The Speed Passion Thread
#6003
for Off-Road, since the cylinder magnets the one that rotates,
instead the winding doing the rotation on Brushed motor.
you should worried about the Sensor the most, on SPV3.0 BL Motor,
unless you are running sensoreless mode with SP GT2xx,
nothing you should worried about.
#6004
Does anyone know when SP ESC's will be back in stock. They are sold out everywhere.
#6006
#6007
Wow... I am really confused by the different ESC's, programmers and software
I am looking to run 17.5 TC (both no timing and open) as well as 10.5 TC
So for software; I imagine I use “508_no_timing” for 17.5 no timing and “528stock” for 17.5 open and 10.5?
As for which ESC: What is the difference between the GT2.1 Prostock (EXT98802PROscb) and GT2.0 LPF (EXT98802LPFcb)?
I am also running 17.5 12th scale no timing… so I guess the software to use is also “508_no_timing” and the ESC to get would be the GT V2.1 EX (EXT98802LPFSCB)?
As for the programmer; I suppose I need to pick up the “LCD Professional Program Card” (SPLCD01) and download the V1.32 software?
Any help/advice would be greatly appreciated
#6008
I have a question. What is the difference between the new 2.1 GT ProStock and the GT 2.1 EX ESCs? Is it more than software?? I bought a 2.1 EX to run in my TC5 R w/a 13.5 or 10.5 motor on 2s and after looking online it seems like that might be too much for the ESC. Is that true??
PS: I do a lot of offroad racing and with a GT 2.0 Pro ESC the V3 17.5 is very fast in my b4 buggy w/no issues. Super smooth, fast, and runs very cool with a decent amount of timing and boost.
#6009
#6010
That's what I was hoping not to hear. I read that its not recommended. I also saw that the ESC is smaller. Oh well. You live an you learn. I'll sell the EX and use something else. If you can't use it in a touring car, how do they think its going to work in an offroad buggy?
#6014
GT2.1 ProStock has a aluminum case design, better way to destribute heat then the GT2 LPF version...GT2.1 ProStock is a newer model tehn GT2 LPF..GT2.1 ProStock also use a 30mm fan instead of the LPF use 25mm fan.
Don't get confused...just ask, someone here will have your question answered.
#6015
Thanks Solara
