Like Tree12Likes
Old 05-03-2011, 12:12 PM   #7021
Joel Lagace's Avatar
Install the desktop software, hook via usb the LCD box and update the box. I have the same HW box for my SP software and ESC;s no problems ever.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-03-2011, 12:18 PM   #7022
Hi,
I'm sure the answer is somewhere in the 400 pages dedicated to SP esc's but can someone tell me what the new firmware actually does and the benefits of upgrading the firmware.
Also what settings would you recommend for a Pro 2.0 with a v2 5.5 in 511.
Matt
mattybucks is offline   Reply With Quote
Old 05-03-2011, 12:28 PM   #7023
Flashing to certain firmwares will unlock or lock features.
For mod there are 2 versions one with timing one without.
For stock there are various versions that unlock variable timing or boost or turbo what ever floats your boat.
Currently i run my 13.5 with stock software the allows variable timing settings and my 10.5 with mod-no timing and i crank the timing at the motor.
Im sure the others will chime in with more details
www.rcottawa.com
Old 05-03-2011, 04:08 PM   #7024
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Solara View Post
Correct.........the red led should be blinking when the car is in idle.
Hi
Thanks for the reply .
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 05-04-2011, 11:46 PM   #7025
See you can ask the Hobbywing ppl (at Hobbywing thread) regarding your question I am sure they can help you there.
If you are indeed using the SP GT2.1 EX, of course we prefer you to run the SP software.........
I do want to use the SP software, just needed to know if I could use a Hobbywing box.
rich67 is offline   Reply With Quote
Old 05-04-2011, 11:47 PM   #7026
This is what i was hoping I could do, thanks for your help.
Old 05-04-2011, 11:52 PM   #7027
Is the latest software 212 suitable for a GT10 runing 13.5 & 10.5?
Old 05-05-2011, 04:06 AM   #7028
Trader Rating: 107 (100%+)
Send a message via AIM to kwiksi
Yes.
kwiksi is offline   Reply With Quote
Old 05-05-2011, 04:28 AM   #7029
chrisk's Avatar
Trader Rating: 32 (100%+)
I was about to ask the same question about using the hobbywing box as i couldnt get a SP one anywere either
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 05-05-2011, 09:24 AM   #7030
YES IT WORKS PERFECTLY
it arrived today and i upgraded my softwere then programmed my speedo with it
sidecarphil1 is offline   Reply With Quote
Old 05-05-2011, 12:11 PM   #7031
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
Default v1.35?
What happened to v1.35? On the SP Americas website, it seems like all the ESCs only have 1.33 to download.
Not that I need to download it (it's what I currently have installed on my computer and on my GT2.0 LPF), but is there a reason it's not listed for download anymore (i.e., it's not good to use)?
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 05-06-2011, 09:02 AM   #7032
Solara's Avatar
Trader Rating: 16 (100%+)
V1.36 released
............and we are not going to support V1.35 anymore and thats why I removed the old version, and I will remove all the previous old version cause all the software we had so far are be found in the new V1.36
Stop using 1212 as this is not even close compare to the new 323STOCK software. Also, try the new 119MOD supercharger software for MOD motor.
Here is the link....you guys will love it. Make sure read the attached PDF file as this Supercharger improvement is alittle different then the previous 1.35 or 1.33 version.
http://www.speedpassion.net/us/escsetup.asp
I am in the middle of creating some setup for 17.5 13.5 motor...as well as some 8.5 10.5 for mod...all are using 323STOCK software (YES, 323STOCK software for MOD racing)...and mainly in OFF ROAD setup, but I have some on road indoor and outdoor setup as well....stay tuned.
Also, new 323stock and 119mod setup sheet....
http://www.speedpassion.net/files/Sp...k_6may2011.pdf
IMPORTANT: You must update the LCD programmer from the 1.36 version before you can see the changes for the 323STOCK, it is a must do process.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-06-2011, 09:10 AM   #7033
downloading!!!
WARNING repeated. read the PDF.... LED box users will not be able to make changes without an LCD box... Not a big issue for most, but i typically flash my friend's ESC's for them and they use the LED box to make changes.. the PDF points out this wont work anymore
www.rcottawa.com
Old 05-06-2011, 09:18 AM   #7034
Solara's Avatar
downloading!!!
Thanks JOEL....LCD box is the way to go if you want to take advantage of the new update...or at least, borrow one.
Old 05-06-2011, 09:20 AM   #7035
Solara's Avatar
Speed Passion USA direct sale website is UP AND RUNNING, AGAIN
http://www.speedpassion.net/us/index.asp
Check it out, most of the hot selling item are back instock and ready for 3-4 days local USA shipping, that advantage of that....we have sold out like 40% of the inventory so don't wait, it you sees it, buy it now...
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
