Like Tree12Likes
Old 09-21-2009, 11:54 AM   #796
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by pmc View Post
Hello
wish is the specs of the speed passion Motor V3.0 9,5T RPM , Power and specific rpm/volt ??
Best regards:
Pedro Silva
I believe the spec sheet, attached to the following post in this thread contains the data you seek:
The Speed Passion Thread
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 09-21-2009, 01:16 PM   #797
pmc
Hello
thanks for the help.
Best regards.
Pedro silva
pmc is offline   Reply With Quote
Old 09-21-2009, 01:45 PM   #798
RonF's Avatar
Originally Posted by abailey21 View Post
I have run them, they're a good "sport" motor.
The exige 2.0 F1 sport tuned, is it roar legal? I cannot find a matching stock number to whats on roar 's site as of yet. I know they are 2800kv..
How does it stack up to the 17.5/21.5 from others? what does it compare to in brushed? 27 or 23T?
sorry for questions, Im only looking at it because it is sensorless, on the roar list and i want to run a CC sidewinder esc in F1 only...
Thanks..
RonF is offline   Reply With Quote
Old 09-21-2009, 02:31 PM   #799
TryHard's Avatar
abailey ygpm
TryHard is online now   Reply With Quote
Old 09-22-2009, 06:21 PM   #800
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
Can someone explain this for me?
I am running a 17.5 Fantom Ion motor the timing is at maximum (20deg). I also have a SP GT 2.0 with the latest software installed (again everything at the maximum settings).
I geared one tooth higher on the pinion so the FDR went from 3.84 down to 3.72. I was really expecting to overheat the motor, but not the case.
Not only did the car go much much faster, the unusual thing was the motor temp after the 5 min run dropped (was 167 F it dropped to 144 F).
So was I under geared initially?
r0adrunn3r is offline   Reply With Quote
Old 09-22-2009, 06:35 PM   #801
Trader Rating: 74 (100%+)
Well as I see it the brushless motor react the same undergeared as overheated. You need to find the "sweet spot" for your esc/motor/batt/style combo. I jumped 4 teeth this weekend from my normal ratio and the motor functioned as if it had nitrous and ran equally as cool. But if I was to go too far it would overheat as so would undergeared. So you need to experiment trackside. I hope this helps.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-22-2009, 07:32 PM   #802
r0adrunn3r's Avatar
Thanks for that
Old 09-22-2009, 08:32 PM   #803
cheehtae's Avatar
Trader Rating: 15 (100%+)
can you get an updated software to the GT version 1?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 09-23-2009, 06:05 AM   #804
abailey21's Avatar
Trader Rating: 36 (100%+)
Thanks..
It is not Roar legal, and it's supposed to be compatible to a 17.5 but i feel it's more like a 21.5
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-23-2009, 11:46 AM   #805
RonF's Avatar
Adam,
Thanks, if its closer to a 21.5 thats fine. Not looking for mega modified horsepower in a F1, just a good brushless equivelant to stock if the class goes that way.
Old 09-23-2009, 01:05 PM   #806
Adam, how long is the Version 3.0 can and how much do the connectors stick out normally. I am asking as I have a Team Magic car and space is critical as the motor is contained within the chassis. As always thanks for your help.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 09-23-2009, 06:42 PM   #807
cyanyde's Avatar
It sticks out by another 3-5mm from the end, depending on what gauge wire is soldered on. The motor itself is the same length as prevoius motors.
cyanyde is offline   Reply With Quote
Old 09-23-2009, 07:44 PM   #808
I just installed one V3 motor ( 4.5 ) at my e4fs .
No problem at all to install it .
Team Magic G4JS - Orion wasp .12 - Traxxas 4tec - O.S 18 tz
Team Magic E4FS - speed passion GT 2 pro - 4T ver 2 - 4.5T Ver 3
Kyosho spada 09 - Kyosho mini-z monster - Kyosho mini-z mr-02
memix is offline   Reply With Quote
Old 09-23-2009, 07:55 PM   #809
abailey21's Avatar
Thanks dude, the battery in my calipers died and I also forgot lol
K.C.C.O.
Old 09-23-2009, 07:57 PM   #810
I would like to say thanks to Speed Passion ( king Golden ) for there service.
They fixed my speed control , and shipped it back to me in a week ( i live in Greece , Speed Passion service is in Hong Kong ) with no charge at all.
I had a problem with the sensor cable and also the speed control wasnt doing any sound.
They replace the electronics from inside the esc ( gt2 pro ) and change also the bottom case ( clear one now ) and now i can see the red and green light very clear .
Also i would like to say thanks to Shawn and Adam for helping me ( Shawn forward my emails to Speed Passion ) .
By the way a tip to everyone , dont try to stop the car by putting your finger to the spur gear its painful .
I lost control of the car trying to set it up ( make a mistake at the settings ) and the car went full throttle. I tried to grab it and the middle finger of my right hand got stuck in the spur gear , nearly lost it . ( my finger not the car )
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
