Like Tree46Likes
Old 01-29-2011, 02:15 PM   #6436
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Guys...any ideas with this one...
Running 21.5 with 212. During the runs/races the car was strong until around the 4 minute mark and would then fade by around 0.4-0.5s per lap(sometimes more). Races are 6 minutes in length. Motor always ran around 65 -70*C.
SP 21.5V3 timing in middle
5.94 FDR
#4 8
#9 7
#12 8
#13 2
#14 3
#15 3
SchuMi2 is offline   Reply With Quote
Old 01-29-2011, 04:26 PM   #6437
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
5.94 FDR
#4 8
#9 7
#12 8
#13 2
#14 3
#15 3
Welcome to the world of 21.5 open ESC racing. You need to be spot on with gearing and esc timing to make them fast for 6 minutes.
For 80-90ft track we are gearing between 6 and 6.5 FDR.
Timing on the motor set to MAX
DDRS set to 7
Timing set to 1 below the MAX setting
Timing RPM start at 1800 RPM
SC timing set to 1 below the MAX setting
SC delay 0.2
and the #15 setting at 3 or 4
Above should last the 6 minutes without significant fade.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 01-29-2011, 04:35 PM   #6438
SchuMi2's Avatar
DDRS set to 7
SC delay 0.2
Jimmy
Thanks Jimmy...
Tried those settings(I think you posted them back a few) and the car was slow although it didn't fade as bad. Overall race time was slower too even without the fade. The 6.0 seems to be close if not where it should be judging from the times and overall feel of the car.
Cheers
Old 01-29-2011, 05:01 PM   #6439
g12314's Avatar
Thanks Jimmy...
Cheers
If you like the feel of your 13, 14, and 15 settings I would try reducing the #12 setting a few clicks. Car will feel a bit slower going down the straight, but will help make it past the 4 minute mark. You can also try increasing #15 by one as it will help with the fade, but again will feel a bit slower overall.
Just a side note, did you have the motor timing at MAX for the settings I posted?
Old 01-29-2011, 05:45 PM   #6440
SchuMi2's Avatar
Thanks Jimmy...
Timing is set to middle. Tried max but felt better set to middle. When fade started I found myself on full throttle a lot more. Would changing #14 to a higher value help?
Cheers
Old 01-30-2011, 12:01 AM   #6441
chinaman's Avatar
Does anyone know how much fixed timing is there in the SP V3 13.5T motor?
Cheers.
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 01-30-2011, 09:10 AM   #6442
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
it does not have fixed motor timing but has a range you can go from 0* to 10*
TRXRACER99 is offline   Reply With Quote
Old 01-30-2011, 10:30 AM   #6443
scoyle's Avatar
I have a spare SP 2.1 ProStock and I am planning to do a bit of off-road racing this summer. Two questions;
What is the lowest mod motor I can safely run with the SP 2.1 ProStock?
Do I need to load specific software (it currently has the 528 Stock s/w on it)?
scoyle is offline   Reply With Quote
Old 01-30-2011, 11:15 AM   #6444
jackdani's Avatar
hi everyone!
i would like to ask some questions.
i m now running sp gt v2.1 prostock ESC and a sp v3 13,5 motor...
the combo work really well.
yesterday decided to buy even a 10.5 motor in order to try that category,
but i got a LRP vector x12 10,5....i found it mint and it was a great deal so i couldn' t refuse..more i was curious to try that brand of motor.
-my question is how do you think the will work together, the sp ESC and LRP motor?
-can i just connect the esc sensor wire to the lrp?
-and as i have only one esc i will swap motors even frequently, what do you suggest to do to make it easyer:
is better maybe solder 3 wires to the new motor and leave theme here (as the sp motor have pin system) and every time i change it, work on the solder only on the esc? will be fine work on the esc everytime?
-last question, do i need to reset the radio every time i give the esc a different motor?
p.s. at my track i run final ratio beteen 6 abd 5,5 with the 13,5 as the track is short and i keep low temp, which ratio would you use for the 10,5?
thanks a lot!!!
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 01-30-2011, 11:17 AM   #6445
jackdani's Avatar
Cheers.
i came to learn this thing few days ago!
that timing go between 0 to 10 and you can see it on the bottom of the motor.
usually timing is set to 0 but u can change it opening the motor a little bite and rotate the sensor wire support!
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
Old 01-30-2011, 12:15 PM   #6446
TRXRACER99's Avatar
I ran the 2.1 in my mod buggy over the summer and found it works ok with a 7.5 motor but the question is what motor are you planning on using?? if you use a 7.5 with most of the setting turned almost off then u should have no problem but if you are running like a 4.5 then i would suggest not to.
Old 01-30-2011, 12:20 PM   #6447
TRXRACER99's Avatar
Originally Posted by jackdani View Post
hi everyone!
thanks a lot!!!
u should have no problem with the sensor at all but the way i used to swap out my motors were with 2 sets of wires with a set for each motor and just soldering to the esc just be sure not to get the esc to hot when soldering. and you dont have to re calibrate the esc every time. As far as the FDR goes use the same one for now and just play with a few different pinions you will probably use a smaller tooth pinion when using the 10.5
Old 01-30-2011, 03:34 PM   #6448
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Instructions say you can run down to a 5.0t IF you run something other than whats preprogrammed with the speedo. Says so ....click on the link.
http://www.speedpassion.net/uploadfi...pt14th2010.pdf
Just use 205 software if your using 10.5 and lower.
What are your plans? Motor? Class?
kwiksi is offline   Reply With Quote
Old 01-30-2011, 11:40 PM   #6449
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
While using the stock option software, can u use the timming option in stock 17.5 non boosted? I turned the boost off.
Blitzrockey is offline   Reply With Quote
Old 01-31-2011, 06:58 AM   #6450
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by irgo View Post
sorry solara.
V2.0_101212STOCK
previously is V2.0_100528STOCK
both are same old version 2?
so, what is the difference between them ?
If you try it, then you will know the different...Have you?
I can tell you a simple answer, the 2 software are different. And NO, there are still no RPM log, probably will never be.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
