Like Tree46Likes
Old 12-23-2010, 12:36 PM   #6256
begrie's Avatar
Originally Posted by robk View Post
TRUTH
yeah i LIKE...
Dragsterz Riena Rc Kelantan
sANwa / gQ / SpeedMind / Team AssociAteD / YoKoMo /
SAKurA ZeRo / HoBbyWing / Tekin / PacTra / TamiYa / ProToForm / HSp
begrie is offline   Reply With Quote
Old 12-23-2010, 01:44 PM   #6257
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default pro stock 2.1
Just got my SP Pro stock 2.1. so I am excited to replace the tekin rs thats in the car now.
I have a Duo 1 in the car now, are the latest SP 3.0 version 17.5's torque based or rpm based motors? I am wondering if gearing needs to be changed substantially.
Jaz406 is offline   Reply With Quote
Old 12-23-2010, 02:24 PM   #6258
Trader Rating: 16 (100%+)
Gear similar to DUO base motor is good enough...but I recommand turn the timing to the max 10* on the SP 17.5 V3 motor to start (for 17.5...the max 10* timing on the can works the best).
For 17.5 TC setting...check out SP team setup page and you should find all kinda setup for this motor and ESC, indoor and outdoor...carpet or asphalt.
MERRY X'MAS everyone and happy new year....from SPEED PASSION.
Old 12-23-2010, 11:32 PM   #6259
begrie's Avatar
Merry X'MAS to you too m8
Old 12-24-2010, 06:48 AM   #6260
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Merry Christmas guys.
i have just recieved my Speed Passion gear. in an Xray T3, V2.0 speedy, and 4t v3 motor, i calibrate to my radio, and when i turn it on, the motor revvs for like 1 sec. if i didnt have it on a stand, it probably would have gone through my window ? is this normal ? or have i done something wrong ? Cheers. Patto.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-24-2010, 06:58 AM   #6261
Thanks Solara,
I am running the Duo 1 in the middle setting now. I'll max out the timing on the SP motor and get some settings off the web.
Merry Christmas!
Old 12-24-2010, 11:29 AM   #6262
Danny-b23's Avatar
Generally with the spec zero timing classes we're running maxed timing with a final drive ratio of 3.7-4.2. With the boosted 17.5 class I've found that with the right settings you can run around a 6.9 FDR and be pretty safe temperature wise.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-24-2010, 09:13 PM   #6263
defcone's Avatar
Trader Rating: 15 (100%+)
Maybe you calibrated it wrong? Mine doesn't do that with either v2 or v3 motors.
defcone is offline   Reply With Quote
Old 12-24-2010, 10:29 PM   #6264
Revlimit's Avatar
Try setting a fail safe on your radio. I had this same problem when I first got my speed passion equipment a year and a half ago. I don't have to on my tekin or my old mamba stuff. I think it has to do with the arm time, the speed passion is ready to go as soon as you flip the switch the rest take a little bit. Hope this helps.
Dirt oval crazed!
Custom Works Rocket 13.5 latemodel, FT B4 backup latemodel/offroad
Boss tuned Speed Passion Power http://bossrcmotorsports.com/
Proud member of Hubbard Motorsports, Team Wicked, and Boss RC Motorsports!
Revlimit is offline   Reply With Quote
Old 12-25-2010, 12:09 AM   #6265
Pattojnr's Avatar
Thanks, ill try it all again.
Serpent - Walter RC
Old 12-25-2010, 12:27 AM   #6266
Would anyone be able to sugest a gearing for a 5t in a TC. I cant find the recommended gearing anywhere.
Ryper Hobbies - ryperhobbies.com.au-- AKA Australia
brendon is offline   Reply With Quote
Old 12-26-2010, 03:54 AM   #6267
irgo's Avatar
5 cell 7.5 to 8.8
6 cell 8.0. to 10
Goodluck and it's for Mod only
Quark Force
irgo is offline   Reply With Quote
Old 12-26-2010, 08:51 AM   #6268
Hello People!
Sorry that I now stupid question.
Did not feel like reading all the poste.
Can you tell me wihch is currently the best program for Speed Passion
Gran Turismo Version 2.
If I want to go Modified 4,5 Turn,
Greetings Stefan
need not be
stefan Köhler is offline   Reply With Quote
Old 12-27-2010, 08:52 AM   #6269
Try to follow the calibration setup and do it 1 more time...hope that will work for you. If not...in some ODD reason, try reverse your throttle setting (that was only for FUTABA radio owner only). But I had a KO customer got that work so don't ask me why....it just work for him. Give that a try.
For the 10,000 time...make sure your throttle EPA and Brake EPA are on 100%...not 105% not 95%, both 100%...default.
Old 12-27-2010, 09:02 AM   #6270
Originally Posted by stefan Köhler View Post
Hello People!
Greetings Stefan
090205MOD is what the 2X WORLD CHAMPION Marc Rheinard used for mod TC and mod 12th scale. You won't go wrong with that...
If you want to try the SUPERCHARGER version...use 100528MOD.
We have both software ESC setup on our site.
http://www.speedpassion.net/us/escsetup.asp
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
