Like Tree34Likes
Old 07-22-2011, 06:53 AM   #7516
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by defcone View Post
ETA for these motors?
Possible in 2 weeks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-22-2011, 06:15 PM   #7517
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by M7H View Post
Boost ACC, will add 1 additional step in timing per selected RPM number.
So the lower you set ACC, the faster the ESC will add an additional step in boost timing to the motor, which means faster acceleration, but more heat.
Yes, it works together with boost start RPM.
Thank you. i thaught it worked that way, but helping a couple in Stock, so those settings were new to me. rather know what they are for 100% than to start playing with other peoples gear.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-23-2011, 02:12 AM   #7518
Default SC10 4x4 Motor/esc recom.
Hey all. Just wondering if anybody has a recommendation for motor/esc combo for the new AE SC10 4x4. Have read a bit about the different combos out and a little confused about what would be the best setup to go for. Speed Passion of course.
Bumpy is offline   Reply With Quote
Old 07-23-2011, 04:19 AM   #7519
mattwoodcraft's Avatar
Originally Posted by Pattojnr View Post
in the last window, you need to choose your software. 119 Mod, then up top, update software. if you click save changes, then it does not upload the 119mod software.
okay then thanks wednesday when i am home i will programme it..
you be running on sunday
mattwoodcraft is offline   Reply With Quote
Old 07-23-2011, 04:59 AM   #7520
Trader Rating: 49 (95%+)
Not sure if any of there 1/10th esc's will handel the power from a 550. but i would go with the Speedpassions ARROW with a 4.5 or 5.5 550 motor
http://www.speedpassion.net/eu/produ...816801V2&c=ESC
http://www.speedpassion.net/eu/produ...138803V2&c=MTR
tcb22185 is offline   Reply With Quote
Old 07-23-2011, 06:43 AM   #7521
Pattojnr's Avatar
yes ill be there. lots more testing to do yet
Serpent - Walter RC
Old 07-23-2011, 01:49 PM   #7522
leigh123's Avatar
Default 508 options
Can someone please give me a list of what settings are available when running the 508 software on a GT2.1 speedy?
Cheers
Kyosho ZX5 FS2 SP - Mod - Team Orion R10 Pro - Team Orion 8.5
Kyosho RB5 SP WC - Stock - Tekin RS Pro ESC - Tekin Redline 17.5
Schumacher Mi4CX - Stock- Cirtix Stock ESC, Speed Passion 21.5 Ultra Sportsman
Secretary - Chargers RC www.chargersrc.net
leigh123 is offline   Reply With Quote
Old 07-23-2011, 06:55 PM   #7523
Danny-b23's Avatar
Cheers
1. Running Mode
2. Drag Brake
3. Low Voltage Cut-Off
4. DRRS (Punch/Throttle Curve)
5. Brake Force
6. Reverse Force (More reverse usually means more brakes on running mode 1)
7. Inital Brake Force
8. Dead Band
10. Over Heat Protection
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-23-2011, 07:03 PM   #7524
skypilot's Avatar
Trader Rating: 14 (100%+)
you need to read and understand this..
Support up to 4 cell lipo with 3000KV motor.
Support both sensor and sensor less motor
Silver Arrow II ESC is best to be used on 3 or 4 cells lipo power.
If using 2 cells lipo powered vehicle, please use our GT2.0 Pro series ESC.
that is in the info on the website, a 5.5 550 SP motor is 3900 KV
I asked Howard about this in a previous post, he didn't respond to it. they way I read it, SP is recommending that the silver arrow/5.5 combo package they sell only be used on 3s, although they don't come right out and say it.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-23-2011, 07:07 PM   #7525
skypilot's Avatar
if it were me, I would go with a 2.0 pro esc, and 7.5 or 8.5 540 mod motor,
I'm assuming your running on 2s.
Old 07-24-2011, 01:18 AM   #7526
Correct. This setup will be going into an SC10 4x4 which can only run a 2s lipo. Have seen quite a bit of talk here and there saying that a 4.5t-5.5t 550 size is the preferred motor to go for but not to sure on the SP motors as they dont give the same specs info or dimensions as the likes of LRP and Tekin etc. Cheers for the help.
Old 07-24-2011, 10:05 AM   #7527
leigh123's Avatar
Thanks!
Originally Posted by Danny-b23 View Post
1. Running Mode
2. Drag Brake
5. Brake Force
8. Dead Band
Old 07-24-2011, 09:25 PM   #7528
AOD
AOD's Avatar
First day running the 323stock software in 13.5 boosted 1/12th with a TP motor with 10deg of timing. I started with the default settings and a rollout of 66mm. Car ran a fast lap of 9.8. Changed the boost timing to 40deg from 36deg and bumped the rollout to 69mm. Car ran a fast lap of 9.7. Next race I turned the boost back down to 36deg and droped the turbo open acc to 6deg from 18deg. Same rollout as last run car ran a 9.6. Next race I droped the turbo open to .1 and drop the rollout to 64mm. Car ran a 9.5. I have never run speed passion before so this is all new to me. We run 1 qual. and 3 mains, the motor temp all day was 120-123deg. Although I won all three mains the other brand speedo was running 9.3 laps and killing me down the straight. Any suggestions to my setup are welcome. We won't be racing for three weeks so I will again be testing then. Thanks Frank
AOD is offline   Reply With Quote
Old 07-24-2011, 10:13 PM   #7529
defcone's Avatar
Trader Rating: 15 (100%+)
Drop your start rpm and timing acc. Sounds to me your car isn't winding out. Is your car still wanting to accelerate at the end of the straight?
defcone is offline   Reply With Quote
Old 07-25-2011, 01:07 AM   #7530
Originally Posted by Solara View Post
Boost software only used on SUPER hugh track...otherwise, there are really no benefit of using it with mod motor. 205 with 4T has plenty of power for track 200 or shorter.....
Here is what I know...Marc won the race at REEDY race in USA (actually, Marc, Victor and Atsushi Hara) all using 205G along with 4.0T motor. (you can find the video on youtube)
Then, Marc, Yanni and others...ran the 323stock with 4.0T motor at ETS event (also can be found on youtube). You can compare that 2 track, the ETS is 50% bigger then the Reedy track.
Hey,
Has anyone found that running 323 stock software in MOD is terrible??? Its got wild top speed, but the driveablility is %^&* to say the least???
Whats the secret with running 323 in MOD and making the driveability work???
Thanks in advance
hpipurple is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
