Like Tree46Likes
Old 09-30-2011, 07:10 AM   #7996
Originally Posted by M-Technic View Post
Which software do people run for boosted mod? I am going to be running a 5.5 and want to run boost, it's been a while since I ran an SP speedo so I am out of the loop. I've got a 2.0 Pro in the mail.
323Stock - even for mod motors. Of course using less timing as in stock classes. A setup for a boosted 4.5T was posted some pages back.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-30-2011, 08:40 AM   #7997
Originally Posted by Solara View Post
If you are going IIC...talk to BILL SYDOR or JJ Wang...but I can tell you this. Bill is very fast with 323stock 17.5 class (boost 17.5) and his FDR is about 6.9 for indoor carpet. I really cannot see running 10+ final is the answer. I will believe that is a BOOST setup with 3.5T motor final drive.
What is your 323stock setup...?
About timing board in the motor...the V3 came standard 10 board. MMM came standard with 20 board. It is not the option, those are standard, and I always run 10 back then when 20 and 30* were not even the option...Now, I think my latest setup (carpet season just started and there are no BOOST class no more) was about 22. And no...you don't run minimum motor timing, nor run MAX motor timing...is depends on track size, and esc setup.
If your temp is 115 after 5 minutes running BOOST class...there must be something wrong there. Don't get me wrong...I WISH we are all getting only 115 running boost class and be fast...but we are all reaching 180-190 almost to the line that will blow up the motor in order to be fast....115 is just way too good to be true (that still be fast).
Your MMM getting hot is because the board inside (RED BOARD) is 10 plus degree more then the black V3 board (which is only 10 max)...you max out the MMM, that is 20 timing....if your ESC setting does not change, of course it will get hotter because you are simply adding 10+ then your V3 setup.
Also...if you are running MMM 17.5 for blinky class.....your 4.1 final is about right. Make sure you use the green sensor board and crank to full right 30. You might need to gear up 1 or 2 tooth...again, talk to BILL SYDOR, he was TQ last year at IIC for stock 17.5.
And ask him about superstock 17.5...and have him to look at your 323stock setting...I think there must be something you did that is completely different then what we used for boosted 17.5....10.4 final is just crazy.
Good luck at IIC...
Sorry for the confusion. What I meant to say by 10 degree upgrade is that I put the red board in my original V3.0.
I don't have a green board so I might be stuck with what I have on my stock MMM.
I admit that the 115 degree is great however I also have a high powered fan and a heatsink on the motor. The MMM with higher timing(was running it turned to maximum compared to the v3.0 with red board in the middle) lost power.
When I ran Tekin motor/esc I was running around a 7:1 ratio for the identical track. When I ran that with the speed passion motor/esc I couldn't get the acceleration needed. When I geared to the 10:1 ratio though the torque is spectacular and then I have the boost take me down the straight.
When I ran around the 7:1 ratio the temperature was around 80degrees. I had no low end and little top end because the motor took too long to spool up.
When you guys run such high temperatures are you losing power during the run?
Lap time wise I would say it was only a tenth of a second however my finger could feel it.
As for settings on my boost 17.5 this is what I run going by memory -
4 DRSS, 45 boost timing, 0 drag break, max break 62.5%, turbo timing 30, boost start 2000 rpm(I had it at 1000 for the V3.0), turbo delay .1s, boost timing acceleration 300(not 100% sure).
I've never run brushless motors as hot as you describe however I also think the carpet track we have being 60'x48' is quite a bit smaller so that might have something to do with it. I aim for around 140-150 degrees with a fan.
If I ran without a fan/heatsink though I definitely would be at the temperatures you mention.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 09-30-2011, 09:55 AM   #7998
M-Technic's Avatar
Trader Rating: 15 (100%+)
The setup Solara posted was for 205 software with no boost. Unless I missed the one you are speaking off.
For some reason I thought 323 was blinky only software. I will make sure I get that loaded up. Last time I ran SP it was with 528Stock software.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-30-2011, 10:05 AM   #7999
It was not posted by Solara - it was posted by sidecarphil1. It's here.
Niklas Hansen
Old 09-30-2011, 10:47 AM   #8000
Joel Lagace's Avatar
the zoof... Sure your not using eddies temp gun set on Celsius?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-30-2011, 11:47 AM   #8001
Yup I am sure... using my own temp gun.
Michael Zufelt
Old 09-30-2011, 12:10 PM   #8002
Well its broken then! LOL My shorts where 80F on sunday.. a ")
www.rcottawa.com
Old 09-30-2011, 12:22 PM   #8003
M-Technic's Avatar
Thanks!
Old 09-30-2011, 02:33 PM   #8004
Solara's Avatar
Trader Rating: 16 (100%+)
Small amount of GT2 PRO and GT2 LPF are back in stock at SP web.....get it before they are gone again.
http://www.speedpassion.net/us/index.asp
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-30-2011, 05:16 PM   #8005
Eddie M's Avatar
I set you ESC to the following setup http://www.speedpassion.net/uploadfi...Harbor_JAS.pdf
It was what I use for our last 2 outdoor season and it work great for our outdoor track. I use the same setup but use th 9.52 FDR for out indoor race because I am unsure what is the proper gearing for our (a lot smaller) indoor track. It turn out it run great. Has lot of low end power and get the top end with the turbo at the same time.
Eddie M is offline   Reply With Quote
Old 10-02-2011, 04:58 PM   #8006
Suspended
Trader Rating: 86 (100%+)
how do you guys like your new mmm motors?
good punch and top end? hotter or colder compare with other v3 for same setups?
RELIABLE?
is it any good for 1/12 scale?
littlealex is offline   Reply With Quote
Old 10-02-2011, 07:13 PM   #8007
mr crum's Avatar
Send a message via Yahoo to mr crum
good luck at vegas teamates that are going
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-02-2011, 07:24 PM   #8008
poochy's Avatar
where in the U.S. can i order the green sensor unit for the new MMM?
poochy is offline   Reply With Quote
Old 10-02-2011, 09:00 PM   #8009
zipperfoot's Avatar
[QUOTE=zipperfoot;9708414]OK give you a week...
You will be back in stock on "SOME GT ESC"? What if I were to buy one and had a problem? Would it take months to get a replacement? What is the reason for the short supply?
I want to give the benefit of the doubt SP, and try something I have not used before, but at what cost.
Xx
zipperfoot is offline   Reply With Quote
Old 10-03-2011, 12:31 AM   #8010
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
To ALL SP drivers going to IIC, in case you didn't get the Team Email, on Wednesday, all us SP drivers will be wearing our SP shirts so we cna identify each other and take a SpeedPassion Team Picture. Im looking forward to seeing familiar team members as well as new team members. Best of Luck team!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
