Old 06-29-2011, 10:48 AM   #7381
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jhhack View Post
Do you know when you expect the MMM motors and timing inserts to be for sale to the public? Debated waiting or getting a 17.5 v3 for blinky racing.
Timing sensor are on sale now...
MMM...will be another month or so.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 06-29-2011, 12:08 PM   #7382
Trader Rating: 55 (98%+)
The sensors work with the normal v3 motors? I was thinking they were only for the MMM ones?
jhhack is offline   Reply With Quote
Old 06-29-2011, 12:18 PM   #7383
swimbikerun's Avatar
Trader Rating: 100 (100%+)
I just got back into racing after taking 1.5 years off and decided to go with the GT 2.0 Pro for 17.5 TC. I'm using the latest firmware and was wondering that the "blinky" mode is just profile 0? Or do I need to do something different? Thanks in advance.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 06-29-2011, 12:20 PM   #7384
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
You have to flash software 508 in order to get "blinky" mode.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 06-29-2011, 01:22 PM   #7385
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Hi Guys
Wondering if you can help looking for good starting point for x12 13.5t and Gm 10.5t fro tight 20x30 mtr carpet track for boost
Craig W is offline   Reply With Quote
Old 06-29-2011, 01:42 PM   #7386
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
I have been running the +10 (20 degree) and +20 (30 degree) boards in my V3 and 1S V3 motors, so yes they work fine in the V3 motors.
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 06-29-2011, 02:15 PM   #7387
Solara's Avatar
Yes...it does work with normal V3 and 1S V3 motor, as well as the new MMM.
Old 06-29-2011, 05:18 PM   #7388
Originally Posted by g12314 View Post
Assuming the Tekin timing #'s correlate to the Speed Passion ESC #'s, then you are pretty close to the setups we run here.
For a 120ft straight, gearing between 6.8 and 7.4 FDR (depending on track / motor combo / ESC settings) is the typical range.
If your temps are coming off at 120F, you can try the following:
45 Boost
18 Turbo
0.1 delay
2 ramp (you can try 1 if the motor temps stay low to see if it likes the timing sooner)
16K for the end RPM, and somewhere between 3000-4000 for the start.
Start at 7.2FDR and see how it responds.
On another note, the option timing boards the Speed Passion sells really wakes up these motors for 1/10th TC use. I am running a 30 degree board (set to 24 degrees) and it really helped get more rip out of the corners due to the mechanical timing advance.
Let us know how those settings work out. Remember to check the motor temps after a couple minutes with the new settings.
EDIT: Just noted that you were 13.5, not 17.5 which is what the settings above are for...... Gearing more like 7.4 - 7.8 FDR for 13.5
45 Boost
18 Turbo
0.1 delay
19K for the end RPM, and somewhere between 4000-4500 for the start.
Sorry about that.
Jimmy
trying to figure out the V3 in 17.5 boost.
I have the original sensor board, 2 questions:
1. Do you run with the maximum end bell timing or minimum?
2. The new sensor boards, are they that much better for boosted? +10-20 seems like too much timing
thanks
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-30-2011, 02:27 PM   #7389
Solara's Avatar
thanks
1. Yes...I have never ran the 17.5 V3 without 10 (max, full right).
2. Yes...that too, the rip is night and day...but of course, once we are running the 20 and 30 sensor, we have to back down the ESC boost/SC but alot to balance it. We did try to use old setup with fast rotor, full timing on motor (totally for testing) and only take 2 minutes the magic smoke came out, rotor in pieces (yes...alot of pieces) and the motor is a solid SPOOL afterall.
Old 06-30-2011, 02:36 PM   #7390
For boosted esc racing- I like the 10* sensor maxed.
I have been trying the 20* sensor turned to 15* and
turning down the esc settings a little.
For limited esc class - 30* sensor maxed.
Solara- love ya....punk....
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 06-30-2011, 02:48 PM   #7391
Solara's Avatar
Wow...Syder is in the house, and the best part is, he know how to use COMPUTER...WOW.
I need that GT rematch, MWS in 3 weeks...bring it on.
And thanks for your insight.
Old 06-30-2011, 03:26 PM   #7392
g12314's Avatar
The 30 degree board set to ~23 degree's sure does run nice on the boost .
Hopefully will have the setup fine tuned this weekend.
Jimmy
Old 07-01-2011, 05:11 AM   #7393
Rod M's Avatar
Originally Posted by Solara View Post
Not carpet, but you can try gear to 7.0 ~7.2 and use this setup...
http://www.speedpassion.net/uploadfi...0Jimmy%20S.jpg
have been testing this exact setup on large asphalt track, (Moorebank Sydney, 17.5 duo 3, TOP Photon) but I still get hosed down the main straight (1-2 meters)
I have tried gearing up from 6.7 to 6.5, but this did not improve times.
down low it is lacking a bit as well,
(perhaps I am overgeared?)
over 6mins motor is coming off max 137deg F.
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 07-01-2011, 06:41 AM   #7394
mattwoodcraft's Avatar
hello
can some point in the rite direction for a gear ratio with a 17.5 i am running at 4.5 at the momant and during testing it doesnt seem to be very good.i copied a programme form the speed passion site but i dont notice any boost at all. the motor timing is standard at the momentas it came out of the box.
i am alittle confused at the moment trying to catch up on technolagy not raced TC for 4 plus years
thanks
mattwoodcraft is offline   Reply With Quote
Old 07-01-2011, 06:50 AM   #7395
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
First how much timing are you using in your D3?
With 1 notch off center I would make these changes.....Try taking #4 and go to level 9....take #9 and go to 45deg.....take #10 to 6deg/0.1s....take #12 to 15deg....take #14 to 0s. This should increase the bottom end along with top end.....and gear at 6.7 to 6.5 to start and check temps. Hope this helps some.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
