Like Tree3Likes
Old 08-31-2009, 04:20 PM   #646
wiscnitro's Avatar
Trader Rating: 22 (100%+)
Originally Posted by MikeXray View Post
DRRS is like throttle delay, its kinda cool, I messed with in on my 2wd buggy and even driving it on wet ground, with a setting of 3, it would roll out for like a foot, then ramp up to full throttle.
ATS is your timing setting, the "ramp rate" isn't adjustable with the setting box, you just adjust the max timing you want, the best setting depends on what motor and type of racing you are doing.
I race VTA I have run my DRRS setting full on the track we were on was so big and the streight so long I ran my ATS max with a 4.23 gear and I was topping out just before the end of the streight. I have my throttle travle to max on my TX 150% and the DX3S has a Throttle punch setting I have set to 20% should I even bother with the punch setting or anything else I should change? I went from a Havoc to a GT2.0 so you can guess how confused I am with all the options to do what I want.
Hold my beer and watch this! :)
wiscnitro is offline   Reply With Quote
Old 09-02-2009, 12:00 AM   #647
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Default sensor
got the sensor today through RC Plus......Thank You!!!!!!!
now for the Duh question....
Are the LPF 2.0's approved by you yet/officially to run single cell voltage 3.7? (I'm setting up to run 13.5 single cell 12th indoor carpet, I have LPF2.0, original 17.5 and 13.5 patiently waiting for v3's)
I want to run a rec pack (12th scale) 5 cell 1/3 AAA ......what's the magic wiring formula to do this? Does the set-up button on the switch play into how this should work?
In the past (GT 1.1 4 nimh cells) I just pulled the red wire....(speedo to rec red wire).....plugged in the rec pack with it's own switch to the rec. To fire it up, I would turn on both switches. To initially program speedo I would hook up motor batt, push and hold button while turning on speedo switch.......to change speedo settings I would pull speedo rec plug from receiver, reinstall said red wire into plug....plug this into program box, with motor batt plugged in, turn on speedo switch, max all settings that needed maxing. turn off, pull said red wire blah blah blah as above.
I sure miss the original thread....knowledge lost to the moderator gods
Just to be sure I have not missed anything I went and reread this entire thread....Andrewdougherty touched on this subject briefly....but I believe he chose to use the booster routine instead. Which makes me think you should still pull the rec red wire.....correct? Two power source paths usually = SMOKE.
pic of last years gt 1.1 setup with rec pack (green) to the left, caps to the right, rec switch behind left front tire, speedo switch behind right front tire. Motor has long since been Upgraded
Did I by chance figure it out, or am I still lost in the 70's? Thanks Shawn and Adam!
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 09-02-2009, 05:42 AM   #648
abailey21's Avatar
Trader Rating: 36 (100%+)
I didn't even read more than one sentence before I saw an issue with your setup.
The GT 2.0 is fine on 1S, I do NOT run the LiPo cutoff because of the low voltage.
As for the radio/esc calibration I calibrated mine BEFORE wiring up the booster. So I set mine up like another 12th/TC/Off Road.
After the radio calibration I wired up my booster and run as per the booster instructions.
If you already have the booster wired up just turn on the esc, NOT the booster for your radio calibration. After calibration then you'll use the booster.
If your using the receiver pack, replace the word "Booster" and put in "receiver pack" lol
As for wiring the receiver pack i have never seen someone run a switch on one. They just wire it directly to the batt plug on their receiver
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-02-2009, 06:26 AM   #649
Drillit's Avatar
OKay.......I git the calibration part. Now if using either a booster/rec pack shouldn't I leave the esc switch OFF when the rec pack is turned on?
I should clarify, I am not using one of the new-fangled boosters(tq,novak,etc)of course tq would say "turn on the esc switch if your esc has LiPo cut-off.......but you should check with your esc manufacturer for sure..."
are you ready/willing for phone call ?
Thanks,
Mark
Mark Tilley
Old 09-02-2009, 06:34 AM   #650
abailey21's Avatar
Thanks,
Mark
I'm on a call right now but give me like 10 minutes
K.C.C.O.
Old 09-02-2009, 06:43 AM   #651
Drillit's Avatar
cool.......shawn's got me on hold
crap, my connection failed! I'll be back......
Mark Tilley
Old 09-02-2009, 06:45 AM   #652
M-Technic's Avatar
Trader Rating: 15 (100%+)
Adam, do you guys have an ETA on the 17.5 v3.0 motors? I'm hoping to pick one up before the first state race.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-02-2009, 06:46 AM   #653
abailey21's Avatar
I'll be cutting it close to the state race but i should have some before the race... I hope
K.C.C.O.
Old 09-02-2009, 07:09 AM   #654
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Hey Adam Im going to the state race but only on sunday let me know if you want to carpool
Old 09-02-2009, 07:22 AM   #655
scoyle's Avatar
Guys, just bought a Speed Passion GT Pro V2.0 for our indoor season and I am looking to get some setup advice...
The track has plenty of grip and I was planning to go up on the start mode (or DRRS) to about 7 or 8 and put the timing at about 15 - 18.75 degrees.
And then tune for gearing to keep temperatures down. Hoping that this will be punchy enough for the shorter carpet track we run on indoors (slightly shorter than a basketball court).
scoyle is offline   Reply With Quote
Old 09-02-2009, 07:33 AM   #656
Drillit's Avatar
Default Rec pack / booster
Adam.......Thanks So MUCH !
I got IT.....once all set-up, esc switch ON, and rec batt plugged in to rec (switch ON) red wire left alone/not pulled.....go play
While you'r in Vegas.......who's runnin' Boosters and/or Rec packs?
Mark Tilley
Old 09-02-2009, 07:36 AM   #657
abailey21's Avatar
What motor? If it's a 13.5 that sounds about right for a start point
YESH!
K.C.C.O.
Old 09-02-2009, 08:45 AM   #658
MikeXray's Avatar
Trader Rating: 72 (100%+)
Sounds like a good setup, with a 21.5 you can throw pretty much everything at it
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-02-2009, 08:48 AM   #659
abailey21's Avatar
Agreed, I would top everything off on 21.5
K.C.C.O.
Old 09-02-2009, 02:40 PM   #660
scoyle's Avatar
Oops running a 10.5 indoors
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
