Like Tree8Likes
Old 07-01-2011, 05:56 AM   #7396
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by mattwoodcraft View Post
hello
can some point in the rite direction for a gear ratio with a 17.5 i am running at 4.5 at the momant and during testing it doesnt seem to be very good.i copied a programme form the speed passion site but i dont notice any boost at all. the motor timing is standard at the momentas it came out of the box.
i am alittle confused at the moment trying to catch up on technolagy not raced TC for 4 plus years
thanks
What software are you using? What motor are you using?
If you are using non-boost software then your ratio is about right.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-01-2011, 06:16 AM   #7397
Rod M's Avatar
as per the setup sheet I have the D3 on 2 notches,
I will drop it back one and try your setup,
Thanks,
Originally Posted by Kevin K View Post
First how much timing are you using in your D3?
With 1 notch off center I would make these changes.....Try taking #4 and go to level 9....take #9 and go to 45deg.....take #10 to 6deg/0.1s....take #12 to 15deg....take #14 to 0s. This should increase the bottom end along with top end.....and gear at 6.7 to 6.5 to start and check temps. Hope this helps some.
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 07-01-2011, 06:30 AM   #7398
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Originally Posted by Rod M View Post
have been testing this exact setup on large asphalt track, (Moorebank Sydney, 17.5 duo 3, TOP Photon) but I still get hosed down the main straight (1-2 meters)
I have tried gearing up from 6.7 to 6.5, but this did not improve times.
down low it is lacking a bit as well,
(perhaps I am overgeared?)
over 6mins motor is coming off max 137deg F.
Is this the track?: http://www.moorebankraceway.com/
If so, how long is the straight?
The D3 setup on the SP site is developed for a much smaller (120ft straight), very tight track style. I dont see those setting working well on a bigger flowing track.
I am hoping to get to our local big track (225+ft straight) soon to develop ESC / Motor setups. As a guess, here would be my big track starting point based on the 528 SW setup I ran last year:
Motor Timing: D3, 1 tick advance
FDR: 5.5 to 6.0 (again BIG track)
DDRS: Level 8
Boost timing: 36
Turbo Slope Rate: 6
Turbo Timing: 18
Boost Start RPM: 5000
Turbo Delay: 0.3s
Boost Timing Acceleration: 500
NOTE: I have not tried the above, so PLEASE check motor temps every few laps to ensure the settings are not way off.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 07-01-2011, 06:36 AM   #7399
zosman's Avatar
My hobbies is Rc
zosman is offline   Reply With Quote
Old 07-01-2011, 01:48 PM   #7400
Rod M's Avatar
DDRS: Level 8
Boost timing: 36
Turbo Slope Rate: 6
Turbo Timing: 18
Turbo Delay: 0.3s
Jimmy
yes that is the track, not sure the exact length of the track,
I will give it a go and see what happens,
Old 07-01-2011, 05:50 PM   #7401
mattwoodcraft's Avatar
hello
i have the pro GT version 2.0 software what ever came with the speedy
the motor i am using is a speed passion V3 17.5
thanks
mattwoodcraft is offline   Reply With Quote
Old 07-01-2011, 06:05 PM   #7402
LonnyJ1950's Avatar
Running 13.5 boosted 1/12TH scale with EX 2.1, 323 software, Trinity Nemesis, medium size mildly technical track 100' straight. Set up suggestions?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 07-01-2011, 06:40 PM   #7403
does the hobby wing programme box work with the speed passion at all ?
i have been told that they will but i am unsure
i will assume that i will not beable to down load the latest software with this card ?
Old 07-02-2011, 04:29 AM   #7404
Hi Matt,
Yes, the HW LCD programme box works fine with the SP ESC. You can use it to flash the latest SP firmware without trouble.
Oggie is offline   Reply With Quote
Old 07-02-2011, 05:09 AM   #7405
great thanks
i have just done a update choice version v3.0_110323stock
soft ware is V2.01000528_mod
hardware427_v1.0
does this sound correct ?
thanks
Old 07-02-2011, 05:35 AM   #7406
Pattojnr's Avatar
Trader Rating: 19 (100%+)
great thanks
hardware427_v1.0
thanks
if you get stuck , i will be there tommorow. i only run SP software and program box, and motor / speedy. i have the latest SP software to load up for you.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-02-2011, 06:54 AM   #7407
koopesv's Avatar
Trader Rating: 18 (95%+)
This is what I found to work well for a track with a 235 foot straight.
Trinity D3 10.5 (1 advance of timing)
Prostock 2.1 528stock
DRRS-7
DTMS Timing-5 (15*)
Supercharger Boost- Stage 8
Supercharger RPM Delay- 4 (4000)
Supercharger Full Throttle Delay- 4 (0.3s)
Supercharger Punch-7 (-6)
Motor Temps came off at 145* with heatsink and fan
Without fan and heatsink temps were 155-162 95* outside
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 07-02-2011, 08:36 AM   #7408
Default Blinking green LED
Hi guys, I have this annoying blinking green led on my v2.0 everytime after a run. The esc is not thermalling and the motor is also not overheating.
I am suspecting that the led is related to a sensor issue. However according to the manual for the problem to be sensorboard / harness related both the red and green leds must be blinking.
Can someone confirm this? I am using a V3 5 turn motor with my v2.0 esc and I do not currently have another motor to swap out and try.
If I turn the system off and back on again the light goes off.
radwerx is offline   Reply With Quote
Old 07-05-2011, 04:44 AM   #7409
has anybody been using the new MMM motor ? looking at getting one , how do they compare with the V3
Old 07-05-2011, 06:11 AM   #7410
Send a message via Skype™ to orzel24
When the Speed Passion company think about make firmware program to update ours speedos on Mac OS X and Linux systems?
Blazej Orlowski
orzel24 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
