Old 05-11-2011, 08:04 PM   #7111
Trader Rating: 74 (100%+)
Originally Posted by Solara View Post
V1.36 released
............and we are not going to support V1.35 anymore and thats why I removed the old version, and I will remove all the previous old version cause all the software we had so far are be found in the new V1.36
Stop using 1212 as this is not even close compare to the new 323STOCK software. Also, try the new 119MOD supercharger software for MOD motor.
Here is the link....you guys will love it. Make sure read the attached PDF file as this Supercharger improvement is alittle different then the previous 1.35 or 1.33 version.
http://www.speedpassion.net/us/escsetup.asp
I am in the middle of creating some setup for 17.5 13.5 motor...as well as some 8.5 10.5 for mod...all are using 323STOCK software (YES, 323STOCK software for MOD racing)...and mainly in OFF ROAD setup, but I have some on road indoor and outdoor setup as well....stay tuned.
Also, new 323stock and 119mod setup sheet....
http://www.speedpassion.net/files/Sp...k_6may2011.pdf
IMPORTANT: You must update the LCD programmer from the 1.36 version before you can see the changes for the 323STOCK, it is a must do process.
Is there any changes to Blinky Mode?
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, JSpec custom stickers and apparel.
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 05-12-2011, 12:33 AM   #7112
Originally Posted by vafactor View Post
does anyone know of a US outlet that has one of the LCD speedo programming boxes in stock? Everywhere I've looked online lists them as out of stock or on back order.
I had the same problem so i popped onto Ebay and bought one from Hobbywing , this is the same and if you use the speed passion softwere it works perfectly ,
looks nicer too
sidecarphil1 is offline   Reply With Quote
Old 05-12-2011, 05:55 AM   #7113
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
+1...if you guys could bump up the brakes on 508 blinky a bit, I'd like that.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 05-12-2011, 09:57 AM   #7114
Solara's Avatar
Trader Rating: 16 (100%+)
No....we tried, but failed (not passing the ROAR standard).
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-12-2011, 09:58 AM   #7115
Solara's Avatar
Originally Posted by Craig W View Post
There are out of stock
Contact sale@king-golden.com and you can order thru them direct.
Old 05-12-2011, 09:59 AM   #7116
dont need brakes in 0 timing mode , dont brake
i have my brakes at 50% on my transmitter and 100% in the speedo but this is only incase of emergencys
Old 05-12-2011, 10:26 AM   #7117
encore75's Avatar
Unfortunately, we don't have a wide open track...just about every turn outside of the sweeper off the straight is a 180* hairpin, so braking is needed.
This is my first season running the SP, and I feel like my old LRP had a bit more brakes.
Old 05-12-2011, 11:25 AM   #7118
Solara's Avatar
LCD is back in stock in US direct sale, not alot, so, hurry...
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
Old 05-13-2011, 12:58 AM   #7119
i tried the latest speedpassion firmware/software on my xray t3 last night had great speed out of corners but top end was not that good running fdr 7
v3 13.5 motor was set on 0 degrees so changed this to full 10 degrees what a difference so was so much faster down the straight well done speedpassion at last i have a car that can keep up with the leaders
rc12r5.1
moggy12 is offline   Reply With Quote
Old 05-13-2011, 11:25 AM   #7120
Solara's Avatar
Never 0* on V3 motor...at least, I never use 0*, always 10*. And you guys have not try these bad boys yet....
http://www.speedpassion.net/us/produ...SP000034&c=OPT
http://www.speedpassion.net/us/produ...SP000029&c=OPT
Old 05-13-2011, 12:14 PM   #7121
Cool!
Fastfreddy74 is offline   Reply With Quote
Old 05-13-2011, 12:27 PM   #7122
When will they be available for purchase?
gdcopbdcop is offline   Reply With Quote
Old 05-13-2011, 12:34 PM   #7123
Solara's Avatar
I was told next week.....at SP USA website.
Old 05-13-2011, 12:37 PM   #7124
kool!,,,solara, i am sending you a pm
Old 05-13-2011, 02:21 PM   #7125
ok heres my starting softwere
6.5SPv3 middle timing
drag brake 20%
DDRS lvl 3(low grip dusty track)
boost timing 36 degrees
Turbo open time 6degree/0.1sec
turbo 15 dergees
boost start rpm 10,000
turbo open delay 0.4sec
boost timing acc 500rpm/deg
Gearing 7.2
ok tonight i ran this , the grip was up so i turned the boost up to 40 and the turbo up to 20 and the boost start to 5000 , this made the car a lot smoother and REALLY REALLY quick !!!!!
temps with fan were Speedo 45 degreesC and motor with 2 fans 70 degreesC
i was laughing all night
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
wyd
SEO by vBSEO 3.5.0
