Like Tree32Likes
Old 11-22-2010, 08:34 AM   #6106
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by dirtracer20 View Post
Question I have the gt2 my program box broke when it hit the floor,will the program box from the citrix system work on the gt2 I've tried to put reverse in with the box no luck
No...they are not the same (within). Sorry
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-22-2010, 09:07 AM   #6107
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
hey Howard did you see the post i put up for you about the rims you should use for new 1/10 scale car???
TRXRACER99 is offline   Reply With Quote
Old 11-22-2010, 09:33 AM   #6108
Solara's Avatar
Where...? Sorry, I must be missed that....
Old 11-22-2010, 10:17 AM   #6109
tedstryker's Avatar
Trader Rating: 74 (100%+)
Hey guys i have the 3600 SC COMBO...i have a couple problems with it well after recalibrating the system 25xs cause the instructions were totally backwards........
list of problems so far with this system "system ran twice"
seems like my neutral range and throttle range are non-exist....
combo has low end punch..no top end...gearing 20/84..then tried 18/84 no difference...adjusted throttle on controller still no difference..
using the program card with the system seems like its doing nothing.
i shut the drag brake off ...still on full
advanced the timing for more top end....did nothing
put on reverse setting just trying to figure out if its me ..nope no reverse..
after I'm making adjustments with the card waited 3 seconds before hitting the throttle as recommend in the manual..still no luck with anything...
is it the card?..is it the esc?.....is it both?....anybody that has experience and knowledge that could help would be appreciated...
p.s yes i sent several emails to speed passion ..no luck..
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 11-22-2010, 10:51 AM   #6110
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Each time you program a parameter with the card are you pushing the "ok" button to accept what you just changed?
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-22-2010, 11:28 AM   #6111
TRXRACER99's Avatar
http://www.amainhobbies.com/product_...el-Set-White-4
try these
Old 11-22-2010, 11:47 AM   #6112
tedstryker's Avatar
of course and the value and item blink...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 11-23-2010, 09:23 AM   #6113
tedstryker's Avatar
nobody wants to help me on this?......
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 11-23-2010, 10:35 AM   #6114
Solara's Avatar
After all the setting are done with the programmer card, can you shut down the system completely and restart the system and give that a try.
Let us know does that work....
And, you are not using it via the USB programming software right..?
Old 11-23-2010, 11:17 AM   #6115
tedstryker's Avatar
after all items are selected i choose my value..click the ok button it blinks..i unpluged it from the program card..the one that come with combo...i then shut the sytem down plug it back into my receiver...power the system up wait 3 seconds and still the same thing...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 11-23-2010, 12:05 PM   #6116
OK. You choose "All" of the parameters you want and then click OK?
You need to select say "drag brake X" and then hit "OK"
Then choose the next item then hit "OK" (but only if you change the value for that parameter)
Each parameter you change you need to click "OK" before you move on.
Jimmy Wright
Old 11-23-2010, 12:11 PM   #6117
tedstryker's Avatar
yes my bad..i choose drag brake 20% click ok..then say timing. 11.25 click ok etc..etc....
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 11-23-2010, 06:10 PM   #6118
tedstryker's Avatar
so my emails fall on deaf ears with speed passion...and i get no help from the rc community...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 11-23-2010, 07:16 PM   #6119
kschu's Avatar
Send a message via MSN to kschu
what gun are you using ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-23-2010, 08:12 PM   #6120
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Im making the move to Mod next year and am after a SP GT2.0 but no one seems to have it in stock, if i was to install a fan on the 2.1, is this capable of running a 4.5 motor?
Also i was told SP stopped making the 2.0's, is there a new esc coming out?
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
