Like Tree46Likes
Old 09-26-2011, 03:18 PM   #7921
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Originally Posted by M-Technic View Post
Can anybody please point me to a shop that has the GT 2.0 Pro in stock? Preferably in silver, and preferably in the USA if possible, but I don't mind ordering from overseas.
here you go...i got my blue one from here also: https://www.ssl-stormerhobbies.com/c...=SPR98802PROCS
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-26-2011, 04:10 PM   #7922
wandiez1019's Avatar
Originally Posted by g12314 View Post
You are overgeared for the track size and have too much timing being applied too quickly. These will cause the excessive motor temperature reading you are getting.
I would suggest the following:
FDR range: 7.5 for starting point.
ESC Settings:
9 . 35
10 . 6
12 . 18
13 . 5000
14 . 0.1 sec
15 . 600
Jimmy
i'll try this set up and i'll post back the result.i'll keep the endbell for 20' for now coz i've felt the power before n kinda like it.......thanks a lot jimmy
wandiez1019 is offline   Reply With Quote
Old 09-26-2011, 07:17 PM   #7923
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Looking at getting a Speed Passion 4.0R motor for speed runs up and down my street. Car will be an Xray T2 with a Novak GTB speed controller. What would be a good starting FDR?
I was thinking 8.5-9.0
Do not plan on racing this kit.
Thanks!
tr1kstanc3 is offline   Reply With Quote
Old 09-26-2011, 07:18 PM   #7924
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks a bunch!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-26-2011, 07:21 PM   #7925
jrz93's Avatar
when will the 2.1 be off backorder already???????
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 09-26-2011, 08:28 PM   #7926
jsinclair's Avatar
I'm going to be racing a blinkey 17.5 1s "stock" class this winter where can I find more info on this http://www.speedpassion.net/us/produ...SP000053&c=CMB
jsinclair is offline   Reply With Quote
Old 09-26-2011, 11:34 PM   #7927
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Solara View Post
Give us a week or so....we are slowly back in stock on some GT ESC.
OK give you a week...
You will be back in stock on "SOME GT ESC"? What if I were to buy one and had a problem? Would it take months to get a replacement? What is the reason for the short supply?
I want to give the benefit of the doubt SP, and try something I have not used before, but at what cost?
zipperfoot is offline   Reply With Quote
Old 09-27-2011, 12:48 AM   #7928
ESC Settings:
9 . 35
10 . 6
12 . 18
13 . 5000
14 . 0.1 sec
15 . 600
Jimmy
hai jimmy....test drive the car today with the fdr that u suggest and esc setting.....finally i come up with this...
track temp 47'c
fdr 7.0
esc setting
4 . 8
9 . 36
10 . 12
12 . 20
13 . 6000
14 . 0.1 sec
15 . 700
after two minute run temp is 78'c.....car was good on both acc and top end...got the fast lap today then the last time.
is this range of temp would be ok? if it is ok....so i stick with this set up...and i would like to thank you again jimmy.....long live speed passion.....
Old 09-27-2011, 02:59 AM   #7929
You will be back in stock on "SOME GT ESC"? What if I were to buy one and had a problem? Would it take months to get a replacement? What is the reason for the short supply?They're always out of stock because they're so darn good and sell out very quick when new stock comes in
I want to give the benefit of the doubt SP, and try something I have not used before, but at what cost?You'll have no problems with SP. I changed from LRP and havent looked back except to see how far behind me they are
Bumpy is offline   Reply With Quote
Old 09-27-2011, 04:42 AM   #7930
J SiN's Avatar
Originally Posted by J SiN View Post
what size bearings do the V3 21.5t motors use?
my new motor has a dead bearing after 1 race meeting
Anyone at all knows?
I don't have anything t check the size with.
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 09-27-2011, 06:59 AM   #7931
Default help with motor heat
Can any one help me solve a motor heat issue.
I have a T3'11 built and set to kit setup which works really well for grip and balance. I am using the Speed Passion GT2.1 with Sp21.5tMMM - 6200mAh 60C.
I run @ Boronia rc club and @ dandenong, both in Australia.
Boronia is a small to med track with low to medium grip.
I tend to run with a FDR 5.7 - 6.2,(23-27pinion / 81-83spur) .
The prob is, unless I back the speedy right way off, I get major 95 - 100 C heat, or max speedy out and drop FDR and the car is as slow as a stock 540.
Does anyone have a suggestion on a good balance to run speedy and FDR.
any help would be muchly appreciated.
Schumacher Mi3.5 / Mi4LP - Xray T3'11 - Venom Crawler Venom GPV-1 - Anderson M5 cross - Tamtech Mini Fox Tamiya Gravel Hound - Tamiya Buggy Champ -
Speed Passion 21.5/17.5/10.5/13.5BL
Medivac Heli - E-flite MSR - Marui BIGBEAR
R.A.B. Hobbies - The Hobbyman
Faulty is offline   Reply With Quote
Old 09-27-2011, 08:30 AM   #7932
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
track temp 47'c
fdr 7.0
esc setting
4 . 8
9 . 36
10 . 12
12 . 20
13 . 6000
14 . 0.1 sec
15 . 700
You motor temp is the maximum I would run in boosted applications. If you are not running a fan on the motor, you should consider adding one. If you are already running a fan and like the ESC / Gearing feel you can try these things to slightly reduce the motor temperature:
1) Change #4 setting to 6
2) Reduce the physical motor timing (put sensor in the middle and adjust up from there).
3) Change #10 setting from 12 to 6
4) Change #14 setting to 0.2sec
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 09-27-2011, 08:55 AM   #7933
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Does anyone have a good setting, for a wgt 13.5 1cell boosted, on a med carpet track? Just looking at what esc settings would work best. thanks.
Blitzrockey is offline   Reply With Quote
Old 09-27-2011, 10:03 AM   #7934
BoneCrusher's Avatar
Downloaded the 323 stock software.
Help please for 13.5 TC boosted setup. I have seen Jimmy's 17.5 setup. Would I just try this setup but say change the FDR to something like 7.5 for indoor carpet 36x80 med/high grip carpet?
Thanks,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-27-2011, 11:52 AM   #7935
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Thanks,
Ivan
Hey Ivan
what's your silver can set up gearing home track for GT?
OVA is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
