The Speed Passion Thread
#6736
Solara, I just ordered my Silver arrow v2.0, my question is do I need to get the programmer too or does the esc come with a stock setup already programed into it ? and does the Speed Passion Multi ESC Programing Box #SPASCPB01 work with the arrow 2 ? Oh and just a little more info I will be running a Orion 1950kv sensorless motor with the Silver arrow
#6737
Hi Solara
i have the latest 17.5 T motor and was wondering about timing on the motor from factory looks to be about 4 or 5 deg ? in the middle of the slot and i was wondering running a stock class with no timing on the esc which is the SP as well as it was the package i brought , what gain will i get from turning the timing up to the 10 deg mark on the motor?
#6740
2.1 EX with stock.
Hey Guys.
Just trying to update my new 2.1 EX esc. Will it run with the newish 528 stock update or only the 205 mod software. Have done the update on the esc and then when connecting to the LCD box it says the software needs to be updated. Got a large race meeting this weekend and am only running 10.5 v3 motor so need stock profiles. Any help will be great.
#6741
do you have a good motor for a 4wd short course I was looking at the silver arrow 1/8th 5.5, is it going to be the same as a 550 5.5 from other manufacturers and will it work ok with my lrp tc sphere speedo? For $69 it looks like a great deal
I am going to run it on 2s so I was hoping that I could find something in the 3000 - 3500kv rating
#6742
Hi Solara
and the track i run on it largish with 20 to 35m long striaghts i am running a 72 spur and thinking about going up to a 37 or 39 pinion?
as i currently run a 72 / 32 and i hit full speed 1/2 way up the straight
any help would be great
car is a XRAY T2 2009
I don't know what is T2 internal is but for 17.5 V3, you can try running 3.7~4 final and check motor temp and feel after like 5-7 laps.
I think you can gear up more...no timing ESC is totally awesome.
#6743
For those who are using no timing ESC and want to get more power out of the SP motor......we are releasing the 11-20* timing ring very soon and currently are testing the 21-30* timing ring with the special protection ring within (due to the high timing)...
If things are working out....the entire V3 motor series will have a whole new power band to choose from and the no timing ESC racing is no longer the same afterall.
#6745
For 4WD SCT....Cirtix Slotless series (2200 and 2500) or Silver Arrow II series (5.5 and 6.5) are the motor to have....
We don't call out Kv on some of these motor because our Kv reading is different then other brand's Kv reading and we were used to compare our data to other company and alot of our customer got confuse afterall.
If running on 2S lipo...GT2 PRO is the ESC to use.
#6748
I'd recommend contacting SP HQ at '[email protected]' as this is what Solara suggested I do..
Best regards,
John.
#6750
It is a better unit, cooler looking, can connect to computer, and you can download and upload the lastest software for SAII ESC in the future. This unit can do everything the multi-esc card does plus more.
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
