Like Tree32Likes
Old 11-12-2010, 09:38 AM   #6016
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by QDRHRSE View Post
That's what I was hoping not to hear. I read that its not recommended. I also saw that the ESC is smaller. Oh well. You live an you learn. I'll sell the EX and use something else. If you can't use it in a touring car, how do they think its going to work in an offroad buggy?
EX esc is designed to work with 12th and 10th scale WGT because we lowered the heatsink (less heatsink) in order to fit those low profile body. It cannot mount a fan for the same reason....because of the smaller heatsink and no fan, thats why it is not recommanded for 2S racing on TC racing.
It works on 2S buggy racing stock motor is because OFF ROAD typically are alot less POWER compare to ON ROAD. Buggy, hardly use alot of SUPERCHARGER or BOOST....On road does. Thats why you will see those 1/8th E-buggy, running 4S, can last 15 minutes...but 1/8th On Road, E conversion...I am lucky to last 6 minutes without blowing up the ESC. Big different...
Another reason EX is a good option for stock 2WD buddy is the same reason like on 12th scale...the ESC can be mount on the side and the body of the buggy can still fit without punching a hole above it. Thats why we listed the EX on the 2WD stock buggy list of recommanded ESC.
About you selling the EX...trust me, you won't have any problem selling it, we are on world wide backorder for all 3 of the EX until like....I don't know when.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-12-2010, 09:43 AM   #6017
Solara's Avatar
Our team drivers just received their prototype software for the STOCK Racing. Targetting for indoor carpet, small tight track layout...and 12th scale/10th WGT software. Especially the lower RPM ramp, and Supercharger boost/RPM range are revised....
Once the testing are done and approved...it will be listed on Speed Passion website for download.
Old 11-12-2010, 09:52 AM   #6018
Trader Rating: 478 (100%+)
Solara,
Thanks for the response. I'm surprised by it as my 1/10 buggy is a lot heavier than the TC5 and contrary to what you are saying my buggy is set up to have a lot of timing and a load of boost starting at a low rpm. My local track has a huge straight as well as some large jumps that come right after slow corners and with a 17.5 in it I need all the get up and go that I can get. Anyway, the info is much appreciated and since you are the manufacturer I'll take your advice.
QDRHRSE is offline   Reply With Quote
Old 11-12-2010, 10:00 AM   #6019
Solara's Avatar
Solara,
It is the amount of THROTTLE using on ON ROAD is alot more then off road...thats why the run time on ON ROAD is alot shorter then OFF ROAD.
Of course...if I am running a OFF ROAD on the current WORLD CHAMPIONSHIP track @ Thailand (175 x 350) versus a 40 x 90 indoor carpet with TC5...there are no comparison.
The boost/turbo used on TC 17.5 (open ESC spec) should be ALOT more on ON ROAD then on OFF ROAD....however, I am not a good off road guy to answer that question, so correct me if I am wrong...(I am going to OFF ROAD this coming year, hopefully I can learn a thing or 2).
Thanks for your support with SP.
Old 11-12-2010, 11:53 AM   #6020
Trader Rating: 14 (100%+)
Quick question. Will the hobbywing esc program box work on my cirtix??? Reason I ask is that a bud has two of them and I want to use one till I can get the speed passion programmer.
DuckStang is offline   Reply With Quote
Old 11-12-2010, 12:25 PM   #6021
skypilot's Avatar
Solara,
it has more to do with wheel spin then the weight of the car that loads up the esc. I've ran boosted 17.5 in a SC10 in the mod class where most guys ran a 8.5 and had very little trouble running up front. I'm not really sure which buggy you can mount the esc on its side and still clear the
body thou.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 11-12-2010, 01:02 PM   #6022
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
i run the fan off the esc and double sided tape next to it to still blow air on it.
TRXRACER99 is offline   Reply With Quote
Old 11-12-2010, 02:32 PM   #6023
traper285's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to traper285 Send a message via Yahoo to traper285
Thanks for the software! I'll be using it on the track tomorrow night on my GT2.1 EX esc.
Team Schumacher USA www.racing-cars.com
Team Speed Passion USA www.speedpassion.net
Futaba 3PK 2.4 Ghz FASSST www.futaba-rc.com
traper285 is offline   Reply With Quote
Old 11-12-2010, 04:07 PM   #6024
xrayal's Avatar
the new software for indoor tight on carpet, is it for the gt series speedos? i was wondering if i will be able to ues it on my gt2pro2.0?
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 11-12-2010, 04:29 PM   #6025
Danny-b23's Avatar
Yes, the new SW is for the GT Series.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 11-12-2010, 05:11 PM   #6026
irgo's Avatar
is there any changes on DRRS ?
Quark Force
irgo is offline   Reply With Quote
Old 11-13-2010, 11:26 AM   #6027
xrayal's Avatar
on our tight indoor 22m straight tech track my settings are as follows:
fdr 7.4
gt2.0pro 528
drss 8
amts 8
sc boost 1 off
sc rpm delay 4000
sc full th delay off
sc punch max (hot)
max temp reached on motor 67degrees
no fan on speedo-max temp 40 degrees
novak 13.5 ss with mechanical timing set to 3/4 advance
5000mah 40c demon lipos
the car is as quick as any other, although on the straight the tekins initial pull is greater for around 3m when i catch up.
as for lap times, last night the fastest gut was 8.36 sec lap and mine was 8.76 and that is more to do with driver skill...............
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 11-13-2010, 12:02 PM   #6028
traper285's Avatar
fdr 7.4
gt2.0pro 528
drss 8
amts 8
sc boost 1 off
sc rpm delay 4000
sc punch max (hot)
Sounds like your car would be faster if you switch #12 to a different number. As of right now you have no SC function with it on #1.
Old 11-13-2010, 02:45 PM   #6029
xrayal's Avatar
[QUOTE=traper285;8204911]Sounds like your car would be faster if you switch #12 to a different number. As of right now you have no SC function with it on #1.[/QU
12 had been set at 4. every run i went down one and the car was feeling quicker, also lap times were geting quicker......... car is much faster with sc turned off.
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 11-13-2010, 03:20 PM   #6030
robk's Avatar
Trader Rating: 22 (100%+)
[QUOTE=xrayal;8205318]
Punch should be on #3 or 4. 12 should be #9. gear it closer to 8.0. You are not accelerating because you're trying to jam all the timing in right away (punch set @ max), and your pinion is too big for that track. So when you take away the SC timing, it goes faster. Try the above and see if it helps.
This exact scenario has been fixed by following the above in several cases locally.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
