Old 03-26-2011, 06:31 AM   #6826
guinnes.s's Avatar
yes i do have a timable esc HW ,what setting are u referring to when u say "boost start higher" ??
thanx
just find a sentence that may explain better the problem " is not making enough torque at the low rpms to pull the car out of the corners "
guinnes.s is offline   Reply With Quote
Old 03-26-2011, 06:45 AM   #6827
thanx
what i mean is the start revs that your timing comes in
on my Tekin you can set it to 3000 , 5000 , or so on , in the Speed passion that i use you have the option for supercharger delay , this i would set to 8000 or more and see what this does.
Some other people will come on and soon help ya more then i can
sidecarphil1 is offline   Reply With Quote
Old 03-26-2011, 02:05 PM   #6828
guinnes.s's Avatar
At moment my start rpm is at 2000, I will try at 8000.
Old 03-26-2011, 07:30 PM   #6829
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Just wondering if anyone has had this problem? I suspect a half broken wire on my sensor wire but here is the issue. I have a GT2.0 Pro Brushless ESC , and running a 17.5 in my tc car, once and a while It will all of a sudden start to loose power untill it almost dies and the throttle wont do anything but it still has steering, when I look at the led its blinking red, I can unplug the sensor wire and it revs right up perfect though? Any thoughts?
Blitzrockey is offline   Reply With Quote
Old 03-26-2011, 08:39 PM   #6830
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Yes, it sounds like your sensor wire is faulty/damaged. Replace it.
HyperRC
Xray XB2 DE // XB4 '16 // RACEOPT MTS Tē // CRC XTi
[[john]] is offline   Reply With Quote
Old 03-27-2011, 04:13 AM   #6831
LonnyJ1950's Avatar
I have a GT 2.1 EX in a 1/12th car with 1S lipo. I tried to calibrate the ESC to my transmitter, but every time I switch the ESC on it beeps the abnormal voltage signal. The battery is properly connected and fully charged. Why can't I calibrate properly?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 03-27-2011, 09:52 AM   #6832
HUTTNER's Avatar
Try hooking up a 2s battery and set the transmitter that way, also set up the esc profiles at the same time, that should work for yah. Same thing happened when I installed the EX in my 1/12th scale.
www.kyoshoamerica.com--www.speedpassion.net---www.ftrcr.com
HUTTNER is offline   Reply With Quote
Old 03-27-2011, 09:55 AM   #6833
mr crum's Avatar
Send a message via Yahoo to mr crum
you also might want to turn low voltage cutoff off cause at the end of a 8 minutes run when you hit the throttle the lipo will draw down below 3.0 so turn it off and only run 8 minutes
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-27-2011, 07:26 PM   #6834
Default Speed Passion Question Legal Programming issue
Hello Guys'
and Solara,
i have a question, is Speed Passion have any Legal Issue according to Programming "Flashing" through Rx Wire , in US ?
flashrevolution is offline   Reply With Quote
Old 03-27-2011, 07:42 PM   #6835
Originally Posted by shadowracer24 View Post
Would not work in mine. Would keep going into throttle signal loss mode and cut power in half every time I would hit full throttle. Good esc just not meant for the scte.
Just put it in my scte and It worked awsome, went like a raped ape !!
Old 03-28-2011, 11:30 AM   #6836
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Blitzrockey View Post
Just wondering if the GT2.0 Pro Brushless ESC will work in the losi ten-scte with a 4.5 550 motor? My buddy has used it all last year in his hyper 10 sc with a novak 4.5 550, and worked perfect. Thanks.
Yes...it will, as long as you are running ONLY 2S lipo.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 03-28-2011, 11:33 AM   #6837
Solara's Avatar
Either the sensor wire or the sensor unit inside the motor are damaged.
Old 03-28-2011, 11:42 AM   #6838
Thanks, its weird I can turn the esc off then on and it works for a bit agian, it seems when the car gets bonked it does it.
Old 03-28-2011, 06:32 PM   #6839
LonnyJ1950's Avatar
Ran my GT2.1 EX for the first time on Sunday. I think it's a bit silly that you must do your set up with a 2S lipo. I run 1S only and had to wait till I got to the track, then scrounge up a 2S before I could use my ESC. I hope you don't need a 2S every time you want to adjust the settings or this will be on E-Bay real quick.
Lonny
Old 03-28-2011, 08:24 PM   #6840
skypilot's Avatar
Trader Rating: 14 (100%+)
you only need the 2s to turn off or down the voltage thing, after that your good to go
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
