Old 03-13-2011, 11:46 PM   #6721
[[john]]'s Avatar
Trader Rating: 24 (100%+)
What temps should I be aiming for after a 2 minute run with a boosted 21.5 ?
60C ?
I have read to try and keep the temp close to 90C after a 6 minute run, but I don't want to run that long before I go up or down on the pinion.
Thanks in advance.
HyperRC
Xray XB2 DE // XB4 '16 // RACEOPT MTS Tē // CRC XTi
[[john]] is offline   Reply With Quote
Old 03-14-2011, 12:19 AM   #6722
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
Looking for a little help/advice. I'm trying to figure out what wind motor I should get for my Ve8. I currently have a Tekin 2050kv motor and speedo. I'm looking for slightly less power/more run time. Are any of the Silver Arrow motors comparable power wise to the Tekin 1900kv or 1700kv motors?
Thanks in advance.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Old 03-14-2011, 11:10 AM   #6723
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by [[john]] View Post
Even though I am located in Australia? I don't mind paying.
How would I go about getting in contact with him?
Thanks!
Since you are from Australia, contact the HQ...
Explain your case with them and they will bill you (paypal) the lower cases and shipping...
email
sale@king-golden.com
Mention you have talked to HOWARD on Rctech and I refer you to contact the office here....
Good luck...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 03-14-2011, 11:12 AM   #6724
Solara's Avatar
Originally Posted by irgo View Post
Talk about case,
Solara, Will Speed Passion release Case gasket, for SP GT2.0 and GT2.1 ?
Shielded case or something like that...
ex: "Highly water-resistant case with protective silicone gasket"
No...cause there are none right now.
Old 03-14-2011, 11:16 AM   #6725
Solara's Avatar
Originally Posted by Nilks View Post
Hi guys,
I am considering using a Speed Passion ESC for modified TC. How is the feel of the SP ESC?
The LRP's have great feel, and my Tekin is a disaster in modified. So wanted to know how the SP ESC compares to the LRP's.
Won the WORLD CHAMPIONSHIP 2X...that is better then words.
SP ESC is very famous about the SMOOTH drive even on MOD motor, and the BRAKE performance is outstanding...you won't be disappointed.
Some mod ESC setup can be found here...
http://www.speedpassion.net/eu/escsetup.asp
Old 03-14-2011, 11:19 AM   #6726
Solara's Avatar
Originally Posted by littlealex View Post
can new ex 2.1 handle 2s lipo for touring car?
No...not for TC. EX is only allow to be used on 1/10th WGT direct axle chassis.
Old 03-14-2011, 11:21 AM   #6727
Solara's Avatar
Originally Posted by big_alex39301 View Post
I have a GT 2.0 lpf esc running 508 software and I just got a 1/12 scale pan car. Will the ESC run single cell lipo.
I have yet to try the booster or receive packs on the LPF myself...cause I only use the EX for 1S racing. But I heard 50/50 about some works, some doesn't...you best bet is use GT2 EX.
Old 03-14-2011, 12:38 PM   #6728
Solara's Avatar
Thanks in advance.
2200kv are what most of our 1/8th driver use...
SAII series motor can be used, I would say 8.5 and 9.5 are good.
We don't have the formula to tell which motor is how many KV and this and that...those number are no longer correct and I stop finding them and just run the motor.
Old 03-14-2011, 12:54 PM   #6729
Solara's Avatar
Originally Posted by flashrevolution View Post
Hello Guys, is there any Temp Sensor in SP Motor ex : V3.0
and can SP GT 2.0 Pro and Lpf read Motor Temps ?
No temp sensor in all SP motors...
Old 03-14-2011, 12:55 PM   #6730
Solara's Avatar
Originally Posted by sidecarphil1 View Post
ok and do you have a good starting set up for a asphalt track with a 60mtr straight ???
use MARC setup here...
http://www.speedpassion.net/en/escsetup.asp
Gear to 7.5 to 8 and try it...
Old 03-14-2011, 01:03 PM   #6731
Solara's Avatar
Originally Posted by mdwalsh View Post
im looking at the Speed Passion Cirtix 17.5 turn spec motor and such for my older XXXS just to do some fun club racing. and i have a couple of questions about the esc
does it have lipo cut-off?
this whole gearing thing kinda confuses me, any tips?
can you use the lcd programmer to change the few parameters you can change?
btw im coming from my very old GSC V8 esc and a Trinity 17 turn brushed motor. i have zero experience with lipos and brushless set-ups
thanks in advance
Matt
Yes...but they are pre-set (cannot be adjust) 3.4V/cell
17.5 can be gear from 3.75 to 4.25...depends on your timing set on the motor.
No, you cannot use the SP LCD programmer to setup the cirtix club spec...you have to use the Cirtix LED Programmer box...you cannot use the USB connector.
If you have more question, just ask here...
Old 03-14-2011, 01:09 PM   #6732
Solara's Avatar
60C ?
Thanks in advance.
If you are temping your motor for the ESC performance or both...I only temp my motor for no more then 5 laps (not minutes)....cannot be exceed 180*F = 82*C
Sometime I will let go for 190*F if it feels good, but agian, that is the absolutely MAX for all SP motors....87*C
If you are hitting 90*C you are really RED LINE your SP motor.
We have setup for the latest 1212 software with 21.5, look here...
Old 03-14-2011, 09:37 PM   #6733
[[john]]'s Avatar
Thanks Solara!
Your help is greatly appreciated!
HyperRC
Old 03-14-2011, 11:05 PM   #6734
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
do you have a good motor for a 4wd short course I was looking at the silver arrow 1/8th 5.5, is it going to be the same as a 550 5.5 from other manufacturers and will it work ok with my lrp tc sphere speedo? For $69 it looks like a great deal
I am going to run it on 2s so I was hoping that I could find something in the 3000 - 3500kv rating
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 03-14-2011, 11:30 PM   #6735
DBL15's Avatar
Hi Solara
i have the latest 17.5 T motor and was wondering about timing on the motor from factory looks to be about 4 or 5 deg ? in the middle of the slot and i was wondering running a stock class with no timing on the esc which is the SP as well as it was the package i brought , what gain will i get from turning the timing up to the 10 deg mark on the motor?
and the track i run on it largish with 20 to 35m long striaghts i am running a 72 spur and thinking about going up to a 37 or 39 pinion?
as i currently run a 72 / 32 and i hit full speed 1/2 way up the straight
any help would be great
car is a XRAY T2 2009
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
