Like Tree3Likes
Old 07-31-2011, 12:30 AM   #7576
303slowdown's Avatar
Trader Rating: 19 (100%+)
Originally Posted by tcb22185 View Post
now will the starting setup i posted work? what do i need to adj one way or another to get more speed..
i would up you timing to 42
and up your turbo delay to .2 or .3
everything else looks good
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 07-31-2011, 03:14 PM   #7577
Trader Rating: 45 (94%+)
ok Guys My 1st Day Running Speedpassion and i can tell you im not Inpressed with it AT ALL I know its prob the User But i could not Find ANY speed out of this Thing.. here is my setup
1. 1
2. 3 10%
3. 1 None
4. 8
5. 7 87.5
6. 3 75%
7. 0%
8. 1 6%
9. 37 36
10 1 3
11. enable
12. 29 28
13. 1000 RPM i played with this any where between 1,000 and 5,000 ran the main with it in 5,000 and practice in 1,000 5,000 the boost would not kick in tell 3/4 away down the staright 1,000 it felt better. but only ran this in practice
14. 0.1sec
15. timming acc 600
tcb22185 is offline   Reply With Quote
Old 07-31-2011, 03:25 PM   #7578
mr crum's Avatar
Send a message via Yahoo to mr crum
1. 1
2. 3 10%
3. 1 None
4. 8
5. 7 87.5
6. 3 75%
7. 0%
8. 1 6%
9. 37 36
10 1 3
11. enable
12. 29 28
14. 0.1sec
15. timming acc 600
put 15 to 400 and 14 to 0
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 07-31-2011, 05:56 PM   #7579
veecee's Avatar
Trader Rating: 34 (100%+)
Planning on hitting the track again after a 6-month break. I have an X12 Octa 5.0T kicking around. So I want to get this combo into my 417. What is the best software and setup to start with? Thanks.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 07-31-2011, 06:21 PM   #7580
jake95's Avatar
Trader Rating: 27 (100%+)
hi have any of u guys tried the 4.5 mmm motor was wondering what is it like and what type of fdr u guys run thanks
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 07-31-2011, 06:21 PM   #7581
Thanks Harold. Still Dont explane why i could only run a 8.36 fdr and every one Else Was Running a 6.2 6.3?
Old 07-31-2011, 07:21 PM   #7582
skypilot's Avatar
Trader Rating: 14 (100%+)
the setup you have works just fine as a base line
things to change and watch out for is dumping to much timing in the motor to soon, it bogs it down and over heats it, it can be fast but not right, play with starting rpms, play with basic esc timing, reduce 36 to 30, or up to 40 leave the turbo alone, another way to control how much timing happens is the timing ramp, 12, 18, 24 try 24 but change the how many degrees per rpm, when looking at it, the way SP has the adjustments setup, some adjustments are useless unless you have the other adjustments figured out.
a couple of weeks ago, I had a 17.5 out running a 5.5 with no heat issues, unfortunately I made the mistake of reseting the esc to radio and lost those settings without writing them down. slowing working my way back, last week i had to use a 10.5 to run with 4.5's, but i've since sold the mod car so back to non ramping for now.
good luck and happy motoring.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-31-2011, 07:26 PM   #7583
i turned the Ramp down to 3deg before my motor temp was 190F Way to freaking hot for my liking!
Old 07-31-2011, 10:00 PM   #7584
skypilot's Avatar
using the basic setup info you posted, what was your final gear ratio, and where was the timing set on your motor. and what motor
Old 08-01-2011, 02:54 AM   #7585
my fdr was 8.36 motor was trinity duo 3 17.5 timming on stock mark...
Old 08-01-2011, 04:00 AM   #7586
mr crum's Avatar
do you want to run what everyone else does or make the car fast and responsive ?
TEAM B.R. RACING
Old 08-01-2011, 06:03 AM   #7587
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
The D3 setup you posted was worked out by me with a factory team driver who appears in A mains at the national level. It took several iterations to find the spot where he wasnt telling me its got no rip, too slow in the straight, etc. Once we hit the sweet spot, it went into 3 other cars of very capable drivers. Again, everyone was happy with the performance. If it is lacking speed, there is an issue somewhere within the car or the track setup is not a tight technical track.
This is telling me something is way off, or you are on a very small / technical track.
190F - 210F is where that setup runs. All four cars where coming off within this temperature range. Some were running fans, others were not and of course driving styles play a part as well (heavy brakes, etc.)
The SP D3 setup called for 1-2 ticks advanced on the motor. We found when running the 0" or stock timing mark that the lacked rip out of the corner.
If you check the Speed Passion website, there are 2 additional D3 setups from the Memphis "Beat the Heat" race which may be better suited for your track conditions. The Speed Passion / D3 combo was definitely on pace for this event in the extreme heat they were racing under: http://www.speedpassion.net/uploadfi...ll%20Sydor.jpg
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-01-2011, 06:32 AM   #7588
Redwood's Avatar
The turbo ramp setting should have only a small bearing on temperature. The gearing in combination with the last setting and boost start RPM is where the temperature really comes from.
The way the settings interact means that a higher FDR does not necessarily mean lower temperatures. You have to give the timing to the motor when it wants it. you set when timing starts to be added with start RPM, the rate it is added by the last setting and say how much total timing with the boost timing setting. If you add it too early or too fast it will get hotter and SLOWER, too soon and it goes slow. You have to experiment with the last setting for your particular gear ration/fixed motor timing. Sometimes it is counter-intuitive.
As for turbo, it only comes on when all of the boost timing has been added so to make it come on sooner can lower the total boost timing (degrees) so that finishes sooner. You can also lower the last setting but that might take you out of the sweet spot explained before.
Following the advice of a very fast driver I tried running with no turbo at the weekd and after that I actually don't think it is necessary to run turbo. Try all timing in boost, find the sweet spot for your motor and the power will be smoother and the rip down the straight will be more consistent. Maybe I am wrong but I think if you add the timing smoothly as the motor needs it, the sudden jump with turbo is not necessary.
Regards
Neal
Redwood is offline   Reply With Quote
Old 08-01-2011, 07:20 AM   #7589
skypilot's Avatar
So I'm clear, you started out with a 8.36?
What is the stock mark?
Old 08-01-2011, 07:37 AM   #7590
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Pm Keefy, Vincent. Think he used the new mod software with a 4.5 and said it was a rocket and cool
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
