Like Tree3Likes
Old 04-13-2009, 02:21 PM   #46
Thanks Shawn, the next weekend tested it.
The last week, i classified 2nd and finish 1st in final A, with SP motor.
With this suggestions, and litle good luck, i hope repeat ,
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-13-2009, 02:41 PM   #47
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
I just noticed that my 13.5 has zero endplay...is this the recommended tolerance or should there be .5-1mm like a brushed motor? Thanks!
-rocky b
flatspunout is offline   Reply With Quote
Old 04-13-2009, 03:00 PM   #48
abailey21's Avatar
Trader Rating: 36 (100%+)
Tork=Torque
And you call yourself a National Champion
Originally Posted by Mike Haynes View Post
Hey Tim the sp 10.5 will need a bit more pinion then the novak to feel comparable, it is a more tork based motor. Try gearing it up a few teeth but watch the temp, also the sp motors run well with a lot of esc timing.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-13-2009, 03:10 PM   #49
tim fry's Avatar
Originally Posted by Shawn Palmer View Post
Tim:
Yes, you'll need to be geared up a few teeth from where you had the Novak.
Thanks Shawn.
I'm at 5.4 now so your saying 5.2 or lower?
tim fry is offline   Reply With Quote
Old 04-13-2009, 03:23 PM   #50
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Shawn, this is what caused the broken case. Cheers.
I guess Speed Racer couldn't save Racer X on this one.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 04-13-2009, 03:27 PM   #51
And he walked away...
-rocky b
Old 04-13-2009, 03:39 PM   #52
Shawn Palmer's Avatar
OW Charlie!
That reminds me of those "amazing X-ray" emails with the nails and fence posts through people's skulls!
I like the colors though - black and yellow rox!
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 04-13-2009, 03:40 PM   #53
Tim - yes, 5.2-5.0
Shawn Palmer
Old 04-13-2009, 03:41 PM   #54
flatspun - yes, at least .5mm, and about 1mm max.
Shawn Palmer
Old 04-13-2009, 04:44 PM   #55
tmunno's Avatar
R/C Tech Charter Subscriber
Yahoo, When Charlie torture tests something he does it right!!!!!!!
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Old 04-13-2009, 04:48 PM   #56
Mike Haynes's Avatar
Originally Posted by abailey21 View Post
Tork=Torque
Um, my title happens to be for racing toy cars, not being "edumicated good at skule".
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-13-2009, 05:06 PM   #57
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
-rocky b
Final Destination 17 - McSmooth's Revenge!
Old 04-13-2009, 05:07 PM   #58
Trips's Avatar
Trader Rating: 16 (100%+)
Why didn't Mike Haynes win the spelling b?
Because Mike Haynes is too fast to be in the B.
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-13-2009, 05:52 PM   #59
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey Guys, i am going to buy a SpeedPassion 2.0. Motor. I was going to get a 4.0. My question is do all of the motors have an inbuilt fan or are there some without? I have been told to get the one without the fan.
Also are the normal ones the same as the special edition motors. Eg the Mark R, Jilles edition etc.
If there are ones without the fan could i posssibly get a Pn?
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 04-13-2009, 07:21 PM   #60
bigdadracing's Avatar
[QUOTE=Shawn Palmer;5678929]Hi Russ:
Start with 98/34 and the timing advance maxxed out.
If you didn't run the timing maxxed in your 1.1, then take away another tooth per advance setting you are going up.
Keep your eye on motor temps every minute or so for the first few runs. If you follow the above, you'll be within a few teeth either way. (too hot - lose another tooth or two, or not quite fast enough add a
shawn , is that maxing out motor timming or the speedo's settings????
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
