Like Tree46Likes
Old 05-07-2011, 03:43 PM   #7051
SpeedySST's Avatar
Try as I might, I cannot find the gauge of wire I need for 17.5 open with the GT2 speed control. Please advise.
SpeedySST is offline   Reply With Quote
Old 05-07-2011, 03:57 PM   #7052
marcel p's Avatar
Send a message via MSN to marcel p
Originally Posted by SCTom View Post
Those settings are default I believe. Check out the setup sheets on SP site for something that might work for you.
oke thanks. have to be a default setting as you say i think
think i have a nice setup now. test it on the track tomorow
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 05-07-2011, 04:34 PM   #7053
Originally Posted by dbmartin View Post
Looks Like I am gonna get the new 2.0 Gt speedo, Do I ned to get the box to program it? Are these in stock down in tampa?
I agree.
rclover33 is offline   Reply With Quote
Old 05-07-2011, 06:09 PM   #7054
Does running a lower wind motor such as a 10.5 with all the boost's and everything turned up not fry both the motor and speedo.
I've just got a program box and would like to try a few things out, but I would rather know what i'm doing first.
Any advise would be greatly received.
mattybucks is offline   Reply With Quote
Old 05-07-2011, 06:20 PM   #7055
SCTom's Avatar
Yes, you can damage motor and esc by running the wrong software, settings or gearing. Check the SP site for setups and watch motor temps, 160F motor temp. is about the highest you want to see.
Tom
SC10 and XXX CR buggy both supercharged by Speed Passion
SCTom is offline   Reply With Quote
Old 05-07-2011, 06:31 PM   #7056
SCTom's Avatar
I run 14 gauge wires on mine.
Tom
Old 05-07-2011, 08:15 PM   #7057
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by marcel p View Post
hey solara.
i mean after i put the 323 stoch software in my speedo and recalebrated it.
al the seting are not at zero. like boost timing was on 36 deg and turbo timing
at 24 deg boost start rpm at 4000. boost timing aceleration at 350 rpm/deg
and so
is tis normal that it starts with tis setings after programing the 323 sw.
thanks again
Those are default setting.....why would we set everything up at zero? If you don't want to try it, use the setup I posted on the website and give that a try.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-07-2011, 08:16 PM   #7058
Solara's Avatar
12 ga or 14 ga....your choice.
Old 05-07-2011, 08:18 PM   #7059
Solara's Avatar
Use the setting I posted on the website...I think I have one 10.5 setup there. But it is for ON ROAD....if you are using it on off road, you can try those 8.5 setup but gear up....
Old 05-07-2011, 09:19 PM   #7060
SpeedySST's Avatar
Thanks for the help. I found 14 guage in flo green so Im glad its gonna work. Now if I could only find white...
Old 05-07-2011, 11:36 PM   #7061
Hi,
Thanks for the reply. What's the benefit or advantage of running a milder motor, and using the boost features.
Would you use it in low grip or a twisty track and then unleash it on the straight?
Old 05-07-2011, 11:55 PM   #7062
i have got a brand new ultra sportsman v2 10.5t from my friend...it is any good? can it bear FDR of 100/45*2 ?
Molala4 is offline   Reply With Quote
Old 05-08-2011, 01:32 AM   #7063
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
V1.36 released
............and we are not going to support V1.35 anymore and thats why I removed the old version, and I will remove all the previous old version cause all the software we had so far are be found in the new V1.36
Well I guess that answers my question. Hehe thanks Solara.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 05-08-2011, 11:17 AM   #7064
V1.36 released
I would like to say thank you for the update , we are running less timing and cooler motors but the cars were so quick today
quicker then the Tekin powered 2wd's
Now to test it with my T3 and a 6.5 motor
sidecarphil1 is offline   Reply With Quote
Old 05-08-2011, 01:41 PM   #7065
marcel p's Avatar
i can confirm this my car was also great we were both faster as the tekin.
PR racing
Absima /vr racing
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
