The Speed Passion Thread
#7621
hello,
does anyone know if speed passion serpent 960 conversion kit will also work on serpent 966 ?
thanks
thanks
#7624
thank you very much solara.
#7626
has anyone tried the 17.5 ultra sportsman V3 yet how did it do what gearing did you run? just found out this is the hand out motor for the iic.never ran this motor can you guys help me out
#7627
We run that motor in our spec GT class with the cirtix esc. Gear around 3.9-4 and should put you in the ballpark. That class is going to come down to setup and driving. Hope this helps, see you at the IIC.
#7628
#7630
#7631
#7632
Gt 2.0 pro new owner.
Any idea of a starting set up to use it with a GM pro Metal 10.5T / 5.5T in a Touring car?
#7633
I believe the SP V3 has 0-10* timing, if they are the same motors that they used the last couple years. So 3.7 is going to be good.
#7634
#7635
I don't think it is the V3 Ultrasportsman (I wish it is..), it will be the pro race V3 competition V3 motor with special IIC 2011 marking...however, it will be using the stock BLACK 0-10* sensor....RED and GREEN sensor are ILLEGAL to be use for the hand out race and IIC will tech the motor.
