Like Tree46Likes
Old 10-05-2011, 06:59 PM   #8026
Radio Active's Avatar
Can anyone give me a rule of thumb for gearing with the MMM in comparison to the V3 in non-boosted Stock? Last meet out with the V3 was on a very open offroad track and I was running 4.6 overall ratio in 4WD (motor came off at 70 degrees even). The car was quick, and a few guys even commented, but the two guys with the MMM had more speed.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 10-05-2011, 09:41 PM   #8027
peter george's Avatar
Trader Rating: 351 (100%+)
Originally Posted by peter george View Post
I downloaded the 323 on my lcd box, then proceeded to try and program the speedo. Now the green light keeps going on and beeping , cant re-calibrate or anything as soon as you turn on it starts flashing and beeping and holding the set button does nothing? Ever had this happen? And is there a quick fix?
I was lucky to find the answer so I will share with the thread in case someone else makes the same mistake. You gotta have the speedo plugged into a 2S lipo not a 1S. Thanks mohamoti you are a lifesaver.
I donít always talk smack but when I do itís 99% spot on
peter george is offline   Reply With Quote
Old 10-06-2011, 02:22 AM   #8028
Rouge711's Avatar
Hi guys, is there any other possibility replacing power caps with a smallest one? That 4 are very big. I saw Reihnard car with a smallest one.
Rouge711 is offline   Reply With Quote
Old 10-06-2011, 08:40 AM   #8029
Solara's Avatar
Trader Rating: 16 (100%+)
MMM is usually about 1T or 2T lower then V3...simply because MMM has a red 20* timing board...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-06-2011, 08:42 AM   #8030
Solara's Avatar
You can buy any kinda CAP that you want and solder it. Rheinard one is shorter but not smaller. pretty darn big and because he is running MOD. Depends on what you are running (motor vise) and we have several caps for you to choose from.
Old 10-06-2011, 09:27 AM   #8031
Rouge711's Avatar
Thank you for replying.
I run mod from 4.5 to 6.5
I would like to save space on my car not decrease power cap function.
Do you mondo suggest me any cod or if it is possible Reihnard's one cod?
Thanks!
Old 10-06-2011, 10:07 AM   #8032
Solara's Avatar
Thanks!
This is what MARC using.
http://www.amazon.com/2200uf-Capacit...=2GIMS3GKMGHL9
Old 10-06-2011, 10:09 AM   #8033
Originally Posted by Solara View Post
AWSOME i will get one for my 1/12th scale make the car lighter and better in balance PHEW
Thanks Solara
sidecarphil1 is offline   Reply With Quote
Old 10-06-2011, 10:12 AM   #8034
Solara's Avatar
Thanks Solara
Come on...I expected you have that extra CELL long time ago...now, go do some BOOST 3.5 racing...
Old 10-06-2011, 10:22 AM   #8035
noooo i am not so good with 1/12th , will do 13.5 with boost set up
Any good set ups for the GT2.0 and 13.5v3 motor 1s ???
Old 10-07-2011, 06:05 AM   #8036
Trader Rating: 18 (100%+)
Sorry guys, wrong thread for my questions!
KSimmonds is offline   Reply With Quote
Old 10-07-2011, 06:58 AM   #8037
Try my 1s setup on the SP website. It is with a 13.5mmm with a 10 degree board. With the v3 motor go 1 to 2 teeth more.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 10-07-2011, 07:49 AM   #8038
Solara's Avatar
Thanks....I will do some 12th scale this winter, but will probably run no boost with cirtix club spec. Try to create a cheap class for the 12th scale. I think cirtix with 10.5 V2 is the way to go.
Old 10-07-2011, 09:32 AM   #8039
We bounce back and forth from 13.5 boosted and 13.5 blinky 12th scale. We have handful of guys that go to the big races. We have a 17.5 blinky 12th scale also.
I ran 17.5 blinky last night. WOW was that slow after running 13.5 boosted.
Steve Walter
Old 10-07-2011, 09:51 AM   #8040
Trader Rating: 14 (100%+)
Will the LCD boxes be able to work with the cirtix stock club soon???
DuckStang is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
