Like Tree46Likes
Old 08-01-2011, 08:43 AM   #7591
Trader Rating: 48 (93%+)
no i started with a 6.83fdr with the setup above..
Slow as a pop corn fart. and Temps i could cook a egg on my end bell..
here is the movie of the track http://picasaweb.google.com/dlarry62...76296059962418
I want the Car to be fast and Responsive.
Thank you guys for the help.. i was ready to throw in the towel yesterday on this thing
tcb22185 is offline   Reply With Quote
Old 08-01-2011, 10:57 AM   #7592
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Originally Posted by skypilot View Post
So I'm clear, you started out with a 8.36?
What is the stock mark?
Information on the D3 motor I found online suggested that the "Stock" or "zero" mark was 30 degrees mechanical advance.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-01-2011, 11:00 AM   #7593
Jimmy
Thank you Jimmy... i ment to add that to my post but forgot.
Old 08-01-2011, 12:35 PM   #7594
Think i found the issue... WAY To much Drag Brake i had it set at 10% but i just got back from the track and id let off and it was like some one Threw a 1000lb Lead Brick down.. so I'm going to try to lower that. to 5 this is prob my Driving style causing this?
Old 08-01-2011, 01:34 PM   #7595
so on these new MMM motors, what endbell timing should it be on for boosted applications? (17.5) The new timings are 11-20deg right?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 08-01-2011, 03:57 PM   #7596
Trader Rating: 16 (100%+)
If you don't want to use the optional 21-30 timing...try max 20*. If you want to use our setting...we were set at 23* on the green timing board.
Old 08-01-2011, 03:58 PM   #7597
MMM from 10.5 to 21.5 are instock for a very limited quantities...17.5 are out the door left and right. Still waiitng for the 3.5 and 4.5. Order them now...
http://www.speedpassion.net/us/catagory.asp?c=mtr&sc=45
Old 08-01-2011, 09:28 PM   #7598
Suspended
Trader Rating: 86 (100%+)
is it possible to order mmm motor with 20+ degree sensor? or i will have to buy 20+ sensor separately?
littlealex is offline   Reply With Quote
Old 08-02-2011, 02:01 AM   #7599
whityboy's Avatar
I had a MMM motor 17.5T
I put the sensor on min (10).
Run boosted class.
With same gearing and ESC settings of my comp v3 motor.
it gets way to hot after 2 min 80 deg
I run in belgium on large nitro tracks.
changed the esc (gt2 pro) settings way down.
It had nice speed out of the corner but lackt top speed.
After 2 min the temp was 36
after 3min 45
Then 2 rounds later (40 sec) without fading motor stopt and started smokking like hell and the temp was 120.
So after 10 min run the motor was dead.
whityboy is offline   Reply With Quote
Old 08-02-2011, 05:41 AM   #7600
Trader Rating: 22 (100%+)
Run boosted class.
after 3min 45
Did you change your gearing from a V3 if you ran one?
These motors are a torque based design now so gearing change from a V3 is a MUST.
bjspinner is offline   Reply With Quote
Old 08-02-2011, 08:48 AM   #7601
Suspended
any suggestion of gearing for mmm 13.5t boosted?
its for touring. straight is 120 feet. kinda technical. thanks
Old 08-02-2011, 09:11 AM   #7602
Sorry, +20* sensor is optional....MMM came with +10* sensor standard (11* to 20*).
Old 08-02-2011, 09:15 AM   #7603
Suspended
:P
Old 08-02-2011, 09:16 AM   #7604
Suspended
for new mmm motor should i gear it higher or lower? roughly by how much?
Old 08-02-2011, 09:50 AM   #7605
bkspeedo's Avatar
Most motors when running with timing should not have mechanical timing added. If the MMM is a torque based motor like the LRP X12 then run standard timing on the motor. so with a +10 sensor board standard in the MMM i would turn it down to -10. For gearing, a torque based motor can take more gear try around 6.0 +/- .5. ESC timing, be easy at first, add a little a time until the motor temp rises or you have sufficient speed.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
