Like Tree12Likes
Old 01-12-2011, 04:04 PM   #6316
lochness42's Avatar
Originally Posted by Sean Williams View Post
Hi Lochness - I personally got the capacitor from Marc....2200uf 25V.
Weekend after weekend my car is up front..... well due to driving and mechanics of course, but I have had no issues with the capacitor.
The picture on the amazon web is of a smaller capacitor, but when you recieve the 2200uf 25v from amazon its long and narrow.
Ah ok, thanks a lot Sean. I do belive it's it, just wanted to make sure that there wasn't typo.
I used to use some low resistance quick charge capacitors with 12V 4700uF characteristic on my LRP.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-12-2011, 04:15 PM   #6317
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If you guys want to use the capacitors that Team Tamiya is using for touring cars w/SP esc's.......here is the link. They work awesome!
http://www.amazon.com/gp/product/B00...ef=oss_product
That's awesome. To replace the 4 bank caps with a single one.... Been wondering if there was another alternative. Thanx for the tip.
kwiksi is offline   Reply With Quote
Old 01-13-2011, 10:00 AM   #6318
irgo's Avatar
Originally Posted by smilekt View Post
any news about SP SW update ?
near after those hw firmware is released, there would be the new one for sp.
Quark Force
irgo is offline   Reply With Quote
Old 01-13-2011, 02:31 PM   #6319
b-man777's Avatar
Hey all: Just wondering are speed passion motors and speed power batteries owned by the same company? I ask this because some drivers are sponsored by one ,but not the other. Thanks for the info
b-man777 is offline   Reply With Quote
Old 01-13-2011, 02:49 PM   #6320
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by b-man777 View Post
Hey all: Just wondering are speed passion motors and seep power batteries owned by the same company? I ask this because some drivers are sponsored by one ,but not the other. Thanks for the info
Speed Power is a branch of Speed Passion...and yes, they are part of the company to each other.
And yes too...some driver are sponsored by SPEED POWER but not Speed Passion, for example, Ryan Lutz. It is all about the drivers decision and their contract.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-14-2011, 02:58 PM   #6321
Joel Lagace's Avatar
i run 13.5 with boost software. I want to run without boost. Should i flash back to mod software or are there recommended values i can set the superstock software to that wont totally dog the power on my motor?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-14-2011, 03:44 PM   #6322
Isn't the bank of capacitors actually a bank of capacitors and diodes (the surface mount components on the bottom of the PCB). I believe the combination of capacitors and diodes is used to suppress noise and a single capacitor should not be used on its own. Maybe someone who knows about these things could clear this up?
Rocking Donkey is offline   Reply With Quote
Old 01-16-2011, 11:46 AM   #6323
Need advice please. My son was testing our new 1/12th CRC today for our upcoming nationals. Everything on this car was being used for the first time.
Our problem was the high temperature on our V2.1 EX ESC.
The setup
-motor is the new SP 3.5T 1 cell motor (standard timing on motor)
-ESC setup: / punch at 6 / motor timing at max / no brake
-factory software on ESC
-battery SMC 5600 60C
-ESC caps connected
-car in normal running condition and making good laps
On the first run we had the thermal shut down disabled and car made 8,5 minutes OK. After the run the ESC's cooling element on top was really hot. The car had very good speed compared to a couple of A-finaslist drivers' cars.
For the second run we dropped the punch setting to 4 and enabled the thermal shut. At around 4-5 minutes into the run the the motor shut down. Waiting a minute and booting the ESC helped and the car run another minute or so.
What setting affects speedo temp the most punch, timing or ...
The setup should be within specs for the V2.1 EX. There is no room for a fan under the Protoform AMR body.
jarkko is offline   Reply With Quote
Old 01-16-2011, 12:12 PM   #6324
Send a message via MSN to geubes
Ok so a strange question:
I know its not recommended but is it possible to run a 3.5t motor on a Speed Passion gt2.0 lpf without it melting?
geubes is offline   Reply With Quote
Old 01-17-2011, 12:00 AM   #6325
Trader Rating: 69 (100%+)
Exclamation Cirtic Club Spec Lost All Brake Power
Hey Solara, I ran my Cirtix Club Spec at TCS Regional today and I found out that my ESC's ABS Brake is totally lost no matter how I set it using the program card (0% or 100%). Basically, I lost my brake on the ESC. But something I didn't understand is that, drag brake still works (my only other alternative since I don't like to run drag brake).
I've reset the ESC a few times and still had the same issue. Is my brake FETs blown? How can I get a warranty if it is defective?
Thanks.
eComet is offline   Reply With Quote
Old 01-17-2011, 01:30 AM   #6326
lochness42's Avatar
The setup
-ESC caps connected
I would think that part in bold is source of problem. Way too much timing on 3.5T motor.
Pavel Balint
Old 01-17-2011, 03:17 AM   #6327
The reason for the high temp of our V2.1 EX ESC may also be in the gearing which was a little bit on the long side at 32,8 mm.
But still I am wondering which element is the most likely cause in mod 1/12TH for high temp at ESC, punch or timing setting at ESC or gearing or something else.
Motor temp was normal and too long gearing would mainly heat the motor, I guess.
Aside from the temp cutting the SP V2.1 EX + SP v3.0 1-cell 3.5T combination was just great to drive and very fast compared with the 3 other nationals A-finalists that were also there. Just need to be able to continue to the 8 minute mark.
Old 01-17-2011, 12:50 PM   #6328
cyclone speed's Avatar
Ok hmm, iv'e been looking on the speed passion website and at my ESC ( GT 2.0 LPF ) for some firmware and updates but im actually really confused ..
Im not the top at computing so i dont really know the difference between driver, firmware and stuffs, but what im actually trying to find is a firmware update for my GT 2.0 LPF so that i can get the boost option and be the same at my local track .
So if anyone has a moment, could you give me a link or a litle explanation ?
Cheers ;
cyclone speed is offline   Reply With Quote
Old 01-19-2011, 06:58 AM   #6329
smilekt's Avatar
any one test the new software ...? what the total advance timing ... still 26.5 degree ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 01-19-2011, 10:57 AM   #6330
It's no longer available!
Fastfreddy74 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
