Like Tree8Likes
Old 12-27-2010, 10:01 AM   #6271
cyclone speed's Avatar
Hello everyone,
I have a speedpasion GT 2.0 LPF :-D
I have a few questions, whats are the real advantages of the software updates/programs on esc's ?
And also, could some point me a good fdr for the lrp x12 13.5 on lipo , thx :-)
And at last, is the ESC i have good ?
Thank you in advance ;-)
cyclone speed is offline   Reply With Quote
Old 12-27-2010, 10:08 AM   #6272
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by cyclone speed View Post
Hello everyone,
Depending on what class/motor you are running, software is VERY important.
For a 13.5, depending on size of the track, on non boosted aps go between 5.5-6.5 and boosted aps from 6.5-7.5.
LPF is a VERY GOOD Esc.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 12-27-2010, 11:36 AM   #6273
Cheers
Il try the gearing ( its for indoor medium-tight and for outdor medium )
But i see alot of posts about the softwares, i read them but dont understand much lol, what is the boost ? Do i have it on my LPF ? I havent updated my ESC since i dont have the litle board to plug to the PC, but what are the main gains on software update ?
I run pro stock,13.5
Old 12-27-2010, 12:37 PM   #6274
LonnyJ1950's Avatar
I was hoping to use Christmas money to buy a V 2.1 for 1/12th, but everyone seems to be out in the US. What's up?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-27-2010, 12:57 PM   #6275
stipres's Avatar
Trader Rating: 70 (100%+)
PM sent
Pres Ilog
AKA Products, Team Losi, Track Star Racing, Tekno RC, Hitec RCD, LRP, Schelle Racing, Imagine It Graphics, EKD, VP/PowerMaster fuels
stipres is offline   Reply With Quote
Old 12-27-2010, 01:46 PM   #6276
Originally Posted by irgo View Post
5 cell 7.5 to 8.8
6 cell 8.0. to 10
Goodluck and it's for Mod only
Thankyou
Ryper Hobbies - ryperhobbies.com.au-- AKA Australia
brendon is offline   Reply With Quote
Old 12-29-2010, 06:02 AM   #6277
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default 2.1 Pro Stock
The first outing with tthe Speed passion in 17.5 TC was a great success. I had to turn down the drrs to 3 with our slick track (new layout). I enjoyed the smoothness of the supercharger and my motor was always cool (114 degrees after 8+ minutes).
Jaz406 is offline   Reply With Quote
Old 12-29-2010, 08:23 PM   #6278
Trader Rating: 152 (100%+)
got an older esc here
Granturismo brushless esc 1.0
is this esc's firmware upgradable?
is this legal for non-timing esc?
S I O is offline   Reply With Quote
Old 12-30-2010, 04:10 AM   #6279
mr crum's Avatar
Send a message via Yahoo to mr crum
is this esc's firmware upgradeable?
no it is not upgradable it is not on roar list but if you can show track official that you have no timing i dont see a problem
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 12-30-2010, 07:57 AM   #6280
spar9368's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to spar9368
Originally Posted by spar9368 View Post
Hi all,
Am running GT 2.0 with 205 mod software, and I'm running SP V3 3.5 ~ 4T motors at my home track. It is a large open track and I'm running FDR around 8~8.5. Motors are running around 65deg Celsius (with heatsink but no fan).
The problem with my ESC is that somehow sensor unit doesn't work. I've tried different motor and different sensor cable, but that wasn't a issue. I believe it was ESC, so I bought a brand new GT2.0 again and tried, but it worked for like a minute and doesn't work now. The green light on the bottom of ESC is blinking, which doesn't really happened, when it was fine. Both ESC are still working without sensor system.
Can anyone help this issue? Am I running to low turn motor with lipo batteries? Am I overgeared or undergeared?
Thanks in advance.
Sang
Originally Posted by Solara View Post
Sang:
You indicated it is the SENSOR problem....how can you tell it is a sensor problem..? Motor is cogging? Won't launch? Not moving...?
(1) Turn off the THERMAL protection on the ESC, also, turn off the LIPO Cutoff. Just want to test and make sure there are no cutoff engagment to make the ESC not working...you can turn them back on if the problem solved.
(2) Open up the V3 motor and clean up the SENSOR unit within...just dust off or blow off the dust/sand or whatever that might caused the problem
(3) Run it again.....with the timing ring on the V3 motor at the MIDDLE (5*) position.
Please report your result here....Thanks
Okay, here's my report.
The initial problem I wanted to solve was 'Sensor issue', which can be described as follow.
I ran 3.5T to 5.5T motor at my home track, mostly between 3.5T and 4T, and when I first installed ESC and motor, it was fine for like 30seconds.
And then it suddenly works like no sensor system. I don't see any performance difference with or without sensor cable, and I tried 0 DMTS timing and 26.25 timing (value 8), and there was no difference in the performance at all. So basically so far it is safe to say that sensor system has some kind of issue.
Both ESC and motor was brand new, and I thought I might have damaged in that 30sec period, so I've put the new motor and ESC again, and then same thing happens again. Of course I've tried different motors and different cables, and it all goes to the same problem. And on the bottom of the ESC, green light was keep blinking, so I guess it would have some problem.
I've then turned off any sort of protection, and it still does the same thing. Over Heat protection is off, so as voltage cutoff. But it still does the same thing.
When I re-boot the ESC (as in turn off and on again), green light is gone and it just seems fine. And then I try to accelerate a bit, like 30%, then green light is back again flashing. So I guess it is safe to say ESC is doing something wrong. BTW, motor was cogging when I slightly accelerate.
FYI, I have been used about 20 SP V3 motors, and I know a few top drivers at my local track runs pretty much the same timing and gearing, so it shouldn't be this bad. Motor and ESC was never thermalled too. I might try SP V2 motors, but then again I might have some same problems.
If anybody knows any better solution, please let me know.
Okay can someone fix this problem?
Apparently speedy doesn't work with sensor system. I upgraded my speedy to 528mod version, and still have the same problem. It has green light flashing on the bottom and works like no sensor system is working. When I turn it on, it is fine, but as soon as I hit the throttle, green light comes back on and no timing system is working. I've turned off all those protections and stuff, and yet it is still doing the same thing. The performance is identical with or without sensor cable. Btw, green light does not flashing, if I test without sensor cable at all. So I guess it is some problem with sensor function
I've tried different motors, including a few brand new, and also have replaced a few sensor units, and all came back with the same result.
Bottom line:
1. Had 2 brand new speedy and 6 brand new motor, and no success
(motor sensor timing was fixed at 5 deg)
2. Changing sensor cable and sensor unit in motor didn't help
3. Upgrading software didn't help
4. All protection was turned off while testing
5. I used LCD programming card, and whenever I changed the setup, it was saved and changed, so there's no argument on this matter
6. Am using 10awg wire on battery and motor
7. Neither motor and speedy was hot at any stage
(motor came back with 65deg celcius and speedy was just cold)
Anyone needs BRAND NEW OS Engines, Please PM me.
spar9368 is offline   Reply With Quote
Old 01-02-2011, 01:58 PM   #6281
seth556's Avatar
Trader Rating: 37 (100%+)
Originally Posted by michaelb5097 View Post
just got my speed passion cirtix stock club race today, and im having a problem getting it going. When i swith it on the red led flashes and beeps continuously.
Its attached to a tekin 10.5t sensored motor and a 5000mah 7.4 lipo and a pretty standard receiver and transmitter. The only time the led stops is when i take out the sensor cable and plug it back in but after that nothing happens
anyone know where im going wrong
thanks
Did anyone figure this out? I'm using a Novak motor which was working great at the track until I turned it on for another run during practice and it would start beeping like this. I found plugging in another battery would solve it, then switch back the other original battery would fix it for some reason. But then this trick no longer worked, just beeping. Got home and it works fine? idk what was up with it.
seth556 is offline   Reply With Quote
Old 01-03-2011, 08:22 AM   #6282
Solara's Avatar
Trader Rating: 16 (100%+)
Bottom line:
Contact Speed Passion USA and send the ESC in for service/testing....thanks
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-03-2011, 08:09 PM   #6283
spar9368's Avatar
Am located in down under, and do I still have to send it to the US?
Old 01-04-2011, 06:17 AM   #6284
M7H
M7H's Avatar
Bottom line:
Nowhere in your story I see you've tried a new battery...
Serpent
M7H is offline   Reply With Quote
Old 01-04-2011, 07:19 AM   #6285
irgo's Avatar
Try to Replace your Servo, and change your receiver,
and or reset your transmitter settings.
Quark Force
irgo is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
