Like Tree8Likes
Old 02-28-2011, 02:31 AM   #6631
Originally Posted by honhon View Post
could anyone post a picture of the citrix stock spec mounted on a touring car, and make or model is fine, i just want to see it mounted and try to do a size comparison...
its without fan, no need when useing ETS Legal
tiny
thilo-alexander is offline   Reply With Quote
Old 02-28-2011, 04:19 AM   #6632
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by Bumpy View Post
Mr Crum; We run 2s. I run Speed Power saddle packs. Should have also mentioned that the esc and motor ill be using are 2.1 prostock and V3 13.5. Cheers
wow that will be a beast i run 1s im guessing that if you use one of the touring car setups from the sp site that will get you closed how big of a track
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 02-28-2011, 06:52 AM   #6633
Tech Legend
Cain's Avatar
Trader Rating: 222 (100%+)
anyone know the warranty length in the USA?
< RC10B6D x 2 | Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 02-28-2011, 08:05 AM   #6634
tiny
do you think 17.5 RCGT would require a fan?
honhon is offline   Reply With Quote
Old 02-28-2011, 08:07 AM   #6635
we ran 13,5 speedpassion on ETS europe Stock class.
i dont think with any Motor higher than 10,5
a fan is requiered. ESC dont get higher than 40 Celsius
Old 02-28-2011, 09:26 AM   #6636
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
It depends on the temp outside....if its above 80deg F then yes I would run a fan with a 17.5 just to make sure. If you are using it inside or on carpet with a 17.5 then I wouldnt run one.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-28-2011, 10:19 AM   #6637
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default Citrix Stock Spec
Here you go. I just removed my Tekin and installed it. It's just a little smaller than the Tekin. Ran the exact same time with it as my Tekin so i was impressed.
jgraham37128 is offline   Reply With Quote
Old 02-28-2011, 01:58 PM   #6638
it would seldum be run on pavement outside, maybe even never... mostly on a carpet air conditioned track inside.
Old 03-01-2011, 01:04 AM   #6639
Yeah you're not wrong there. I ran the car at my country's National champs 3 weeks ago down here in New Zealand and took away the top spot in Pro10. Very happy with that but had some issues with the LRP setup I had in the car so have now on-sold that and am now changing to Speed Passion in all my cars. Thanks for the help.
Bumpy is offline   Reply With Quote
Old 03-01-2011, 04:05 AM   #6640
mr crum's Avatar
your welcome thats what us team drivers are here for
TEAM B.R. RACING
Old 03-01-2011, 07:34 AM   #6641
kwiksi's Avatar
Trader Rating: 103 (100%+)
Send a message via AIM to kwiksi
Anyone have the latest setup sheet thats used with 212?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - PT Racing Oils - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 03-01-2011, 08:25 AM   #6642
hi guys, i will be using this in a WGT car. will be running a 13t motor with boost, 1 cell. the track is a small and tight indoor carpet. what settings should i start with? i have a regulator and a 850 ma batt for steering.
gdcopbdcop is offline   Reply With Quote
Old 03-01-2011, 05:02 PM   #6643
mr crum's Avatar
i dont know if my new sheet is on the site but the old one is for sure that would be a good start
TEAM B.R. RACING
Old 03-03-2011, 06:50 PM   #6644
Currently what is the new firmware of the SP? And do you guys have the good setup for 11.5t? I'm still newbie
mizah is offline   Reply With Quote
Old 03-04-2011, 06:00 AM   #6645
scoyle's Avatar
I noticed today that you can update the USB programmer as well as the speed controller...
Up until now I have used a Hobbywing USB programmer to put the new software onto my GT2.1 ProStock and then changed the settings with the Speed Passion programmer that came with the speedo.
Is this correct or should I be updating the Hobbywing programmer and then using that to do my programming - and why do I need to do that?
Hope that makes sense...
scoyle is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
