Like Tree3Likes
Old 09-08-2011, 09:21 AM   #7861
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mxer59 View Post
Is the short course Esc a good one for a 4x4 slash or nexx 10
What's the best speed passion Esc for a 4x4 truck
I would use the SP GT2.0 PRO....that is what I am running on my SLASH 4x4 with 7.5, along with others on Durango, Losi Ten and AE 4x4.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-08-2011, 09:22 AM   #7862
Solara's Avatar
Originally Posted by TheZoof View Post
Hey all!
Going indoor carpet racing for the first time with my speed passion pro esc! I was running a 3.5T outdoors however now going to a 17.5 Boosted for indoors(that's the rules).
Anyways... any starting setup for Speed Passion Pro and approx gearing? The track is 80'x60'.
Running Touring car(417), with V3 SP 17.5 and rubber tires.
Thanks!
http://www.speedpassion.net/us/escsetup.asp
Check those out...alot of setup there.
Old 09-08-2011, 09:23 AM   #7863
Solara's Avatar
Originally Posted by ruebiracer View Post
Hi guys,
I just grabbed a used Speed Passion GT2.1 Pro Stock ESC,
and want tu use it for a no boost 17,5t Race.
What I already learned here is that I need the "508" Software or program!?
But where do I get it on the website, or is it already on the esc?
And I need the programm card with 2 LCD lines as Transmitter to the computer, as I read here?!
Sorry for this silly questions, but itīs my first time connecting an esc with a computer.
So,
if anyone has a actual "how to" for me, would be great, as there are different communication softwares and so on.
I donīt want to run without sensor cable, but sensored with no boost as with the cirtix combo...
Thanks in advance,
Matthias
Everything you asked....are included in this video.
+ YouTube Video
Old 09-08-2011, 09:25 AM   #7864
Solara's Avatar
Originally Posted by swimbikerun View Post
When are the GT 2.1 EX back in stock on speedpassion.net for North America? Looks like most esc's are out of stock. Thanks.
End of September...I was told.
Old 09-09-2011, 06:26 PM   #7865
Default 21.5 starting point
Hey all. Im looking for a starting point for 21.5 with open esc in tc. I will be running outdoor low-med grip asphalt medium sized semi tech track 60mtr back straight. Running a 417 with SP GT2.1 pro stock esc and Sp 21.5 1 cell motor. Any info appreciated.
Bumpy is offline   Reply With Quote
Old 09-10-2011, 06:00 AM   #7866
Jack2's Avatar
Hi,
I have been running a 13.5 V3.0, which I like, just bought a 13.5 MMM I see it has more static timing adjustment and claims to be slightly more powerful through-out the whole power band, just wondering about gearing and esc setup.
I was planning to set the timing to 15 degrees on the motor and gear it the same and my v3 and up the static timing first before I touch the esc setup as its pretty sweet with the v3.
can anyone tell me if they have found they need to gear it any different?
Cheers, Jack
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 09-10-2011, 05:31 PM   #7867
Trader Rating: 20 (100%+)
So I picked up a gt2.1 prostock to run in my shortcourse truck, soldered it on mounted it up and all was gravy. Along comes my bro who is oblivious to r/c and reversed the connecters on the battery and plugged it and bam, sparks flew. No smoke or funky smells really, and the spark wasn't intense.
Is there a way to figure out if the esc is damaged or should I just go ahead and assume damage was done?
Turns on fine, calibrates, and I even used the supplied program card and stuff was saved properly. One problem that occured is that when I would start turning the throttle would shut off? Should I write that down as damage done from reversing the polarity?
Gyr0 is offline   Reply With Quote
Old 09-10-2011, 08:43 PM   #7868
Mxer59's Avatar
Trader Rating: 114 (100%+)
That's a really weird issue is everything in your receiver plugged in properly?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 09-10-2011, 09:49 PM   #7869
Yeah triple checked everything, recalibrated about twice, even switched the profile to smooth. Then I thought well maybe the servo is drawing to much juice, threw a capacitor on the receiver and still nothing, same problem. Went to retry it out in the driveway and seems to glitch up when I hit full throttle as opposed to steering
Old 09-10-2011, 09:50 PM   #7870
Yeah triple checked everything, recalibrated about twice, even switched the profile to smooth. Then I thought well maybe the servo is drawing to much juice, threw a capacitor on the receiver and still nothing, same problem. Went to retry it out in the driveway and seems to glitch up when I hit full throttle as opposed to steering.
Old 09-11-2011, 05:50 AM   #7871
Vicko's Avatar
Trader Rating: 14 (100%+)
Try an new receiver and see if that fix it
Vicko is offline   Reply With Quote
Old 09-11-2011, 07:38 AM   #7872
If you have reversed the polatity it is ruined , maybe not 100% now but it will stop soon , i had one did the same and it failed full throttle on the 60m straight running a 10.5 with timing , made a real mess of my TRF !!!!
Lesson learned !!!!!
sidecarphil1 is offline   Reply With Quote
Old 09-11-2011, 08:54 AM   #7873
Yeah that's what I figured, thanks. OH well it happens, so does anyone know if speedpassion fixes these (not for free obviously) and for how much? Or am I better off buying a new one? Looked so nice in my blitz too!!! Back to using the gtb for now.
Old 09-11-2011, 04:41 PM   #7874
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Do you need to recalibrate it each time you change a setting on it? Because I had to cut my swtich and wire it together as it kept failing. The white wire is just free now, so even if I had to do the calibration i wouldnt know how to now that the switch is cut off?
Blitzrockey is offline   Reply With Quote
Old 09-11-2011, 07:28 PM   #7875
defcone's Avatar
Trader Rating: 15 (100%+)
You need to calibrate everytime you change software.
defcone is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
