The Speed Passion Thread
#6151
Hey people,
what is happening with Speed Passion, i have ordered 3 SP13.5 motors V3.0,
all by different webshops all around the world:
1 x in my own country
1 x in the USA
1 x in China
All between 2 to 3 months ago, but they are all out of stock...?
Does anybody know more..?
1 x in the USA
1 x in China
#6153
Is the GT2.1 Prostock ESC going to be approved for the ROAR Sportsman ESC list?
#6154
#6156
Hi Guys
Do you have any recommended set up for a 17.5 on a medium size carpet track. I am currently using the 528 program...
I tried my car with a ratio of 7.50 and at max boost and punch but the car did not have any punch nor speed... I tried using a ratio of 6.50 but I did not see any improvements in speed and torque either....
I Also tried a couple of set ups that were listed on the website... But they did not seem to help in my top speed.... Do you guys have any problems in achieving top speed as compared to the tekins?
#6158
Hi Guys
#6159
Hi Guys
SP17.5v3 10 degree timing
5.3 FDR
#9/ Max
#12/ 6
#13/ 1
#14/ 1
#15/ 4 adjust down if you need more punch.
Hope this helps
#6160
Trader Rating: 32 (100%+)
Hi Guys
Here are the settings that I use with SP 17.5 V3 motor set at 10deg timing advance....and 7.32 ratio at The Track and just about all the Carpet tracks in our area...this doesnt work for all motors with a Duo 2 these adjustments change.
1-3-1-9-3-3-2-1-8-2-9-1-1-5
#6161
Have anyone tried the optional rotors, like the silver ones and the super 7's, are they any better?
http://www.kinggolden-rc.com/search.asp?s_key=RM1380
Looking for some more midrange power for my 1/12th scale 4.5t
Thanks,
Eirik Andreassen
Thanks,
Eirik Andreassen
RM13806
V3.0 3.5T-8.5T Rotor, Super 7 (Orange ring 13MM rotor with Super 7 - High, RPM, and Long Run Time)
#6162
(1) LCD programmer box
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
(2) Multi programmer box
http://www.speedpassion.net/us/produ...PESCPB01&c=OPT
#6164
Hi Guys
Kelvin....what motor are you using?
What Kevin said is what we (Chicago Team) used very much @ The Track harbor....you might be using NOVAK Ballistic then it need to be adjusted. We were using SP V3 motor and there is NO WAY it is lacking top speed or low end punch with Kevin's setup...I might not be the one to judge, but this setup was approved by Stegan, King and Sydor...it is the way to go.
#6165
Kevin,
I was using the Novak Ballistic 17.5 motor. Any idea what other adjustments do I have to do to my motor or is getting the SP 17.5 V3.0 motor the only option?
