Like Tree8Likes
Old 04-13-2009, 07:24 PM   #61
bigdadracing's Avatar
[QUOTE=Shawn Palmer;5678929]Hi Russ:
Start with 98/34 and the timing advance maxxed out.
If you didn't run the timing maxxed in your 1.1, then take away another tooth per advance setting you are going up.
Keep your eye on motor temps every minute or so for the first few runs. If you follow the above, you'll be within a few teeth either way. (too hot - lose another tooth or two, or not quite fast enough add a tooth or two
shawn, max the motors timing or the speedo's setttings on the timing
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 04-13-2009, 07:32 PM   #62
Mike Haynes's Avatar
For any spec motors i like esc timing max and motor at 0 to start.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-13-2009, 07:44 PM   #63
Originally Posted by Yokomo_Ant3 View Post
Hey Guys, i am going to buy a SpeedPassion 2.0. Motor. I was going to get a 4.0. My question is do all of the motors have an inbuilt fan or are there some without? I have been told to get the one without the fan.
Also are the normal ones the same as the special edition motors. Eg the Mark R, Jilles edition etc.
If there are ones without the fan could i posssibly get a Pn?
Yes some of the champ edition don't have fans. I know the Reinhard one dosen't have a fan, and the Jillies one does. They go harder in every way without the fan but also have more wheelspin. I like a cut down fan best. The full fan is great for low grip as it tones down the spool up for better control.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-13-2009, 07:50 PM   #64
dbmartin's Avatar
I just ordered my 2.0 esc today, I am going to be running mod. What FDR should I be looking at for a 4.5 motor, it is an Orion vortex. Also what base setting should I start with. I am upgrading from a GTB. - Medium to large track
Thanks.
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 04-13-2009, 08:37 PM   #65
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Cool I will try and get a Mark R one, if i can find one in stock
Thanks For your help
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing - Bezerk RC - Hearns Hobbies - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 04-13-2009, 08:55 PM   #66
ok i looked at a few places and only found rcmodel having the special edition motors. There all out of stock. Does anyone else know any other place that has the motors, or any other 4.0 motor without the fan?
Antoni Caretti
Old 04-14-2009, 05:31 PM   #67
dameetz's Avatar
Thanks.
I want to know this too...I got mine any haven't run it yet...I be racing this weekend in mod class indoor carpet foam tyres..I bought it with 2 motors 3.5 and 4.5...What esc timing do you usually use for the motors I just mentioned? BTW I ve got the LCD Pro Card as well..
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-14-2009, 08:39 PM   #68
I ran mod sedan at the carpet nats, medium sized track, ended up with 21.5mm rollout, esc timing at 0 for a 4.5...should be a decent starter for you.
Old 04-14-2009, 08:55 PM   #69
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i saw this website...seem like evething r same with speedpassion except d casing...
www.hobbywing.com
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-14-2009, 08:58 PM   #70
smilekt's Avatar
www.hobbywing.com
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 04-14-2009, 09:01 PM   #71
smilekt's Avatar
how much straight line in feet or meter for medium size track?
Old 04-15-2009, 04:53 AM   #72
n for
WOW that is low.
I run max timing even for mod but mayb I should try lower. I usually start at 22mm for a 4.5t motor.
Powered by Falco
Old 04-15-2009, 05:06 AM   #73
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
www.hobbywing.com
It's reasonably common knowledge that Speed Passion speedo's are made by Hobbywing, the speedo you are referring to looks like a GT 1.1?
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 04-15-2009, 06:46 AM   #74
abailey21's Avatar
Trader Rating: 36 (100%+)
It's no big revelation that "some" of our products come from the Hobbywing factory, but what happens to our products as opposed to the stuff you see on that website is quite a bit different.
www.hobbywing.com
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-15-2009, 08:42 AM   #75
around 90 feet
n for
WOW that is low.
I dont like high timing with the 2.0 while running mod, it is just tooo much.
Once Adam touches it it goes fast
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
