Like Tree46Likes
Old 05-06-2011, 10:27 AM   #7036
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Thanks for the update!! Having a blast with the new ProStock speedo, v1.36 is loaded!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 05-06-2011, 02:48 PM   #7037
AWSOME , gonna try this out at the weekend , hope my buggy flies with it
sidecarphil1 is offline   Reply With Quote
Old 05-06-2011, 02:51 PM   #7038
guys, this new s/w gives you brakes from helll~! i have mine set at 50%, reverse force off, and drag brakes off! i still have to adjust a bit with my transmitter.
rich
gdcopbdcop is offline   Reply With Quote
Old 05-06-2011, 03:12 PM   #7039
Trader Rating: 16 (100%+)
rich
We heard too many ppl asked for BRAKE...so, we provide BRAKES...but remember this...
BRAKE JUST SLOW YOU DOWN!!!!
I am just kidding...but with this brake improvment, on both ON ROAD and OFF ROAD, it is a HUGH advantage (and I heard this is something extremely important in OFF ROAD)...
Enjoy it...
Old 05-06-2011, 03:14 PM   #7040
marcel p's Avatar
Send a message via MSN to marcel p
hmm to complicated
is it posible to make a comparisment from the 528 stock max seting to were the new should be to get the same resuld?
so i now where to start faster to understand for me and learn.
my 528 was wicked fast already
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 05-06-2011, 03:16 PM   #7041
323STOCK setups are here
OK....I spend quite some time to gather all the setup I have so far for both ON ROAD and OFF ROAD...mainly are for stock. But with the 323STOCK software...it is kinda confused. Because I have driver use the same car from STOCK and actually raced in MOD...same thing, running the STOCK MOTOR on MOD then back to the open stock with the same setup and gearing.
I don't know how to tell you guys....TRY IT. If you are confused...don't blame me, blame those who created BOOST....
All the new 323stock setup are here...find the class you want, I have SCT mod 8,5, to 2WD stock 17.5, 4WD mod with 8.5, TC 17.5 open, indoor carpet, outdoor asphalt, 13.5 and 10.5....
http://www.speedpassion.net/us/escsetup.asp
Old 05-06-2011, 03:18 PM   #7042
Originally Posted by marcel p View Post
hmm to complicated
Really...forget about the 528, it is so 2010....
323STOCK is the 3rd gen open esc software, totally new...it is 528 fast times 2.
Read the attached PDF and tried to understand....if you don't, just use 1 of my setup and try it.....you don't have to understand if you are WINNING, right?
Old 05-06-2011, 04:39 PM   #7043
marcel p's Avatar
thats right
i have the speedo programed and calibrated.
have a setup in it after programing. is this the start setup?
PR racing
Absima /vr racing
Old 05-07-2011, 02:38 AM   #7044
Can i use a 6.5 motor with the new 323 softwere in my T3 or is it better to use the new 119 mod softwere ?? If so do you have a rough set up jet ??
Old 05-07-2011, 01:34 PM   #7045
Could someone tell me which software is best to use that doesnt have a supercharger/turbo , such as the old 110 and 107 software
I heard use 205 MOD but im not sure as i have a 13.5T motor
Thanks for any advice
madwestmo is offline   Reply With Quote
Old 05-07-2011, 01:44 PM   #7046
thats right
See the setup page on speed passion website, I have uploaded some 323stock setup for on road and off road, from 17.5 to 8.5 motor.
Old 05-07-2011, 01:45 PM   #7047
205 is your only choice....
Old 05-07-2011, 02:43 PM   #7048
Hi,
i've just downloaded the latest firmware. Can some one recommend a setup for 4wd off road with a 5.5 v2 sp motor.
Matt
mattybucks is offline   Reply With Quote
Old 05-07-2011, 03:20 PM   #7049
marcel p's Avatar
hey solara.
i mean after i put the 323 stoch software in my speedo and recalebrated it.
al the seting are not at zero. like boost timing was on 36 deg and turbo timing
at 24 deg boost start rpm at 4000. boost timing aceleration at 350 rpm/deg
and so
is tis normal that it starts with tis setings after programing the 323 sw.
thanks again
PR racing
Absima /vr racing
Old 05-07-2011, 04:33 PM   #7050
SCTom's Avatar
hey solara.
and so
thanks again
Those settings are default I believe. Check out the setup sheets on SP site for something that might work for you.
Tom
SC10 and XXX CR buggy both supercharged by Speed Passion
SCTom is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
