Like Tree46Likes
Old 07-29-2011, 07:38 AM   #7561
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mattwoodcraft View Post
Sloara
thanks for your 4t set up you sent me the other day it works a treat.
and has bucket loads of speed and power.
i have not got a fan running on the motor as yet would you think this would be a good idea to do so
Heatsink and fan both...more is better. I power up the fan directly from the power lead, however, because you are running 4T...when it is on full throttle, it will draw most of the power to the motor instead of the fan and fan might not while at that moment...if in doubt, use the receiver plug power, the fan will spin slower, but will be on 100% of the time. I am glad you like it...we will do the 6.5 or 4.0T in like 3 weeks and will give a shot with the 1/8th car...
Originally Posted by CraigM View Post
Care to share?
I have upload the Marc R. ETS 5 setup...his ETS 6 setup is only gear 1T smaller...like 8.6 final. Look under 1/10th TC Mod....
http://www.speedpassion.net/us/escsetup.asp
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-29-2011, 11:16 PM   #7562
Pattojnr's Avatar
Trader Rating: 19 (100%+)
wiht the 1 Cell motors, there is no identification to where the end bell goes. on the V3 motors, the turn mark is where the lead for the timing board goes, but there are no marks on teh 1 cell 3.5T i have. i made the mistake of taking it apart, and didnt realise the markings werent there. how do i work out where the end bell goes now. as if your in the wrong spot, the connectors go on a different Phase pole ? cheers, and yes i should have checked first, silly me.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-30-2011, 01:52 AM   #7563
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
The stator doen't know the difference......you are moving the sensor also....A-phase is always (v3) to the left of the sensor plug, B-phase center, C-phase to the right. You can also move the other end if you happen to strip out the "to-chassis" mount holes.
I set-up mine so the motor turn label is easiest for tech to see, over, under, thru the chassis. And make the sensor plug easiest to adjust (reach) while in the chassis.
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 07-30-2011, 02:25 AM   #7564
Pattojnr's Avatar
Thanks.
Serpent - Walter RC
Old 07-30-2011, 04:46 AM   #7565
Trader Rating: 48 (93%+)
This is going to be my Starting point Setup if i dont have anof speed. what can i incress or decress to get more. This is my 1st race with a Speedpassion ESC in a Boosted Classes.
tcb22185 is offline   Reply With Quote
Old 07-30-2011, 06:31 AM   #7566
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
What size track are you running on? This setup is pretty specific to the track, which is very technical with a 120ft straight or so.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 07-30-2011, 08:35 AM   #7567
Not sure if this link will work
http://picasaweb.google.com/dlarry62...76296059962418
around 130 to 140 feet in length and 75 to 80 width
Old 07-30-2011, 01:33 PM   #7568
bigdadracing's Avatar
hey guys just a question on what kind of heat your seeing on marks setup ?? i was going to to put it to a 4.5t team powers motor. the weather here is about 80f and running a big track with a 240 back` straight and a preaty good flowing and high speed track!!!
defently could use some thought on gearing and maybe setting changes??
thanks, Russ
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 07-30-2011, 06:21 PM   #7569
Any one Answer my Qustions?
Old 07-30-2011, 06:51 PM   #7570
Hey guys, Is it safe to run a drift master combo on NiMh and NICAD? My ESC fan burnt out and wondering if the battery's are the cause.
86drive is offline   Reply With Quote
Old 07-30-2011, 07:32 PM   #7571
mattwoodcraft's Avatar
link worked all okay.
the track looks good
mattwoodcraft is offline   Reply With Quote
Old 07-30-2011, 07:55 PM   #7572
now will the starting setup i posted work? what do i need to adj one way or another to get more speed..
Old 07-30-2011, 10:58 PM   #7573
303slowdown's Avatar
Trader Rating: 24 (100%+)
When I get home ill give you a starting setup that I like to start with that works well with little tweeks. Give me an hour or two.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 07-30-2011, 11:23 PM   #7574
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
thanks, Russ
Tracks like Mikes Ifmar Nitro Onroad track in Humble Texas.
I get about 160-175 on my motor.
My ESC is Warm at best. If i Ramp I get into 100 range but never got into over heating.
BTW I am selling one of my set up if any one is interested.
Speed Passion GT 2.1 EX with a Team Powers 17.5 Plutonium.
PM if any one is interested. Nothing wrong with it.
I just need smaller Set to save some weight =D On a new build.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 07-30-2011, 11:29 PM   #7575
skypilot's Avatar
Trader Rating: 14 (100%+)
the setup you have works just fine as a base line
things to change and watch out for is dumping to much timing in the motor to soon, it bogs it down and over heats it, it can be fast but not right, play with starting rpms, play with basic esc timing, reduce 36 to 30, or up to 40 leave the turbo alone, another way to control how much timing happens is the timing ramp, 12, 18, 24 try 24 but change the how many degrees per rpm, when looking at it, the way SP has the adjustments setup, some adjustments are useless unless you have the other adjustments figured out.
a couple of weeks ago, I had a 17.5 out running a 5.5 with no heat issues, unfortunately I made the mistake of reseting the esc to radio and lost those settings without writing them down. slowing working my way back, last week i had to use a 10.5 to run with 4.5's, but i've since sold the mod car so back to non ramping for now.
good luck and happy motoring.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
