Like Tree3Likes
Old 08-26-2011, 10:19 PM   #7771
LonnyJ1950's Avatar
Don't know if I had a dodgy push button, or weak fingers due to my advanced years, but I couldn't get mine going. A super firm push on the set button put things right. Now SP and KO working beautifully together.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 08-27-2011, 04:43 AM   #7772
Trader Rating: 22 (100%+)
Originally Posted by bjspinner View Post
I am after some advice on changing from a 13.5 ver3 to the 13.5 MMM.
As the MMM has more timming and I run 0 timming on the ver3, what is the best way to tune to the latest software.
With 10deg more timming am I better to wipe 10 off boost timming or 10 off turbo timming. How about 5 off each?
What is ballpark gearing change going from ver3 to MMM. Say drop 2 teeth or add 2 teeth.
Anyone got some input?
bjspinner is offline   Reply With Quote
Old 08-27-2011, 10:11 AM   #7773
Suspended
Trader Rating: 86 (100%+)
i have the same question too, is it for boosted 13.5 touring car?
littlealex is offline   Reply With Quote
Old 08-27-2011, 06:52 PM   #7774
Default starting 323 setup needed for 13.5 1/12th scale
I don't see much info posted that's directed towards us 1/12th scale runners. Can someone please post a starting baseline speedo setup for the 323 software that will get me in the ballpark with a 13.5 D3 motor in a 1/12th scale car?
vafactor is offline   Reply With Quote
Old 08-28-2011, 03:10 AM   #7775
J SiN's Avatar
I tried a brand new SP MMM 21.5t motor running off a HW Xtremestock.
First run it tempted at 35deg C geared at 6.3
I added a little more boost and the motor smoked at 58 deg C
Is this a normal thing for brushless?
Is there anyway I can sent this off to be fixed at all?
I really feel ripped off with this so any help would be great.
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 08-29-2011, 12:02 PM   #7776
I'd like to know this too. Some input from the manufacture would be nice
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 08-29-2011, 12:44 PM   #7777
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by JRRobiso View Post
Quick question for the SP peeps...planning on getting a SCT 4x4 in the near future and was wondering if you can run the SP SA V2.0 ESC and SA V2.0 5.5R combo on a SCT platform? Or is it only intended for 1/8 scale application? Thanks for the quick reply.
Not unless you are running 3S or 4S....for 2S, use GT2 PRO.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-29-2011, 12:49 PM   #7778
Solara's Avatar
Thanks for the info...how about the Short Course Master ESC with a SA 9.5R motor?....would the ESC be able to handle the motor...sorry for the silly questions...new to BL ESC and motor combos.
No...running 4x4, your only option is GT2 PRO...trust me, we did test on those and GT2 PRO is the only choice. Don't bother to try other model and hope that will work.
Old 08-29-2011, 12:51 PM   #7779
Solara's Avatar
Originally Posted by Pattojnr View Post
hi guys, having troubles setting end points with the KO propo. steering works fine, but wont accept throttle input, when you calibrate the speedy, it beeps for neutral, then press the red button, and it should beep to input throttle, well it doesnt beep. i just hooked up another speedy and another motor (all new from box) and still does it. wondering if anyone has issues with the KO radio gear to set end points. have radio set in N mode, not high response, and have reset that model to factory reset. kind of thinking its a reciever issue, but my mate had to leave asap , so couldnt nut this one out. Cheers for any help. Patto......
I hardly use FINGER to calibrate with radio....a good 2.5mm allen wrench with some pressure does the work perfectly without any "finger" problem.
Old 08-29-2011, 12:56 PM   #7780
Solara's Avatar
Need more information....
Is that for BOOST stock racing..? How big is the track? Indoor or outdoor? Why are you running the V3 13.5 in 0 timing on endbell? Is that because of the track rule? Please provide more info before we can provide suggestion...thanks.
Old 08-29-2011, 01:05 PM   #7781
Solara's Avatar
Please contact info@walterrchobby.com.au and someone will take care of your case....please provide detail information about the usage and please provide copy of sales receipt for RMA and warranty purpose. Thanks
Old 08-29-2011, 01:23 PM   #7782
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Thank you for your input/advise. Will be getting the SA V2.0 and 5.5R combo thru SP's US warehouse. Just hope it will fit the SC10 4x4 if I decide to get the kit. Will be running 3S lipo battery with the ESC combo since I have no plans of racing. Will be racing/bashing with my daughter at the park.
Will I need to get LCD Professional program card or does it come already with the Multi ESC program card? Thanks again for the quick response.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 08-29-2011, 01:30 PM   #7783
Mxer59's Avatar
Trader Rating: 114 (100%+)
I know when I orderd my v2 2200kv buggy combo it came with the progrommer
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 08-29-2011, 01:36 PM   #7784
Solara's Avatar
Not at this time....you don't need LCD for SAII, yet....
Old 08-29-2011, 01:37 PM   #7785
Solara's Avatar
Only the LED programmer card...not the LCD/USB digital programmer card that JRRobiso was asking.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
