Old 03-28-2011, 11:47 PM   #6841
RevMaxx's Avatar
Send a message via MSN to RevMaxx
which firmware should work best for 12th scale 1S.
am running SP V3 4.0T motor now...
esc settings would be nice...
t-i-a
RevMaxx is offline   Reply With Quote
Old 03-29-2011, 02:34 PM   #6842
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Blitzrockey View Post
Thanks, its weird I can turn the esc off then on and it works for a bit agian, it seems when the car gets bonked it does it.
Open up the end bell of the motor and reseat the sensor unit.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 03-29-2011, 02:36 PM   #6843
Solara's Avatar
t-i-a
Mod motor usually use the 205g version.....1S or 2S, don't matters.
Old 03-29-2011, 02:54 PM   #6844
Hey Solara
Is there any chance of getting a "push control" like the Tekn has in the next update from SP ???
i liked it on the tekin in the 12th because it was like an anti brake and let the car roll more ???
cheeRS Phil
sidecarphil1 is offline   Reply With Quote
Old 03-29-2011, 07:55 PM   #6845
Has anyone had problems with savox servos and the Speed Passion GT2.0 ESC's? I'm not convinced the ESC has anything to do with the troubles people are having with Savox servos and Spektrum rx's. Any input? Some claim it is the BEC in the ESC, I think it is the Rx.
Banshee8530 is offline   Reply With Quote
Old 03-29-2011, 10:04 PM   #6846
skypilot's Avatar
Trader Rating: 14 (100%+)
some claim the servo sucks to much voltage
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 03-29-2011, 11:10 PM   #6847
Hi,
I've just picked up a gt2.1 pro stock and a d3 9.5T
What software should I load on the esc? Unsure whether I should be using the modified or stock software on a 9.5T motor.
J-PaP is offline   Reply With Quote
Old 03-29-2011, 11:34 PM   #6848
The voltage SHOULD be limited by the BEC... I stress should... twice. Most ESC's have a 3.0A current capability on the BEC regardless of the Voltage value, some are 5.5V, some 5.75V, some 6V. The one constant I see is the Spektrum RX. Not trying to bash Spektrum, just wondering if anyone can offer a good explanation to the problem... are some internal BEC's not limited on Current/AMPS? I know the Speed Passion literature says it is. Has anyone had this issue with a speed passion? Will the Rx's BEC curcuitry cause this?
curious.
Old 03-29-2011, 11:54 PM   #6849
curious.
The output voltage from the ESC is regulated to 5.75 or 6 depending on model. The voltage should not drop unless there is more then the 3As being drawn from the BEC at the given moment. Running a nice big capacitor on the RX'er end (also known as a glitch buster) will help the BEC keep a constant output voltage, for when the servo needs alot of power.
Rx'ers, dont have BEC's.
Shawn68z is offline   Reply With Quote
Old 03-30-2011, 01:04 AM   #6850
I am running a Savox and a GT2.0pro without any problems ,
Its not a voltage thing it is Amps the servo wants to pull
Old 03-30-2011, 08:31 AM   #6851
tedstryker's Avatar
Trader Rating: 69 (100%+)
I'd figure I'll ask my question here i have the Speed Passion Short Course Master ESC Sensored...can you use another motor with this ESC?..I've read that this ESC doesn't work with other motors...is this true? i was looking into running a 17.5 sensored motor with it..anybody that has any experience with it or any info on what motors will work..would be really appreciated..
A.E.RC8B3E
TLR 22T 2.0
Kyosho RT5
YOKOMO B-MAX4 III
YOKOMO YZ2 DT
tedstryker is offline   Reply With Quote
Old 03-30-2011, 09:46 AM   #6852
Solara's Avatar
Originally Posted by sidecarphil1 View Post
Hey Solara
cheeRS Phil
On our next generation ESC, we will have that feature on the firmware...your request is forwarded to the HQ, thanks.
P.S...the feeling of push control vs the radio "sub-trim" setting it going forward is not the same..? I use the radio sub trim setting (set the motor roll forward) on my TC when racing 21.5 class to act as a rolling start(push) kinda effect...I would like to know what are the different between the 2. Thanks.
Old 03-30-2011, 10:12 AM   #6853
Solara's Avatar
The original/early batch of the SCM dated like a year ago can only limited to SP motors and Trinity motors. If you purchased your SCM unit like October last year and later should be able to use all motors. However, if your unit is purchased used, then it cannot be tell....see you can borrow a motor and give that a try.
Old 03-30-2011, 10:47 AM   #6854
tedstryker's Avatar
just checked my purchase order 10/25/10 looks like I'm good to go with any motor...
thank you ...
A.E.RC8B3E
TLR 22T 2.0
Kyosho RT5
YOKOMO B-MAX4 III
YOKOMO YZ2 DT
Old 03-30-2011, 10:59 AM   #6855
Isn't the bus bar in Rx's designed to allow power to come to the Rx through any servo port? I thought that was BEC circuitry... otherwise we would have two Rx leads on every esc, one for signal and one for power. That's what I was getting at, I know Rx's don't have a literal BEC, but they do have the bus bar to allow it to work. Not trying to be snotty, just clarifying.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
