Like Tree46Likes
Old 09-27-2011, 11:17 AM   #7936
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by tr1kstanc3 View Post
Looking at getting a Speed Passion 4.0R motor for speed runs up and down my street. Car will be an Xray T2 with a Novak GTB speed controller. What would be a good starting FDR?
I was thinking 8.5-9.0
Do not plan on racing this kit.
Thanks!
If you are not racing it, just drag racing for a very short period of time per run...I think you can gear more. 8.5 final with 4T is very much what I use for racing on track. If I do drag race...I will put more gears on it.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-27-2011, 11:19 AM   #7937
Solara's Avatar
Originally Posted by jsinclair View Post
I'm going to be racing a blinkey 17.5 1s "stock" class this winter where can I find more info on this http://www.speedpassion.net/us/produ...SP000053&c=CMB
What kinda information that you want to see..?
Old 09-27-2011, 11:31 AM   #7938
Solara's Avatar
Originally Posted by zipperfoot View Post
OK give you a week...
You will be back in stock on "SOME GT ESC"? What if I were to buy one and had a problem? Would it take months to get a replacement? What is the reason for the short supply?
I want to give the benefit of the doubt SP, and try something I have not used before, but at what cost?
1. Give us more then a week now...we have to fulfill all of our dealers in USA first (like A-main, stormer...etc) before we can supply for online customer. So please check with big online shop or your local hobby shop FIRST before checking us online. Especially all the GT series ESC. They are on high demand....
2. All of our MOTOR and ESC has 30 and 90 days warranty...all of our warranty item will be shipped from USA...UNLESS they are out of stock. We replace only NEW warranty products. We don't really fix the broken item within the warranty period, we simply replaced the same item to our customer within a reasonable time. And of course, if you overheated your motor, plug the +/- at the wrong side for your ESC, those are not under the warranty terms and will not be covered.
Like I mentioned, we supply to our US dealer, our sponsored drivers, then we will have them available on our direct sale site. The quantity are very limited. And our motor and esc sells thru out the world...countries like Germany (3-500 orders), UK (3-500 orders) and Japan (2-400) demand the most of the GT ESC and motors....US, on the other hand, only demand stock ESC and motors...our inventory are usually "enough" to supply for dealers, drivers and other online customer. So once they are online...you should pick them up before they are all gone. And they are usually out of stock within week.
Old 09-27-2011, 11:36 AM   #7939
Solara's Avatar
Originally Posted by Blitzrockey View Post
Does anyone have a good setting, for a wgt 13.5 1cell boosted, on a med carpet track? Just looking at what esc settings would work best. thanks.
Not the latest boost software...but should give you a good start...
http://www.speedpassion.net/uploadfi...rCarpet_hl.pdf
Old 09-27-2011, 11:38 AM   #7940
Solara's Avatar
Originally Posted by BoneCrusher View Post
Downloaded the 323 stock software.
Help please for 13.5 TC boosted setup. I have seen Jimmy's 17.5 setup. Would I just try this setup but say change the FDR to something like 7.5 for indoor carpet 36x80 med/high grip carpet?
Thanks,
Ivan
Try Jimmy's setup first...then compare with mine.
http://www.speedpassion.net/uploadfi...Howard%20L.jpg
Old 09-27-2011, 12:06 PM   #7941
Hey all!
I am new to the Speed Passion family. I did my second race with 17.5 boosted and finally got some performance.
The first race was terrible as I couldn't get any speed out of the car. It turned out that it seems I was geared incorrectly.
Originally I had a ratio of 6.5.
Now 10.4.
The track is 60' x 48'.
Now the good news is I am getting power from my car. The problem is I seem to loose power on my MMM motor about 3 minutes into the run. The temperature is at about 150 after I check it so most likely over heating.
My question is regarding timing on the physical motor... should I be putting the timing as low as possible since the speedo does all the boost? I also am curious about the MMM for 17.5 boosted class. Would it not be better to use my older lower timing motor for more torque?
If I decrease the timing on the motor it should give more low end power and less heat. The top end should be similar if I increase the boost settings on the esc?
What do you think... ?
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 09-27-2011, 12:38 PM   #7942
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Hmm that wont open ?
Blitzrockey is offline   Reply With Quote
Old 09-27-2011, 12:46 PM   #7943
Solara's Avatar
Me open....try 1/12th setup on the SP website. Under Harrold McDonald...
Old 09-27-2011, 12:48 PM   #7944
Solara's Avatar
Originally Posted by TheZoof View Post
Hey all!
Now 10.4.
I have never seen anyone run 10.4 final drive on on road especially in stock...that is like an off road 1/8th buggy in MOD final drive. Are you sure the 10.4 final is correct..? If so...you are way way way way way way way undergear.
Old 09-27-2011, 01:37 PM   #7945
That was my thinking too until I did the testing. If I ran my original v.3.0(with 10degree upgrade) Speed passion motor with the 10.4 ratio everything was awesome. It is a 417 car with 113 spur, 21t pinion... (113/21)*1.94=10.439. Temp was about 115 after 5 minutes.
If I run the new MMM with the same gearing of 10.4 then I see the heat issue. The only difference I can see is that I had my MMM turned to highest possible timing.
I even have the 10degree board in my v3.0 original.
My car was the fastest on the straight and had decent bottom end. In fact I was thinking of going to a ratio closer to 11 for next race.
I tried 7:1, 8:1 and 9:1... all of them lacked power and speed on our carpet track. The 10.4:1 was the best by far. My lap time is about 1 second difference from 6.5:1 compared with 10.4:1... my driving line was the same.
>.. Anyways... I am just curious about timing of motors... do people run them lowest timing possible on motor... or highest and why. I obviously will try it out next time however I am going to IIC so I just wanted people's input.
Also FYI, I run a ratio of 4.1:1 without boost and at IIC I will definitely run at least an 8:1 ratio to start for 17.5 boosted due to the larger track.
Michael Zufelt
Old 09-27-2011, 02:14 PM   #7946
One other question I had is due to this ratio my car has a lot of built in drag break. Does speed passion offer any push control type setting to counter that issue?
Michael Zufelt
Old 09-27-2011, 02:35 PM   #7947
Default Inspire V2
I am still confused as to if the Inspire V2 can support sensored motor? I don't see where you would plug the sensor wire into the esc? But someone posted on here that it support both sensor and sensorless?
Can someone chime in on this?
TIA,
Ron
syrss is offline   Reply With Quote
Old 09-27-2011, 02:43 PM   #7948
M-Technic's Avatar
Trader Rating: 15 (100%+)
10.4 FDR in 17.5, now that is crazy. When I used to run the SP 2.1 in boosted 17.5, I ran a 4.8-5.3 FDR! That was with the 528 software, I don't know if there is a new version out. I think you went in the wrong direction with the gearing if you started with a 6.5 FDR and couldn't get any speed out of the car. 150* F is not overheating a motor, you should not have any fade at those temps.
I'm excited to be running an SP speedo again soon. Running mod this season so I just ordered a GT 2.0 Pro to replace my Tekin.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-27-2011, 03:01 PM   #7949
jsinclair's Avatar
Does it have a booster for 1s? Does it have a lvc for 1s? What other battery does it support? Thanks;
Josh
jsinclair is offline   Reply With Quote
Old 09-27-2011, 04:49 PM   #7950
Trader Rating: 84 (100%+)
Hi i just recently purchased a couple of 1/8th scale Speed Passion Silver Arrow v.2 speed controls and am wondering which programing box i should purchase to use with these?
This one.
http://www.amainhobbies.com/product_...Programing-Box
Or this one.
mike_d is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
