Like Tree12Likes
Old 01-25-2011, 07:58 PM   #6391
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Lilhill View Post
Just updated my speedo software to 101212STOCK and is a little unsecure of how to setup everything, how is motor temp on 1212 compared to 528??
With 528STOCK I ran my SP Ver. 3 17,5 motor and FDR 4.3 on a large indoor carpet track, motor timing was standard (In the middle, 5 degrees I guess). And ofcourse 7.4v LiPo in my 1/10 TC.
With this setup I ran every speedo setting maxed out and the motor was about 85degrees celsius after 5min heat so OK.
Do I have to change motor timing to 10degrees? I would like some advice because if I do this, the FDR should be different also.
With the setup I ran I needed more punch out of corners, but laps were faster with FDR 4.3. The new 101212STOCK software might solve this, with lower SC boost RPM right?
running EVERYTHING maxed out, is NOT the fast way around.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 01-26-2011, 04:42 AM   #6392
I tested the settings one at a time and the laps got faster and faster and these settings put me in the A-main at our nationals. Speed on the straights were good but just needed a little more punch. But you're right, I think this can get faster, I just don't know what to do to make it faster. I have considered testing the motor timing, but I know that changing this can cause seriously changes to motor temp, so wanted to know if anyone had some experience on FDR and speedo settings when changing the motor timing =)
Lilhill is offline   Reply With Quote
Old 01-26-2011, 09:27 AM   #6393
irgo's Avatar
Default Speed Passion Interface 1.35
i must appreciate Speed Passion,
but still i don't get it, why in this new interface version
we can't saved or Import Export Settings from
PC Interface Software ???
Quark Force
irgo is offline   Reply With Quote
Old 01-26-2011, 10:52 AM   #6394
Solara's Avatar
Trader Rating: 16 (100%+)
(1) 10* timing on the SP V3 motor...give it a try, I never used the stock 5*..always max.
(2) http://www.speedpassion.net/uploadfi...oAsphalt_2.pdf
(3) Checkout this page for other setup...don't know exactly the size of your track but we have setup from 35 x 70 small carpet, to 125 x 275 1/8th on road track...just go thru the setup and try them.
http://www.speedpassion.net/us/escsetup.asp
* PS...remember, when using the new 101212STOCK software on 17.5 or 21.5 motor, item #13, option #1 is actually 1800 rpm...please read thru the write up and adjust the setting accordingly.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-26-2011, 11:24 AM   #6395
irgo's Avatar
Default Whoops
those Firmware is stuck as 528, the 101212Stock is V2,
and For some one above confuse about this new 1.35 PC Interface
updates, the LCD Firmware has the old version "V1.06 100617"
, So... What's happen on with these beta version ????
Quark Force
Old 01-26-2011, 04:04 PM   #6396
mr crum's Avatar
Send a message via Yahoo to mr crum
hey irgo will u be at snowbirds
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-26-2011, 04:30 PM   #6397
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Anyone got any input.
Regards
Gary
Originally Posted by GSM Storm View Post
Hi all
Using a GT2.0 ESC with 528 Mod software, running a 4.5 motor, what settings have you found work well for the drag brake and the initial brake force.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 01-26-2011, 07:04 PM   #6398
defcone's Avatar
Trader Rating: 15 (100%+)
Regards
Gary
These two options will be based on personal preference, initial brakes I found with mod motors is enough at 0% or =drag brake force. Just test them out at your track.
defcone is offline   Reply With Quote
Old 01-26-2011, 08:36 PM   #6399
RCHR Racer's Avatar
Yes, please download this latest one from today and upload to 1.35.
Yes...it is the newer version then 528STOCK and you should try it (101212STOCK). It is not just for ProStock 2.1 it is for the whole GT series ESC. We leave the 528STOCK there because some ppl prefer that version over the new one.
Is the power band the same in the newer firmware, besides the SC ? are these two options shown the only difference for adjusting and feel?
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 01-26-2011, 11:50 PM   #6400
irgo's Avatar
i reply to your Ym.
Quark Force
Old 01-27-2011, 02:44 AM   #6401
Coldn's Avatar
Send a message via MSN to Coldn
in instructions of this new software, the SpeedPassion recommend that we dont use with motor 10.5T. why?
I use Stock 10.5T motor at a championship on a big asphalt track
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 01-27-2011, 02:28 PM   #6402
Solara's Avatar
I am really confused about what you are trying to say....really.
Actually, it is not the 1st time....
Old 01-27-2011, 02:31 PM   #6403
Solara's Avatar
Power band was told increased within the software between the 1108 version and the 1212 version (house setting, without adjustment). I would simply try it and find out from your laptime and you can tell me your finding.
Old 01-27-2011, 02:43 PM   #6404
Solara's Avatar
Originally Posted by Coldn View Post
in instructions of this new software, the Speed Passion recommend that we don't use with motor 10.5T. why?
Running the STOCK supercharger software on 10.5T and faster motor required some serious knowledge and experience. We don't recommend that simply because we do not want to see those who are not experienced enough on SC software, run MAX OUT setting on the software, get fast for 2 minutes and get their mod motor blew up and then claim their motor blew up because of the software....(liability issue).
If you are confident enough and know what you are doing about the STOCK SC software on any mod motor....go right ahead. The software itself will work with any motor, as long as you know the setting and gearing...motor/esc failure due to the inappropriate setting and usage is not covered by the warranty.
Old 01-27-2011, 06:04 PM   #6405
irgo's Avatar
sorry solara.
V2.0_101212STOCK
previously is V2.0_100528STOCK
both are same old version 2?
so, what is the difference between them ?
Quark Force
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
