Like Tree46Likes
Old 10-11-2011, 09:19 AM   #8086
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Originally Posted by Solara View Post
If you are bashing...I think you should stick with the 205G software cause that software does not have BOOST/Supercharger feature like the one that you loaded (110119mod)....the 110119mod is for full race condition that required alot more complicated setting...if not handle right, yes, you can blow up the motor and esc easily.
You should turn DOWN the AMTS timing within the 205g just to play safe....check motor temp and increase your timing and gearing if temperature allow you do so.
Uploaded the default 205MOD software and went with 15 for the AMTS timing (default setting is 26.25) as you suggested and recalibrated my TX settings with the ESC as we should normally do.
Checked if everything was working properly by holding my SCT of the table and giving it short blips of the trigger forward and brake and everything works, however I noticed the LED was flashing green at the neutral position afterwards. I just read the manual a few minutes ago and it states:
LED Status for Normal Running
In normal use, if the throttle is in the neutral range, neither the red LED nor the green LED will be lit.
The red LED lights up when the car is run forward or backward and it will flash quickly when the car is braking.
The green LED lights up when the throttle stick is moved to full throttle or full brakes/reverse.
I also checked my TX throttle and brake settings and everything checks out. Not sure if the flashing LED at neutral position is normal.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-11-2011, 09:33 AM   #8087
Solara's Avatar
Trader Rating: 16 (100%+)
I also checked my TX throttle and brake settings and everything checks out. Not sure if the fashing LED at neutral position is normal.
You might be running the sensorless mode....there should NOT be any light when you are in neutral position. Check your sensor wire and all the connection.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-11-2011, 09:41 AM   #8088
JRRobiso's Avatar
Thanks. Will check everything again.
Old 10-11-2011, 10:07 AM   #8089
Sounds like it gone into sensorless mode, try changing the sensor wire, failing that unfortunately, your gonna have to change the sensor in the motor.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 10-11-2011, 11:45 AM   #8090
trytowin's Avatar
Hopefully 1st week of November. we have sold about 100 of those 2 weeks ago because the IIC and Halloween Classic event...then some are getting that for Cleveland indoor....
Keep checking our site...but always support the hobby shop, have them to place order....
Can do and Thanks!!
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 10-11-2011, 12:02 PM   #8091
JRRobiso's Avatar
Just got done inspecting the sensor wire and made sure it was plugged in properly (pulled it out and back in again). Tested it again and also recalibrated my TX with the ESC. Lifting my SCT off the ground, pulled the trigger slowly to FULL and then applied the brakes....no green LED flashing in the neutral position. Did it again but a little quicker, halfway thru the full throttle position the motor/ESC cogged down and jumped back on power and got the LED flashing at neutral again. This also happened with my SCT placed on the ground.
With that said, has the sensor wire gone bad? Will try again with another new sensor wire if that will fix it and if not I'll look into the sensor board which I hope won't need replacing.
Old 10-11-2011, 03:55 PM   #8092
mattwoodcraft's Avatar
You are running BOOST or no timing..? Please specify...
If you are running boost...good luck, I hate that class cause it will have 100 setup just for the software and the motor.
If you are running no timing...great. Max it to 20* (full right) and gear at 4.5 and check temp....I am sure you can keep gearing up til 4.0 or even higher, depends on the size of the track.
yep im drunning boost good only 100 setups should be quiet succesful for me then our track is large we run any where from 4.3-4.1 fdr
mattwoodcraft is offline   Reply With Quote
Old 10-12-2011, 01:39 AM   #8093
JRRobiso's Avatar
Exclamation
Flashing green LED @ neutral report.....changed sensor wire twice (brand new ones too) and still getting the same result. Current software I have is the default 090205MOD that came with my GT2.0 PRO, only thing that was changed on the profile was the AMTS set to 15 as suggested (by Solara).
Tried the other default MOD profiles (100528 and 110119) and the funny thing is.....I don't get the flashing green LED @ neutral anymore. Don't know why. Current motor I have is the Silver Arrow V2.0 5.5R and my lipo pack is a Gens Ace hardcase 7.4 2S 5000mah 40c.
Current MOD profile on my ESC is the 110119 that I will use when I go to the park bashing with my daughter later this week but need to know what to adjust so I don't blow up my ESC/MOTOR.
Thanks for any help you guys can provide.
Old 10-12-2011, 03:52 AM   #8094
sandrixx's Avatar
Default the real deal...
bradirs,, just want to know what is the real recommended gearing for competition 3.0 SP 13.5r and SP 10.5r motors?
thanks in advance!!
Team DogBone-Cobra/Serpent
Team F.R.E.A.K.S/SOLIDSNAKE_Saudi Arabia
Stay Serpent...
sandrixx is offline   Reply With Quote
Old 10-13-2011, 02:12 PM   #8095
Trader Rating: 84 (100%+)
Is there a way to reverse the motor rotation on the Silver Arrow 2 1/8th ESC without the programing box?
mike_d is offline   Reply With Quote
Old 10-13-2011, 02:59 PM   #8096
Nevermind i figured it out.
Old 10-13-2011, 03:04 PM   #8097
gom
I have a newb motor question I hope some one here can help me with. I am running a stock class with a 17.5 MMM motor at only 4.8 FDR. At the first 3 min of the race the car runs great. But the power starts to fade after the 3 min mark. It's not going extremely slow or anything like that. It's just lost the "bursty" feeling that it had at the start of the race.
I checked the temperature after the race it was around 140F. So I don't think it's overheating. I am using a 25c lipo battery and a tekin RS. both seems to be running at normal temperature.
I am not sure what is causing the loss of speed. And I can't begin to fix the problem without knowing what the problem is. I am not even sure if it is a motor issue. I am just trying my luck here on the SP forum. Anyone here has experienced similar situation?
Any advise would be greatly appreciated.
gom is offline   Reply With Quote
Old 10-13-2011, 04:14 PM   #8098
GCT69's Avatar
are all the cirtix speed control sensored?
GCT69 is offline   Reply With Quote
Old 10-13-2011, 05:50 PM   #8099
M-Technic's Avatar
Trader Rating: 15 (100%+)
How many mAh is your battery? I'd suspect its the voltage dropping on your battery causing the fade.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-13-2011, 10:19 PM   #8100
gom
It's a 3000mAh reedy wolfpack. Is that too low for a 17.5 stock class 6 minute main?
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
