Like Tree12Likes
Old 09-13-2011, 07:55 PM   #7891
Suspended
Trader Rating: 86 (100%+)
Originally Posted by eComet View Post
I have the MMM 17.5R with green +20 sensor board at +10 max (total of +30 degrees). I ran anywhere between 4.2 to 4.4 depending on how technical the track is. My temperature is around 150-160 at the case.
Comparing to my older V3 17.5R, the MMM runs at about 10-20% higher rpm for the same physical timing setting.
full 30 degree? do you feel you want more endbell timing?
this is the track i m running.
http://www.youtube.com/watch?v=MAmpy...OHx-CY7OjQ02fQ
btw thanks for the info
littlealex is offline   Reply With Quote
Old 09-13-2011, 10:15 PM   #7892
Trader Rating: 69 (100%+)
For non-boosted 17.5 class, people usually run at the max allowable timing and adjust gear ratio according to keep temperature down. Higher timing develops more overall power regardless.
I run at TQ RC, small indoor carpet track. Even with our small techncal track, every fast guys are running very high physical timing.
+ YouTube Video
Your track is meant for high speed nitro so you should go to the max timing possible.
eComet is offline   Reply With Quote
Old 09-14-2011, 06:34 PM   #7893
Suspended
thanks for the info ecomet
Old 09-14-2011, 08:00 PM   #7894
skypilot's Avatar
Trader Rating: 14 (100%+)
+ YouTube Video
uum... wonder why that layout looks familar
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-15-2011, 05:03 AM   #7895
mattwoodcraft's Avatar
i like the look of the track, have not raced on carpet for long time
mattwoodcraft is offline   Reply With Quote
Old 09-15-2011, 05:16 AM   #7896
will the 10.5r 1 cell although it says 1 cell be okay in F1 car ? i looked the instruction and it says 2 cell aswell so it can handle 7.4v ?
Old 09-15-2011, 03:46 PM   #7897
Mxer59's Avatar
Trader Rating: 114 (100%+)
What speed passion 17.5 motor should I get for a 4x4 slash
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 09-15-2011, 04:17 PM   #7898
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the 1 cell motors are what i have been using Matt. so yes they are more than capable to run 2S
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-16-2011, 04:02 AM   #7899
thanks for the info patto so your s411 3.5 was 1 cell ?
im impressed oneday i may know your secrets asking the rite questions
Old 09-16-2011, 04:54 AM   #7900
Pattojnr's Avatar
Matt, i dont have secrets. car setup, well that is on Serpent site. all my speedy settings, and FDR , i have said previously. the one day i run 2 cars, am crook as, and tired to match, was a day where everyone wanted to know stuff. i pulled out of my 8th class, as i was crook. but any other day, i will answer any question, just not for Xray drivers.
Yes, my 3.5T was a 1 cell. iget to try my MMM if the rain stays away sunday. but i will be tryign new things as far as power is concerned. i wont say too much for now, but if i get it to work, then im sure Solara is keen to know also. lets say im hoping its wheelie popping material.
Serpent - Walter RC
Old 09-16-2011, 05:07 AM   #7901
i have just bought a 1 cell to try are they smoother than using the others is this why you use them, i like the price..
i agree its hard to concentrate when your brook and trying to run 2 classes i have enough trouble doing my TC and F1 i could imagine the 8th scale needing even more the speeds are mad
Old 09-16-2011, 05:54 AM   #7902
Pattojnr's Avatar
they are lighter, and i feel they have better brakes, and overall power .
Serpent - Walter RC
Old 09-16-2011, 09:48 AM   #7903
Solara's Avatar
Trader Rating: 16 (100%+)
Try MMM first...otherwise, any V3 or 1S will work...but I will stick with MMM.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-21-2011, 02:04 PM   #7904
Solara's Avatar
Thank you STEVE for the 323stock setup for 12th scale with 13.5T stock motor...
http://www.speedpassion.net/uploadfi...e%20Walter.pdf
Thank you Rob King for the 323stock setup for DIRT OVAL with 6.5T mod motor.
http://www.speedpassion.net/uploadfi...Rob%20King.pdf
Old 09-21-2011, 02:05 PM   #7905
Solara's Avatar
How was the 323stock with 3.5TMMM motor testing...? What blows up?
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
