Old 05-15-2011, 02:30 PM   #7141
marcel p's Avatar
Send a message via MSN to marcel p
have seen a few runs off sidecarphil.
realy crazy for a 6.5 and stil going strong after 7 minutes.
after the run stil easy to hold the motor. low motor temps.
myself had good results with my 13'5 and 323 sw
liking it more and more.
thanks
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 05-15-2011, 04:59 PM   #7142
Anyone got a starting setup for a GT2.1 EX running a 10.5 on 1s lipo in a GT10 pan car, indoors on carpet track aprox 30m x 12m on the new 323 software?
rich67 is offline   Reply With Quote
Old 05-16-2011, 05:08 AM   #7143
i have a v3 13.5t 1s motor here
thinking of testing it in my ff03 car with 2s
what gearing should i start with, running on a large asphalt track?
also what is the difference between the regular and 1s motors?
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 05-16-2011, 09:07 AM   #7144
unknownmember's Avatar
Default V3 3.5T Optional Rotors
Hi there,
Just discovered that...well for me any ways. That there's actually optional rotors for the V3 motors and each of them has different characteristics. So I was just wondering if there's much difference in them? For instance going from the standard black rotor/ red ring to silver rotor/ red ring. Also in the description, some of the optional rotors says " Super 7 ", what is this feature?
unknownmember is offline   Reply With Quote
Old 05-16-2011, 09:58 AM   #7145
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by unknownmember View Post
Sup guys,
SP wouldn't happen to sell the switch harness on their GT ESCs on the side would they? I broke mine recently by mounting it on the side and the inevitable happened I tried gluing it back on but it never lasts and it'd just brake off every noun then.
Our US webstore only handle US customer, you need to contact here, they will get that take care for you and ship to Australia....
[IMG]sale@king-golden.com[/IMG]
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-16-2011, 10:00 AM   #7146
Solara's Avatar
Originally Posted by skypilot View Post
well like i said before, Ive have ran boost on everything from a 13.5 down to a 6.5 in the mod class. from 'my personal experiences', it is pretty easy to find a setup that will run the same lap times as a 4.5, HOWEVER that is lap times, I can drive deeper into the turn (usually a sweeper) coming off the straight, have better control on the infield with a smaller boosted mod motor, but coming off a corner on the back door of a 4.5 you WILL get pulled because of the low end grunt those motors have. you can make up the distance later on the track. that was on a very large outdoor track. but that was me. I have seen drivers (such as Travis S a multi time national champ, kick some serious ass with a boosted small motor in the mod class on carpet. it can also be done on pavement, especially if you have a track with low to med traction. it is my understanding that serveral 'PROs' have even been boosting the 4.5. thats just gotta be crazy fast.
Good to know that.....but only on the 323 version that will made me feel SAFE to tell ppl to try it with mod motor.
Old 05-16-2011, 10:03 AM   #7147
Solara's Avatar
Originally Posted by Fastfreddy74 View Post
Today i've done some testing with 323Stock firmware and 6.5T V3 motor, the track was not sprayed with sugar because it rained the night before, so traction wasn't at its best, but good enough to test motors.
Ambient temperature was about 25, track temp. 38, max motor temp 60 without fans
Results were impressive, during the first runs i had too much power! So i toned down some settings to gain a better driveability.
Had no problem keeping up with 5.5 and 5.0 turns motors.
Here is were i started in the morning (too abrupt, difficult to drive) :
Stock rotor
Endbell timing - 5
FDR - 8.5
4 - 7
9 - 30
10 - 18/0.1s
12 - 15
13 - 5000
14 - 0.3s
15 - 500rpm/deg
and here the settings after various tests, i got a more linear feel of the power band
Stock rotor
Endbell timing - 5
FDR - 8.5
4 - 7
9 - 25
10 - 18/0.1s
12 - 20
13 - 6000
14 - 0.3s
15 - 700rpm/deg
Cheers!
BTW, this was the track, main straight is about 35m long
: http://www.modellismo2002.it/pista.p...=580&width=895
P.s. Thanks Solara and sidecarphil1
NICE TRACK..........and thanks for sharing.
Old 05-16-2011, 10:06 AM   #7148
Solara's Avatar
Not yet....and probably won't have much 10th scale here running in state. But...you can try Harold's 528 stock and give that a try yourself. I mean, use his setup and applied onto the 323 and create your own timing level and give that a try.
WGT is not really a hit here..especially on outdoor when we are all running now in Summer....
http://www.speedpassion.net/inc/down...8HMcDonald.pdf
Old 05-16-2011, 10:57 AM   #7149
Solara's Avatar
Good choice...1S motor is lighter (5 grams or so) and the stator has less resistant compare to the standard V3...is a faster motor.
Old 05-16-2011, 03:06 PM   #7150
mr crum's Avatar
Send a message via Yahoo to mr crum
solara i will be sending you a new setup when i find the new setup sheet on the site cant find a blank one
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-16-2011, 03:14 PM   #7151
Solara's Avatar
There is a blank one....right here. (upper left side of the setup page). You can still send me one if you want...
http://www.speedpassion.net/files/Sp...k_6may2011.pdf
Old 05-16-2011, 07:52 PM   #7152
skypilot's Avatar
Trader Rating: 14 (100%+)
boost is boost, if someone doesn't know what thier doing or how to use it doesn't matter want version it is. whenever I talked about using it, I always said, start slow and go from there, that holds true for all esc's and all versions of boost. heck it even goes for non boost, heck it was true with brushed motors.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-18-2011, 08:09 AM   #7153
Default Set up for 10.5 outdoor
Hey,
Just moving over to SP v2.1 stock spec from GM and looking for a good setting for outdoor racing in 10.5.
Where should i start the gearing and possible speedo settings, software to use etc..
Any help would be appreciated.
Jon
socialjon is offline   Reply With Quote
Old 05-18-2011, 08:13 AM   #7154
Solara's Avatar
Originally Posted by socialjon View Post
Hey,
Jon
We have quite alot of setup there...please check it out.
http://www.speedpassion.net/inc/down...Howard%20L.jpg
Old 05-18-2011, 08:43 AM   #7155
Thats great, thanks, a good starting point..
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
