Like Tree34Likes
Old 07-11-2011, 02:40 PM   #7441
Hi,
I'm running a SP 13.5t boosted with a LRP stock Spec V2 geared at 5.20 timing on the motor is in the middle and this set up works well, what gearing would I need with a SP 10.5t same speedo and same track ?
Thanks.
S.A.W is offline   Reply With Quote
Old 07-11-2011, 06:13 PM   #7442
koopesv's Avatar
Trader Rating: 18 (95%+)
I currently have Prostock with 528stock and I run a 10.5 and was wondering if I changed to a newer software will I still be able to run 10.5? I not sure if I can remember what I read. i want to update to the 323 I need some input on this.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 07-11-2011, 07:33 PM   #7443
RacinJ's Avatar
Will there be a 1s version of the MMM?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 07-12-2011, 11:49 AM   #7444
Solara's Avatar
Trader Rating: 16 (100%+)
Yes.....overall at ETS, top driver using 323stock with 4.5 motor. But that is only for professional and they have alot of motor/esc for spare. But yes, 323stock can work with 10.5...upgrade that now.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-12-2011, 11:50 AM   #7445
Solara's Avatar
No...the new MMM is good enough for 12th scale racing. It is a newer version of 1S V3 motor already.
Old 07-12-2011, 11:51 AM   #7446
Solara's Avatar
Originally Posted by S.A.W View Post
Hi,
Thanks.
My wild guess is 2-3T shorter.........
Old 07-12-2011, 01:05 PM   #7447
Default Help!
hello Everyone! , just got my SP gt pro 2.0
whit a 5.5 SP motor , my car has 2.0 in ratio , right now i have a 106 spur gear 64dp in it, what can be a good/safe combo to start with? (pinion and setup for esc).
The track i drive on is pretty big , 280 meters long. With a big straight.
Tnx
Marcus
MarcusEngdahl is offline   Reply With Quote
Old 07-12-2011, 01:50 PM   #7448
Solara's Avatar
whit a 5.5 SP motor , my car has 2.0 in ratio , right now i have a 106 spur gear in it, what can be a good/safe combo to start with? (pinion and setup for esc).
The track i drive on is pretty big , 280 meters long with a big straight.
Tnx
Marcus
280 METERS LONG...? You sure that is not a airport runaway for RC jet? That is 918 feet......3 times the size of our bigggest 1/8th ON ROAD track...are you sure it is 280 meters long or 280 feet long...hugh different.
If it is indeed 280 meters long...run NITRO car...you will burn the motor before it gets to the end of the straight.
Old 07-12-2011, 02:15 PM   #7449
I don't think it is a 280 meter straight, but a 280 meter track, with a big straight :-)
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 07-12-2011, 02:22 PM   #7450
Solara's Avatar
Safe way to run 5.5T mod is run 205G, full timing, gear around 7.5 or even higher (depends on motor temp)...motor timing in middle position.
Old 07-12-2011, 07:51 PM   #7451
skypilot's Avatar
Trader Rating: 14 (100%+)
I've been racking my brain trying to help a friend with a silver arrow esc and 5.5 motor combo.
after reading just about everything i can find this is what I have come to understand and need carification.
running this system on 2s will not work, "If using 2 cells lipo powered vehicle, please use our GT2.0 Pro series ESC."
running this system on 4s will not work "Support up to 4 cell lipo with 3000KV motor." the SP 5.5 SCT motor is 3905kv
"Silver Arrow II ESC is best to be used on 3 or 4 cells lipo power"
so the only way to run the esc/motor combo as sold is with 3s, I'm assuming this as I don't have a 3s lipo to test with.
So I'm also gonna assume that if I install a GT2.0 esc and this 5.5 SCT motor on 2.s it will be ok.
at this point the esc is useless unless he buys a smaller motor, which I already know hes not going to do. can I send it in for credit towards another Pro 2.0 esc? you guys are pretty much giving them away on the web site so trying to sell it is mute.
edit, ok so i wired up a pro 2.0 (on 2s) to the motor and apparently its hurt, no rpm whats so ever and after a couple of trigger pulls the red and green lights flash on the esc. (it also did this with the silver arrow esc and 4s)
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-12-2011, 09:15 PM   #7452
Sorry if you understand me wrong , the track is 280 meters long. And it has a big straight.
Old 07-12-2011, 10:06 PM   #7453
With the driver stand in the middle of the 280 meter long track , you will not be able to see the end of each side 140 meters away ! Take you tape and re-measure the track, buddy !!! Even a 280 foot track is too big for 8scales !!!! Any track above 250 feet long is not practical !!! Get your facts straight !!!
bertrandsv87 is offline   Reply With Quote
Old 07-12-2011, 10:09 PM   #7454
jake95's Avatar
Trader Rating: 27 (100%+)
have any of you guys tried sp 17.5 mmm is it better than sp v3 17.5
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 07-12-2011, 10:34 PM   #7455
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Needs help No blinky led
I have the SP GT pro 2.0 esc and I don't see the led light anywhere on the esc..even on the switches..there's a red buttom but no led
the esc is carbon black with purple top heat sink..
OVA is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
