Like Tree12Likes
Old 12-06-2010, 07:44 PM   #6196
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by irgo View Post
Anyone Know how to control Supercharge during after the Full Throttle
engage ?
Originally Posted by skypilot View Post
Yea. Profiles 12 - 15. Why?
Btw. Where do you race? Could you post a link to some of you race results or race videos
nope, i meant during the SC is activated, when Reduced The throttle,
The SC is Deactivated instantly, instead of adjusting the SC Speed.
thats not what you asked.
are you trying to ask, after the supercharger is engaged and you let off the throttle how do you control it, cause that doesn't even make sense. why do you need to control boost when off throttle? if you wanna know how do you control it after you let off then get back on, then that would be by the throttle delay you have set, or the rpm delay you have set....
or where you just trying to tell a joke and it went over like a fart in a submarine
btw, how about them links I asked for, you have any??
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 12-07-2010, 06:33 PM   #6197
I have GT ESC V1.1-LPF Edition that I never used, my 1/12th track disappeared. I am going to run some 1/10th dirt at a new track and was wondering if I can update from V1.1 software. I don't see any mention of it on the website.
Looking to run 13.5/17.5 2S Lipo and Futaba 603FS.
deker9 is offline   Reply With Quote
Old 12-08-2010, 10:03 AM   #6198
Solara's Avatar
Trader Rating: 16 (100%+)
Sorry, V1.1 is not upgradable. However, I think it is still capable to race in dirt or off road in stock class...you will be short from those who use BOOST and SUPERCHARGER...
Time to upgrade to GT2.1 series.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-08-2010, 01:37 PM   #6199
thanks Solara...unlikely I will get GT2.1 though.
Old 12-10-2010, 01:11 AM   #6200
DanOK's Avatar
Default gt 2 no timing light where is it?
Hello. Need some help finding the flashing light that indicates Im running stock no timing on my gt 2.0.pro
Ive definetly changed my software no problem. Trouble is the only light I can find seems to be coming from the base, red when I throttle forward or backward.
User manual shows 2 leds green and red near the motor sensor cable that I dont seem to have on mine.
Thanks in advance!
DanOK is offline   Reply With Quote
Old 12-10-2010, 03:30 AM   #6201
mr crum's Avatar
Send a message via Yahoo to mr crum
Thanks in advance!
does ur 2.0 have a semi clear bottom on it the light will shine thru the bottom of case
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 12-10-2010, 04:20 AM   #6202
Super Moderator
Thanks in advance!
Try pulling the sensor cable and looking there. That's what one guy I know said he did to get through tech at the offroad nats.
Dave H is offline   Reply With Quote
Old 12-10-2010, 06:53 AM   #6203
san.'s Avatar
Trader Rating: 59 (100%+)
Thanks in advance!
I had the same issue. I was able to fix this when I set my Throttle EPA to 100% on both braking and acceleration. Also, the throttle curve/expo to 0. Recalibrate and you should be good.
I'm guessing you're motor is connected properly, including sensor wire, correct?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 12-10-2010, 09:54 AM   #6204
Solara's Avatar
For all the GT2 series ESC, when 508_no_timing software is loaded for no timing sportsman event, the bottom of the ESC, with the semi-clear bottom case, will spot the RED LED is on....the RED LED is the only indication when you are using the 508_no_timing software.
If you are running any OTHER software, there will be no LED lit at the bottom until it is on throttle or brakes.
GT2 circuit board was designed way before this NO TIMING thing happened. Our next generation ESC will have all the LED indication above or on the SIDE of the ESC.
Old 12-10-2010, 08:33 PM   #6205
DanOK's Avatar
Ok so I double checked my software, uninstalled then reinstalled V1 508 no timing!
Set my throttle forward and back to %100
I have the clear bottom esc but still only have a red light when i throttle
no green at all
My motor sensor cable only has 5 conductors the original had 6! Could that be it?
Swapped sensor cable thats not it.
un installed program from computer then reinstalled using v1.33 nothing
Old 12-10-2010, 10:10 PM   #6206
What are the bearing sizes in the 17.5 ver3??? My rear one is gritty, wouldlike to change them. Will any bearings do???
DuckStang is offline   Reply With Quote
Old 12-11-2010, 12:11 AM   #6207
Super Moderator
no green at all
Did you recalibrate the ESC to the radio? Need to do that after changing firmware/software.
Old 12-12-2010, 09:40 AM   #6208
Hi all, have a question that hopefully you can help me with.
I'm running a Yokomo BD with a 6.5T Orion. Will the SP GT V2.1 EX be able to support this?
Thanks!
HypeRevAE86 is offline   Reply With Quote
Old 12-12-2010, 11:23 AM   #6209
mr crum's Avatar
Thanks!
the ex is designed for 1 cell racing i would recommend the 2.1 gt you will be much happier
TEAM B.R. RACING
Old 12-12-2010, 04:30 PM   #6210
rc-racer-kirby's Avatar
Send a message via MSN to rc-racer-kirby
Ordering a V2.1 Pro Stock tomorrow.
What is meant by recalibrating the the esc to the radio? I've heard it mentioned before but not quite sure what it means and how it is done.
Schumacher UK - Lite Modz - Gingapaint
Schumacher Mi4LP - Nosram Matrix Evolution Spec Racing, Speed Passion V3.0, GM 5400 50C, Savox 1251MG, Futaba 3GR 2.4ghz, TiR Screws, TiR CVD's, TiR Layshaft, Ti Turnbuckles.
rc-racer-kirby is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
