Old 01-05-2011, 12:32 AM   #6286
spar9368's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to spar9368
Originally Posted by M7H View Post
Nowhere in your story I see you've tried a new battery...
Originally Posted by irgo View Post
Try to Replace your Servo, and change your receiver,
and or reset your transmitter settings.
Oh! maybe I should wear a new underwear to the track. Or maybe I should have tried a new pair of shoes? Maybe I should have changed my soldering iron.
Come on people, it's not like I'm trying to be a noob here. A dear friend of mine is speed passion dealer in this country and we've already worked on and tested but no luck here. FYI, I'm running SMC 6000mah battery and running Futaba BLS551, which all ran flawlessly with other speedies. If I had to try all of those new things, I might simply get an LRP speedy and forget the whole problem, although I have like 4~5 SP speedies and dozens of motors.
Anyone needs BRAND NEW OS Engines, Please PM me.
spar9368 is offline   Reply With Quote
Old 01-05-2011, 03:05 AM   #6287
M7H
M7H's Avatar
If you think it helps, you should do that yes....
Had 2 brand new speedy and 6 brand new motor
Are you sure?
Serpent
M7H is offline   Reply With Quote
Old 01-05-2011, 05:09 AM   #6288
mr crum's Avatar
Send a message via Yahoo to mr crum
Am located in down under, and do I still have to send it to the US?
did u flash software to esc twice it is recommended that you do so
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-05-2011, 06:27 AM   #6289
spar9368's Avatar
Are you sure?
Yes I've purchased 2 SP2.0 blue ones and 6 brand new motors for sure.
Oh yes one guy (peter george) sent me a pm with the same info (thanks again) and yes I've tried and no luck again.
Old 01-05-2011, 07:45 AM   #6290
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
I've only every run the 528_Stock SW with motors ranging from 10.5 to 21.5, but one thing came to mind to try: Increase the neutral width setting to see if there is a sensitivity to the radio/esc combination being used.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 01-05-2011, 09:36 AM   #6291
Solara's Avatar
Trader Rating: 16 (100%+)
If you are not in US....you have to contact the HONG KONG office for service. BTW..where exactly you are located? May be I can find you a local rep...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-05-2011, 09:46 AM   #6292
grapejuice's Avatar
Trader Rating: 126 (100%+)
Default 13.5?
I have a GT2.0 Pro and running a V3.0 13.5. Everything was running fine and now I turn it on and only get about 1/4 throttle and the green light is flashing on the speedo. I tried a new sensor board, new sensor wire and same thing happens. Put an 8.5 in and it works fine...this same thing happened with two different 13.5's and two different esc's. Any ideas? Running the 528 software...
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 01-05-2011, 11:19 AM   #6293
Send a message via Yahoo to motojon
What esc to use for mod w/ 4cell nmh its a t-bar 1/12
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 01-05-2011, 12:09 PM   #6294
spar9368's Avatar
I'm in Australia and a friend of my is Speed Passion distributor in Australia, so I'll be on my own. Thanks.
Old 01-05-2011, 01:11 PM   #6295
My friend had a very similar problem. Turned out the battery plug could not handle the current. Try another plug on the esc end.
You really need to try a friends battery as well to make sure yours isn't the problem either.
When you run super powerful motors your battery must be strong enough to hanle the current.
regards
Mike
ixlr8nz is offline   Reply With Quote
Old 01-05-2011, 09:02 PM   #6296
skypilot's Avatar
Trader Rating: 14 (100%+)
I have in the past, ran a race, pulled my car, went back out for the next heat and the servo be crap, don't discount it, it may have a bind and have a high current draw when operating. pull the lead from the rcvr and see what happens, its free and easy, worth a try.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 01-05-2011, 09:57 PM   #6297
hey skypilot, can you give me a call???
rich
gdcopbdcop is offline   Reply With Quote
Old 01-08-2011, 03:18 PM   #6298
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
Anybody have a starting point for offroad SC truck using SP V3 10.5 on 528 stock?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is online now   Reply With Quote
Old 01-08-2011, 03:22 PM   #6299
Trader Rating: 74 (100%+)
Not for you...
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, JSpec custom stickers and apparel.
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-08-2011, 05:19 PM   #6300
irgo's Avatar
Default New SP/HW GT2.xx SC 3rd
Originally Posted by COBRARACING View Post
Hi Guys
Just an early treat for the weekend i have two links for the new software that can be downloaded forget monday as i said ive decided early as i know what the racer and hobbiest is like we want it now now now because thats how i would be .lol
The software is for stock racing 1/10th .
Please read the instructions first as there are quite a few options you might not understand .But i can tell you that the brakes have gone from 4 options to 8 and more steps have been added in programming especially with timing.
links are below
thank you all for supporting hobbywing .
http://www.filefactory.com/file/b4g9....63_110105.rar
http://www.filefactory.com/file/b4g9...are_110106.doc
any download problems please let me know via email teamcobraracing@gmail.com
enjoy your racing guys and i hope to see some of you at the TITC in february in thailand
Stock 3rd Gen.
Quark Force
irgo is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
