Like Tree9Likes
Old 09-11-2011, 07:35 PM   #7876
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Originally Posted by defcone View Post
You need to calibrate everytime you change software.
What if I make a change like timing do i still need to ? Or just when uploading a complete new softwear program onto it.
Also how do I do it with a cut off switch lol ?
Blitzrockey is offline   Reply With Quote
Old 09-11-2011, 07:48 PM   #7877
defcone's Avatar
Trader Rating: 15 (100%+)
You don't have to when you change a setting, well obviously you can't if you chopped the switch off. You can take apart the casing of both the swtich and esc and solder a new wire on.
defcone is offline   Reply With Quote
Old 09-11-2011, 10:12 PM   #7878
Suspended
Trader Rating: 86 (100%+)
anyone have good gear ratio and timing for tekin rs and v3 17.5t stock no boost class for touring in 120 feet straight track?
littlealex is offline   Reply With Quote
Old 09-12-2011, 05:09 AM   #7879
mattwoodcraft's Avatar
if putting the +10 in my 17.5 V3 should i be treating it the same as my MMM by dropping a few teeth on the pinion
mattwoodcraft is offline   Reply With Quote
Old 09-12-2011, 09:08 AM   #7880
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Gyr0 View Post
Yeah that's what I figured, thanks. OH well it happens, so does anyone know if speedpassion fixes these (not for free obviously) and for how much? Or am I better off buying a new one? Looked so nice in my blitz too!!! Back to using the gtb for now.
Give SP USA office a call....Phone 1-888-928-1328
Let them know what you did and we will have some kinda plan for you to get that ESC updated/fixed with a fee. I assumed you are in USA area.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-12-2011, 09:11 AM   #7881
Solara's Avatar
Do you need to recalibrate it each time you change a setting on it? Because I had to cut my swtich and wire it together as it kept failing. The white wire is just free now, so even if I had to do the calibration i wouldnt know how to now that the switch is cut off?
Call our office....Phone 1-888-928-1328, you can purchase a new switch and we can ship to Cananda for you....you can then solder that back to your ESC and do all the things that it suppose to do instead of what you did to the switch.
Since you are NOT changing software...you DO NOT need to calibrate each time after you changed the SETTING......you DO, need to calibrate, ONLY if you changed your software...which I doubt you can or you want to do it now, because you will not be able to without the switch.
Old 09-12-2011, 09:13 AM   #7882
Solara's Avatar
4.0 with full timing on right 10°.........I think you can gear higher then that but check the motor temp and gear accordingly.
Old 09-12-2011, 09:15 AM   #7883
Solara's Avatar
No...different motor internal..I think you should use the same gearing as your MMM when running V3 with full right 10° timing and give that a try. Again, 5 laps is all you need...then check motor temp and feel.
I hope you are running no timing....
Old 09-12-2011, 11:11 AM   #7884
Trader Rating: 20 (100%+)
Thanks for the info! Man 60 days is a long and grueling wait! Gonna have to decide what I wanna do
Gyr0 is offline   Reply With Quote
Old 09-12-2011, 11:40 AM   #7885
Thanks hey. I have the old switch im just gong to pull it apart and clean it and check it I have the mod softwear on it which is all I wanna run with the esc anyway, but If I do need to calibrate it I will put the switch back on to do so. Thanks.
Old 09-12-2011, 05:13 PM   #7886
Suspended
i also bought new mmm 17.5 motor with 30 degree green sensor. is gearing same with more timing on endbell?
Old 09-12-2011, 05:45 PM   #7887
Trader Rating: 69 (100%+)
I have the MMM 17.5R with green +20 sensor board at +10 max (total of +30 degrees). I ran anywhere between 4.2 to 4.4 depending on how technical the track is. My temperature is around 150-160 at the case.
Comparing to my older V3 17.5R, the MMM runs at about 10-20% higher rpm for the same physical timing setting.
eComet is offline   Reply With Quote
Old 09-12-2011, 10:24 PM   #7888
BoneCrusher's Avatar
Just getting back into the indoor season soon. I have a GT2.1 Prostock that I ran in 13.5 boosted class. I haven’t touched for like 6 months. Could someone tell me if there is new software to download, best settings for 13.5 boosted, FDR and what motor you guys are using now?
Thanks,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-13-2011, 04:43 AM   #7889
Originally Posted by Bumpy View Post
Hey all. Im looking for a starting point for 21.5 with open esc in tc. I will be running outdoor low-med grip asphalt medium sized semi tech track 60mtr back straight. Running a 417 with SP GT2.1 pro stock esc and Sp 21.5 1 cell motor. Any info appreciated.
Bump. Anyone able to share some info on a possible setup?
Bumpy is offline   Reply With Quote
Old 09-13-2011, 10:18 AM   #7890
Does anyone have a good setup for a 10r5 boosted 13.5 on 1cell wgt, with the gt pro 2.0. Thanks.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
