The Speed Passion Thread
#7291
http://www.speedpassion.net/us/produ...8802Prob&c=ESC
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
#7292
Any chance this is esc firmware related.
Thx
Joe
#7293
Well it sorta worked. I have a heatsink fan on the motor and added the cap and pulled the fan wire. 80% improved but not gone. Im running latest hw firmware but noticed sp had a "patch" for fasf rx. I tried to downrev and test that firmware but the sw would not allow it. I surfed the threads and there is a lot of confusion on this topic.
Thx
Joe
Thx
Joe
Beside, your programmer card is running hobbywing software/firmware within, you have to talk to the HW ppl and find out how to upload the speed passion software/firmware on your LCD in order for you to use our software...that, I cannot provide any help.
#7294
Yes it is a Silver Arrow II with V.100_100912a_2R firmware loaded. This firmware appears to be newer than the SP version and I am not using a Futaba Rx. This is in a new Short Course 4x4, Ofna Nexx 10 SC. I went with the SP over the Novak ESC since I already own the HW 80A Xerun, which has been flawless in my 1/8 scale buggy. No glitches, no Cap needed, etc. Savox servo's in both. The Rx works fine in another car w/o any Glichbuster Cap.
I'm starting to think the motor pulls a lot of current and is already advanced 30 degrees. I haven't tried to change the ATMS timing from default but will set it to zero and see if there is any difference. I would have purchased a 4.5T SP motor but they were all out of stock.
I'm still pretty green with this sport so I could be overlooking something obvious and jumping down rat holes. Any advise is much appreciated.
Thanks,
Joe
Thanks,
Joe
#7295
Is my the sensor done with?
Sup guys,
Recently I had the green and red flash with my GT 2.0 and V3 3.5T, I cleaned out the motor and all internals. But what's the chances of the sensor unit failing? I just don't want to fork out for a new sensor and only to find out that the problem is the actual motor itself. Also don't know if this matters but motor temp never went above 50C.
#7296
Sup guys,
#7297
Trader Rating: 102 (100%+)
Feedback
Just had a few quick question,
I'm looking to try new speedos this season
switching from Tekin RS Pro
primarily run 17.5 blinky
primary motor is LRP.
how does the GT - Pro Brushles ESC Version 2.0
hold up.
is there better Speedpassion option?
should I use the optional High Power Capacitor?
etc
thanks
any feedback would be appreciated.
hold up.
etc
thanks
#7299
Super Moderator
hold up.
It has just won the Reedy race and a few WORLD CHAMPIONSHIPS. It should Handle things fine.
GT20 is the flagship of all the SP ESC's unlimited Motors. All the others handle up to a 5.5 motor.
Yes.
#7300
R/C Tech Elite Member
I just picked up a Speed Passion Gran Turismo 2.1 to run in my TA05 for 17.5 turn stock, when I use the LED card to set the values, I get nothing past item 10 so I don't have access to any of the boost timing features (which is why I upgraded from my justock esc)
What do I need to do to get it to work?
Attached is a pic of what I have in case I have mixed it up with the wrong esc.
#7301
