Avatar
whats the safest method on changing the bearings in the motors with out damaging parts and the new ceramic bearings im wanting to install
mattwoodcraft is offline   Reply With Quote
Old 10-14-2011, 03:07 AM   #8102
defcone's Avatar
Trader Rating: 15 (100%+)
I used a wheel axle and hit the old ones out with pliers. And just press the new ones on with the rotor.
defcone is offline   Reply With Quote
Old 10-14-2011, 03:46 AM   #8103
thanks i was going to do something much the same i will continue on
thanks
Old 10-14-2011, 07:53 AM   #8104
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by gom View Post
I have a newb motor question I hope some one here can help me with. I am running a stock class with a 17.5 MMM motor at only 4.8 FDR. At the first 3 min of the race the car runs great. But the power starts to fade after the 3 min mark. It's not going extremely slow or anything like that. It's just lost the "bursty" feeling that it had at the start of the race.
I checked the temperature after the race it was around 140F. So I don't think it's overheating. I am using a 25c lipo battery and a tekin RS. both seems to be running at normal temperature.
I am not sure what is causing the loss of speed. And I can't begin to fix the problem without knowing what the problem is. I am not even sure if it is a motor issue. I am just trying my luck here on the SP forum. Anyone here has experienced similar situation?
Any advise would be greatly appreciated.
Speed Power (same as Speed Passion) sells lipo, 6200mah, 65c for less then $60....I think it is time for the upgrade and get rid of those unknown problem.
Your lipo is way too low in mah and also low in C rating...you can buy something alot nicer for the same price you paid 2-3 years ago. Or even less...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-14-2011, 08:51 AM   #8105
gom
Thanks Solara. Looks like it's time to buy some new batteries.
gom is offline   Reply With Quote
Old 10-15-2011, 02:15 PM   #8106
Hi guys, any setup suggestions for a HPI pro flux 10.5t motor with the 323 software?
Running indoors on carpet around 30m x 20m track
Cheers
Mb3195 is offline   Reply With Quote
Old 10-15-2011, 02:46 PM   #8107
what's the difference between the sp 323 and hw 211 firmware? is there any?
Old 10-16-2011, 07:50 PM   #8108
i have a question regarding 17.5 turn motors, yesterday i was tuning and getting my setting correct the motor was temping around 65 degrees it has plenty of punch and mid speed but seems to lack just a little on the top end not by much but in boosted racing the LRP motors seem to be faster.
i am running the 323 software 0 degrees on the motor
45 boost and 20 turbo punch set at 7
its fast of the line and through the mid feild but lacking the top end just a small amount but noticable.
is it possable that the LRP motors rev just a little harder ? i love the speed passion but with the nationals coming up in 6 weeks i want to be on the pace
thanks any advice
Old 10-16-2011, 08:05 PM   #8109
transplantlife's Avatar
Trader Rating: 43 (98%+)
Solara i won the 5800 lipo you donated to the track. Thank's again for all your support!
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 10-17-2011, 04:29 AM   #8110
thanks any advice
drop a tooth on spur or pinion? give you a tad bit more top end?
Deepsouth is offline   Reply With Quote
Old 10-17-2011, 05:24 AM   #8111
done that still didnt help i will try a few more things next time i venture out on the track
Old 10-17-2011, 05:58 AM   #8112
jrxs-r's Avatar
Matt,
Try a little more turbo. 1 degree at a time. What is your turbo ramp rate? Temps will be safe up to about 78-80C.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-17-2011, 06:05 AM   #8113
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by jrxs-r View Post
Matt,
he is maxed out Zacha. 62 or 64 deg is Maxx. anythign past that point it will not add. so what ever he uses up first wether it be turbo, then it will add the rest of the boost to a max of 62 or 64 deg, not 100% sure on that number.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-17-2011, 06:39 AM   #8114
Manfredo's Avatar
I'm looking for a good 12th scale setup using an GT EX2.1 ESC and a V3.0 1cell 3.5t Motor. Which timing-insert, software, settings would you recommend?
It seems like boost is required nowadays in 1/12th (?) Do you guys run Stock-software with mod motors in order to do that?
P r i H o r s e power! ...welcome to the Austrian Off-Road expert ! -- www.prihorse.at
Manfredo is offline   Reply With Quote
Old 10-17-2011, 07:51 AM   #8115
thanks any advice
Try adding some motor timing. I always have more power when the SP motor's are set on 10 degrees instead of 0 or 5.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
